N1 4X4 SPECIAL
Only commercial members may advertise in this section. No commercial member may post on another commercial member's posts. To become a commercial member, please see http://www.hilux4x4.co.za/rates" onclick="window.open(this.href);return false;
Please support our commercial members, they are the guys who pay the hosting account and who help us to keep this forum running, free of charge to you.
Forum rules
Only commercial members may advertise in this section of the web site. One commercial member may not comment in the posts of another commercial member who supply similar products or services.
Marius Boersma
Town: Krugersdorp
Vehicle: D4D d/c 4x4
Real Name: Marius
Wed Oct 29, 2014 3:58 pm
OE PARTS
616120K010GL 1/4 PANEL LH HILUX D4D 2 X R 997.50
616110K010GL 1/4 PANEL RH HILUX D4D 3 X R 997.50
611310K010GL A PILLAR OUTER FRT UPPER RH HILUX 05ON 2 X R 790.00
781200K010GL ACCELERATOR PEDAL HILUX/FORTUNER D4D (05-11) 1 X R 180.00
3610735190GL ADAPTOR GEARBOX KZTE (98-05) 2 X R 3 292.50
202545501PGL AIRCON RADIATOR HILUX (98-05) 1 X R 685.00
2702001901GL ALTERNATOR HILUX YN 1 X R 1 837.50
641010K020GL BACK PANEL LOAD BIN HILUX 05 ON 2 X R 1 885.00
4704305800GL BACKING PLATE RH REAR NEW HILUX 4X2 1 X R 85.00
9008036111GL BEARING CONDOR KF/LF/RZ 1 X R 230.00
9036427002VPGL BEARING G/B 3RZ HILUX 5TH GEAR 1 X R 41.25
9036335036GI BEARING G/B 3RZ MAIN SHAFT CENTRE 1 X R 327.50
9036432023GL BEARING G/B 3RZ NEEDLE 3RD GEAR 5 X R 267.50
3335030010GL BEARING G/B 3RZ REAR MAIN SHAFT 1 X R 652.50
9036335033GI BEARING G/B 3RZ SPIGGOT 1 X R 327.50
9036445002GL BEARING NEEDLE ROLLER HILUX YN LOW GEAR 1 X R 300.00
9036430011GI BEARING S/S FRONT HILUX 98-04 IN KNUCKLE 8 X R 372.50
9036340068GI BEARING SIDE SHAFT REAR HILUX NEW IMP 9 X R 500.00
9036328001GL BEARING STEERING SHAFT TOP HILUX/75/79 1 X R 210.00
9036443006GI BEARING T/F HILUX KZ GEAR NEEDLE 2 X R 230.00
5144135250GL BELLY PLATE 4X2 HILUX NEW 1 X R 72.50
9010514069GI BOLT CRANK PULLEY 4Y 2 X R 67.50
9091002132GL BOLT CYLINDER HEAD 2UZ 20 X R 22.50
4454512010GL BOLT D/LOCK MOTOR REAR HILUX D4D (2005-2011) 1 X R 20.00
9011908466GL BOLT IN FREE WHEEL HUB HILUX (98-05) 16 X R 10.00
9011908466GI BOLT IN FREE WHEEL HUB HILUX (98-05) 5 X R 10.00
9010510270GL BOLT KIT TORSION BAR REAR 3RZ 1 X R 7.50
2367930021GL BOLT LEAKOFF PIPE HILUX D4D (2005on) 3 X R 20.00
5351035150GL BONNET CATCH HILUX (98-02) 2 X R 367.50
5330135060GL BONNET HILUX 1.8/2.4/2.7/3.0 (1998-2002) 8 X R 1 705.00
5330110280GL BONNET HILUX OLD 1 X R 1 547.50
533810K010GL BONNET RUBBER HILUX D4D 1 X R 87.50
3112660081GL BOOT CLUTCH FORK HILUX KZ 1 X R 90.00
551060K011GL BRACKET BRAKE PEDAL HILUX D4D (2005-2011) 1 X R 435.00
551070K010GL BRACKET CLUTCH PEDAL HILUX D4D (2005-2011) 1 X R 280.00
