Side Shaft oil seal - rear right
Duwayne
Town: Strand
Vehicle: 89 Toyota Hilux D/C 4x4 - 3Y & '92 Hilux D/Cab 4x4 2.7i
Real Name: Duwayne
Mon Oct 06, 2008 11:42 am
Hi guys, i decided to check my rear brakes as i noticed oil dripping from wheel drum. if i had clean hands i would have taken a picture. I could hardly see the brake mechanism as it was totally covered with "greasy thick oil". I assume this is the side shaft oil seal on the diff that is leaking? Brake shoes also need to be replaced - soaked in oily grease. Looks like a relatively simple job according to the manual (haven't done it before), but is there an inner and outer oil seal or just one? any advise will be appreciated! gonna replace the wheel bearing while it is open as well. will get seals from Toyota. let me know thanks!
Nitro
Town: Alberton
Vehicle: 1993 Hilux D/C 2.2
Real Name: Victor Nunes
Mon Oct 06, 2008 11:59 am
This seems like a common problem. I had my rear diff serviced and since then have had this leak on the right rear brake drum. The car has been back twice and still leaking! :?
I know I read somewhere about using after market oil seals not being a good idea. I will make sure mine gets an original Toyota oil seal next time.
ThysdJ
Club VHF Licence: HC102
Mon Oct 06, 2008 12:07 pm
yes pirate/aftermarket oil seals do not work. They only work on your nerves, and your wallet... fit the real thing, it is best in the long run.. :twisted: :twisted: :twisted:
Sifu-Lux
Town: Mount Vernon Illinois
Real Name: Andrew
Mon Oct 06, 2008 1:00 pm
Hi Duwayne, I did this a while ago on my Lux.
Drain the rear diff oil.
Jack up vehicle, chock wheels, put axle stands under axle for safety.
Remove the wheel.
Undo the 4 nuts on the back of the drum that hold the assembly to the rear axle stub.
Disconnect the brake hydraulic line.
Disconnect the handbrake linkage.
Remove the old oil seal and the old o-ring on the stub.
Clean everything up thoroughly especially any mating surfaces.
Tap the new oil seal in with a suitable sized block of wood keeping it square to the axle.
Add a light wipe of silicone gasket sealer around the hub face and install a new o-ring in the groove.
Wipe the new oil seal with some clean diff oil.
Insert the sideshaft into the axle being careful not to damage the seal edge.
Refit everything and tighten up.
Lower the vehicle.
Refill the diff to correct level.
Thats it as far as I can remember. Hope it helps. :)
Sifu-Lux....I will miss you
putsy
Town: Brisbane QLD Australia
Vehicle: Hilux D/C
Real Name: Tom
Mon Oct 06, 2008 1:12 pm
Nitro.....
I have heard of a few caes where.
- The collar that holds the rear wheel bearing on becomes worn and causes a leak...
- When putting the axle back try to hold it up when tighting the 4 bolts some times they hang abit low and dont seal correctely (may only be 0.5mm but can healp)
To do the rear wheel bearings you will require a press. You can cut the old collar and bearing off with a grinder just be careful not to cut in the axle itsself, butDO NOT heat the collar up to slide down the axle when refitting this is dangerous and when it cools it does not hold on as thight cand can cause your axle to fall out.
Some bearings if you chose to press them off will be very tight.
Hope this helps
Tom
SFA dual cab 2.8D, Front and Rear lockers, Winch with in cab control, Light Force spotlights, 4 Inch EFS lift, 2 Inch Body lift, Super Swamper TSL's, Bucket seats, Under body lights and some more stuff......
Duwayne
Town: Strand
Real Name: Duwayne
Mon Oct 06, 2008 1:24 pm
thanks guys for the info - exactly what i was looking for. thanks! Gonna go price the seals now.
Mon Oct 06, 2008 2:43 pm
Andrew, brilliant instructions, thanks! I am moving this to "Technical Tips" for posterity.
One trick I have seen is to pinch the brake hose flat with a vice-grip pliers, so as not to lose brake fluid. Works well, but still wise to check the brake fluid level afterwards and bleed the brakes.
Sifu-Lux
Real Name: Andrew
Mon Oct 06, 2008 2:56 pm
I knew I forgot something. Thanks F_D. Bleed the brakes :oops:
BenHur
Vehicle: '96 D/C Raider
Real Name: Bennie
Mon Oct 06, 2008 5:07 pm
Is it necessary to pinch the brake lines ?
