SFA Built-up.....and a few mods
- Pieter Bean
- Town: Upington
- Vehicle: 2000 Hilux 2.7 D/C Raider 4x4
- Real Name: Pieter Bean
A while back I took stock and realize there was about 2 whole SFA's lying in pieces. Decided what the hell, lets built one. Also wanted a bit more power, was seriously considering a Lexus, but at the end decided to go with a 3RZ. Mainly because I had a complete motor already, with oem ecu, tank etc. Also wanted to fit some 33" tyres, so I needed some lift and with that I needed to convert to a X-over steering. So here goes:
First: Took a 1992 model chassis and started with the engine mounts for the 3RZ, lowering the shock mounts and welding brackets for the IFS steering box. Oh and the bracket for the IFS tank.
- IMG00200-20110720-1036.jpg (34.56 KiB) Viewed 3916 times
- IMG00199-20110720-1036.jpg (35.86 KiB) Viewed 3916 times
- IMG00198-20110720-1035.jpg (42.85 KiB) Viewed 3916 times
[img][/imC:\Documents and Settings\Administrator.16CEF2D4978E478\My Documents\My Pictures\Phone pics2g]
Re: SFA Built-up.....and a few mods
That should be an interesting re-build to follow. Good luck and keep us posted with updates and pics!
- Pieter Bean
- Town: Upington
Welding finished, chassis painted and ready for the suspension and diffs.
- IMG00210-20110720-1541.jpg (42.38 KiB) Viewed 3909 times
- IMG00209-20110720-1540.jpg (46.5 KiB) Viewed 3909 times
- Town: Gordons Bay
- Real Name: Luke
wish i had two hilux's just lying around!!
- Gunta
- Real Name: Mark
Take 2 pics of your lux and throw them on the floor.
Looking forward to this read. The 3RZ is an ideal match for the SFA!
- mervyn
- Town: Randburg
- Vehicle: 2001 Prado 3.4 VX
- Real Name: Mervyn
Guys which motor is the 3RZ? Ffrom which car?
Mark you are hilarious!
- Gunta
- Real Name: Mark
So is the 7mge, loads more torque at low revs. 3RZ is the 2.7 engine.
- Pieter Bean
- Town: Upington
Fitting std. 4.875 ratio diffs (already completely recon) to compensate for the bigger tyres. Rear diff is gearmax with electric locker. OME leaf springs for approx. 2" lift and 2x 25mm = 50mm (another 2") steel blocks between the diff and springs. Used the longer right side U-bolts for front left and rear, will have to make longer ones for the right side front.
- IMG00203-20110720-1038.jpg (40.58 KiB) Viewed 3856 times
- IMG00196-20110720-1032.jpg (37.63 KiB) Viewed 3856 times
- Pieter Bean
- Town: Upington
More pics....
- IMG00247-20110722-1416.jpg (48 KiB) Viewed 3848 times
- IMG00245-20110722-1415.jpg (42.24 KiB) Viewed 3848 times
- IMG00244-20110722-1415.jpg (45.38 KiB) Viewed 3848 times
- IMG00243-20110722-1414.jpg (46.89 KiB) Viewed 3848 times
Coming along nicely .... still don't like the use of spacer blocks though.
- Gunta
- Real Name: Mark
Looking good, what petrol tank are you using. I wonder if you can fit the 90L 2.7 tank.
- Hoppy
- Vehicle: Hilux SFA & IFS
- Real Name: Allan 0721291160
I see you've got a angle grinder and a welder, so shorten the Cassis while you are at it.
I'll send you the specs if you need it, i've done a few.
- witmamba
- Town: Sasolburg
- Vehicle: D4D 4x4 Lux + D4D 4x4 Tuna
- Real Name: Hans
Interesting project - Good luck!!! :wink2:
Life only starts . . . . where comfortlevels end
- dustbuster
- Town: Richards Bay
- Vehicle: Rebuilding 91 D/C Hilux Mboza Body, OME 4Y EFI, & 91 S/C 4Y Hilux
- Real Name: Dean
YEBO YES Some motivation for my project just keep those pics coming looking good so far
- Pieter Bean
- Town: Upington
Just a quick update:
Got the cyllinder head back from the engineering, replaced the valve stem seals.
Took a gearbox from our stock, my brother replaced the bearings and seals.
Fitted a new clutch and mate the engine and gearbox and fit it to the chassis. Fitted the head back to the block.
Put the cab onto the chassis to check all clearances. Its just temporary and we will take of again.
Will give more feedback to all the questions as soon as I have more time.
- IMG00273-20110805-1737.jpg (41.5 KiB) Viewed 3663 times
- IMG00270-20110805-1729.jpg (52.48 KiB) Viewed 3663 times
- IMG00269-20110805-1727.jpg (49.7 KiB) Viewed 3663 times
- IMG00268-20110805-1727.jpg (45.9 KiB) Viewed 3663 times
- IMG00267-20110805-1138.jpg (56.91 KiB) Viewed 3663 times
- IMG00264-20110804-0937.jpg (49.14 KiB) Viewed 3663 times
- IMG00260-20110803-1717.jpg (46.53 KiB) Viewed 3663 times
- Thunder02
- Town: East Rand
- Vehicle: IFS Hilux
- Real Name: Neil
- Club VHF Licence: HC105
How do u get two lux's lying around?pampoen wrote:wish i had two hilux's just lying around!!
Build looking great so far.
Scout motto:be prepared....
www.4x4direct.co.za
www.4x4direct.co.za
- Andre du preez
- Town: somerset west
- Vehicle: hilux 2.2
- Real Name: Andre
Dit lyk mal.........!!!!!!!!
- Harm JR.
- Town: Durban
- Vehicle: 1989 Toyota Hilux
- Real Name: Abdullah
Update PLEASE!!!!
- scout
- Town: White River
- Vehicle: 91 Hilux dc -pro comp , arb bb , winch , 33'' muds
- Real Name: Jonathan
ry daai wa al seker 'n mooi trokkie
" Yes I know we are lost , but we are making good time "
- Piesang
- Town: Grabouw
- Real Name: Pieter Pieterse
Ek sien jy praat van sterker motor om die 33" bande te kan hanteer.
Dalk 'n dom vraag, maar as 'n ou die rat verhouding in die diff verander, byvoorbeeld een tant laer op die input, gaan dit nie die selfde wees nie Ek wou dit nog altyd weet
- Pora
- Town: Brakpan
- Vehicle: Hilux 2.5 d4d
- Real Name: Pora
looking good there