5899505760GL BRACKET CONSOLE BOX REAR RH HILUX YN 4X4 (1984-1998) 5 X R 50.00
631320K010GL BRACKET DOME PANEL FRONT HILUX 2.7 VVTi (2005-2008) 1 X R 210.00
3352135221GL BRACKET SELECTOR LEVER HILUX 2.7 2X4 (1998-2005) 2 X R 200.00
452800K020GL BRACKET STEERING COLUMN UPPER HILUX D4D 2.5/3.0 4X4 1 X R 725.00
4351235190GL BRAKE DISC FRONT HILUX (98-05) IFS 1 X R 727.50
5214235080GL BUMPER BRACKET NEW HILUX LH (02-05) F/L 1 X R 255.00
5214235080GI BUMPER BRACKET NEW HILUX LH (02-05) F/L 2 X R 255.00
521190K360GL BUMPER FRONT HILUX D4D (2008on) BLACK 1 X R 1 105.00
872450K300GL BYPASS PIPE HILUX D4D 2 X R 155.00
4643005736GL CABLE HANDBRAKE HILUX LOCAL DIFF 1 X R 162.50
1115354030GL CAMSHAFT CAP HILUX YN 2 X R 137.50
1916963011GI CAP (GREASE) DISTRIBUTOR HILUX 2Y 2 X R 12.50
3355420010GL CAP GEAR LEVER HILUX 98-05 2 X R 40.00
686100K010GL CHECK FRT DOOR HILUX/FORT <05 1 X R 105.00
8324789308GL CIRCUIT METER HILUX OLD LN W/O REV 2 X R 395.00
9046721010GI CLIP P/S TUBE HILUX/75/79 1 X R 12.50
9046722010GL CLIP TURBO HOSE HILUX ALL 8 X R 7.50
8313289300GL CLUSTER HOUSING HILUX 2L 1 X R 250.00
9091902220GL COIL IGNITION 3RZ (2/3) 6 X R 752.50
5540535100GL CONSOLE RADIO HILUX 98on 1 X R 220.00
8161135181GL CORNER LAMP HILUX SURF (93-98) RH 1 X R 322.50
8151135211GL CORNER LAMP RH NEW HILUX CHROME (98-05) 1 X R 470.00
9006981040GL COVER SOCKET HEADLAMP HILUX D4D 8 X R 40.00
588080K030B0GL COVER SWITCH HOLE HILUX V6 D/C 1 X R 730.00
557090K050GL COVER WIPER MOTOR LH HILUX D4D 1 X R 562.50
5120435570GL CROSS MEMBER CENTRE BEARING 2.7I 1 X R 1 247.50
5120135330GL CROSS MEMBER NEW HILUX CHASSIS FRONT 1 X R 717.50
4120180189GI CROWNWHEEL & PINION 41X11 REAR NEW/HIL 1 X R 3 625.00
1110154111GL CYLINDER HEAD 2L2 1 X R 5 000.00
1110154131GL CYLINDER HEAD 3L 2 X R 5 810.00
1110154150GL CYLINDER HEAD 5L 1 X R 5 220.00
5533089113GL DASH SUPPORT HILUX YN 1 X R 1 892.50
7547305800GL DECAL 2700 CHARCOAL 4 X R 80.00
6762005804GL DOOR PANEL FRONT LH HILUX KZ 1 X R 12.50
6700235500GL DOOR SHELL NEW HILUX D/C FRONT LH 3 X R 1 380.00
6700235470GL DOOR SHELL NEW HILUX D/C FRONT LH (P/W) 2 X R 3 380.00
6700135480GL DOOR SHELL NEW HILUX D/C FRONT RH 2 X R 1 380.00
6700435070GL DOOR SHELL NEW HILUX D/C REAR LH 2 X R 2 837.50
5584335020GL DUCT HEATER VENT LH HILUX 2.7/3.0 (1998-2005) 1 X R 52.50
1711454120GL ELBOW INTAKE MANIFOLD 5L 1 X R 230.00
1740505803GL EXHAUST REAR HILUX 5L 1 X R 840.00
1636175020GL FAN BLADE 3RZ 4 X R 642.50
8713035090GL FAN UNIT NEW HILUX 1 X R 795.00
5380105812GL FENDER FRT RH HILUX 2.7 1 X R 945.00
5380289184GL FENDER LH HILUX 2X4 98-99 1 X R 1 020.00
538760K020GL FENDER LINER LH HILUX D4D 1 X R 290.00
3732405731GL FLANGE DIFF REAR M75 YN HILUX 4X2 2 X R 78.75
1136175020GI FLYWHEEL COVER BOTTOM 3RZ 8 X R 122.50
3321435040GL FORK GEAR SHIFT NO 3 HILUX 84-98 3 X R 307.50