Mon Oct 06, 2008 5:29 pm
Well, if you don't, you'll have brake fluid everywhere after having loosened the rubber hose from the brake drum, which you then remove... :wink:
Mon Oct 06, 2008 5:32 pm
You can also just use the rubber cap that fitted to the bleeding nipple to fit over the hydraulic line when removed from the back of the brake cylinder. Works like a charm for me. :)
Sifu-Lux
Real Name: Andrew
Mon Oct 06, 2008 5:44 pm
Or, you can use a piece if clear "fish tank air pipe" from the hardware store as I did in the picture. I also use the clear pipe when bleeding the brakes to make sure no air gets back in the system. Pump the old fluid straight into jam tin.
patrickr
Town: Durban
Vehicle: 1987 SC 2.2 Hilux 4x4, '86 D/C Hilux 4x4
Real Name: Patrick
Wed Mar 24, 2010 11:14 am
Hi chaps,
I don't want to dig up an old thread, but I am facing the same sort of thing with my 'lux. At first I thought the wheel cylinder was toast, but when I opened up the drum, it was dry. Then I found the culprit for the oil- the axle is leaking :problem: It was leaking inside the drum, dripping right onto the shoes. Oil=lubrication, Friction is not friends with lubrication, therefore no braking. OKay, so I can conclude that the seal between the shaft and the backing plate of the drum is leaking (correct me if I am wrong), and that seal needs to be replaced. Super, but how on earth do I get the backing plate off the axle!? I am very nervous about all this cause I don't want to ruin a shaft or something expensive. Can any of you guys help me here? Just don't want to make any mistakes :wink:
Regards,
Patrick
Take nothing but photographs and leave nothing but footprints
Toybox
Vehicle: Hilex
Real Name: Jonathan
Club VHF Licence: X100
Fri Jun 18, 2010 4:19 pm
Bringing an old thread back to life...
Is the removal of the rear side shaft on a Gearmax axle with locker the same as an import? Remove 4 bolts, the brake stuff, and just pull the whole thing out of the axle housing?
Fri Jun 18, 2010 4:48 pm
Toybox wrote:Bringing an old thread back to life...
Yebo...
Toybox
Vehicle: Hilex
Real Name: Jonathan
Fri Jun 18, 2010 5:15 pm
Thanks Cassie.
After an hour of 'percussion persuasion' with a BFH it hadn't budged so I just took it in to the local mac. Now the other side needs doing...
I'll have to have another bash at it...
Fri Jun 18, 2010 6:42 pm
Jonathan, don't forget to 'pinch' your brake fluid hose tightly closed with a vice-grip, to prevent loss of brake fluid when you loosen the pipes before removing the rear axle shaft.
Toyfan
Vehicle: Hilux 2.7i 4x4 DC
Real Name: William
Tue Mar 15, 2011 9:19 am
Hi guys, I have the same problem. Mine leaks inside the drum and appears to leak from the outer seal. I would like to do it myself
but need to visualize the work ahead. If the outer seal leaks, I assume that the inner is also leaking... Correct? If so, then both
must be replaced. Now the main question.... Do I need to remove the bearing and its retainer to replace the outer seal?
Toyfan
Real Name: William
Tue Mar 15, 2011 9:45 am
Oooops forgot to mention that the o-ring appeared not to be sealing properly. Can this also cause a leak.
Sifu-Lux
Real Name: Andrew
Fri Aug 23, 2013 6:01 pm
While changing the diff oil today on both diffs I spied oil on the back wheel rim. Right side side shaft seal this time. Good thing I remembered this old post, stripped and ready now. Just need to get a new seal on Monday. Anybody got a part number on hand?
Masekind
Town: Lichtenburg
Vehicle: 2005 Hilux 4x4 v6, LR tank, ARB Bumper. (iJzer)
Real Name: Drikus
Sat Aug 24, 2013 9:28 am
Ek is besig om alles op my agter shafts te vervang. Het opgemerk dat as die retainer nie op die regte plek gepress is nie (te diep) skuif hy nie in die seel in nie en dan lek die oli uit. Ek het oli op die retainer gesit en die shaft in gesit en gedraai on te sien waar pas die seel.
Dit is op n 2005 V6 weet hoe werk die res nie.
Return to “Useful Articles”