111150C021GL GASKET CYLINDER HEAD 2.7 VVTI 1 X R 357.50
0411254072GL GASKET KIT HEAD SET 3L 1 X R 207.50
8324389213GL GAUGE FUEL HILUX 2.0 4X4 (1979-1984) 2 X R 365.00
3342830040GL GEAR 5TH ON CLUSTER HILUX 2.7 1 X R 1 095.00
3342128053GL GEAR CLUSTER 5SPD 2.7I 2 X R 1 877.50
3348130040GL GEAR SPEEDO DRIVE HILUX 2.7 2X4 <05 1 X R 127.00
5311135420GL GRILLE NEW HILUX 2X4 CHROME (98-02) 2 X R 2 285.00
5311135410GL GRILLE NEW HILUX 2X4 GREY (98-02) 4 X R 1 720.00
5311135510GL GRILLE NEW HILUX FACE LIFT 2X4 GREY 2 X R 1 745.00
531210K070GL GRILLE TOP HILUX D4D (2008-2011) BLACK 1 X R 345.00
531210K080GL GRILLE TOP HILUX D4D (2008-2011) CHROME 3 X R 640.00
4610435050GL HANDBRAKE LEVER NEW HILUX 1 X R 442.50
5313289111GL HEADLAMP LH SURROUND HILUX (84-98) 1 X R 270.00
9098105735GL HEADLAMP LH/RH SQUARE SEMI SEALED HILUX 1 X R 170.00
81110K050GL HEADLAMP RH HILUX D4D (2005-2011) 4 X R 1 130.00
8111080370GL HEADLAMP RH SQUARE COMPLETE HILUX 1 X R 175.00
5313189114GL HEADLAMP RH SURROUND HILUX CHROME 1 X R 475.00
8715035180GL HEATERBOX 3RZ 1 X R 52.50
6873052010GL HINGE DOOR FRONT LOWER RH HILUX D4D 2 X R 45.00
6872002070GL HINGE DOOR FRONT UPPER LH FORTUNER D4D 1 X R 192.50
6871002070GL HINGE DOOR FRONT UPPER RH HILUX/ FORTUNER D4D 2 X R 192.50
6873034010GL HINGE DOOR LOWER RH NEW HILUX 2 X R 305.00
6871034010GL HINGE DOOR UPPER RH HILUX (98-05) 4 X R 305.00
887110K092GL HOSE DISCHARGE AIRCON COMP HILUX (2005on) 1 X R 390.00
90947T2004GL HOSE FRONT RH BRAKE (CALIPER) HILUX D4D (2005-2011) 1 X R 215.00
887040K130GL HOSE SUCTION AIRCON COMP HILUX 1KD (2005-2011) 1 X R 975.00
4110135150GL HOUSING C/PORTION D/LOCK (HILUX/PRADO) 1 X R 2 270.00
3310135051GL HOUSING G/BOX HILUX 98-05 1 X R 2 825.00
692060D070B3GL INNER OPENER FRONT LH HILUX D4D 1 X R 147.50
5370105801GL INNER TRAY NEW HILUX LH 1 X R 550.00
1788054240GL INTAKE HOSE AIR CLEANER 5L HILUX 1 X R 472.50
8978635080GI KEY (UNCUT) HILUX (2002-2005) 1 X R 105.00
3336635030GI KEY 4TH GEAR HILUX 2.7/PRADO90/1GR/1HZ 18 X R 27.50
3332135111GL MAINSHAFT HILUX 4X4 YN 1 X R 1 500.00
1714154111GL MANIFOLD EXHAUST 5L 1 X R 860.00
8794035410GI MIRROR SMALL LH HILUX (98-05) 1 X R 530.00
5308805800GL MOULDING HILUX N/S FRONT L/H 1 X R 1 575.00
1236131090GI MOUNTING ENGINE HILUX D4D (05on) 2 X R 290.00
1237175070GL MOUNTING GEARBOX HILUX 3RZ 1 X R 427.50
1237154180GI MOUNTING GEARBOX NEW HILUX 5L 4X4 1 X R 680.00
9030188077GL O RING SIDE SHAFT BEARING REAR HILUX ALL 2 X R 20.00
412520K040GL OIL SEAL PINION D4D 2.5TD 4 X R 40.00
6921102150GL OUTER DOOR HANDLE FRONT HILUX D4D 1 X R 157.50
610240K130GL PILLAR FRONT HILUX 05 on 1 X R 817.50
611320K030GL PILLAR FRT UPPER LH HILUX 05 on 2 X R 870.00
610230K020GL PILLAR INNER FRONT RH HILUX 05 ON 1 X R 367.50
613080K020GL PILLAR INNER LH HILUX 05 on 1 X R 522.50
613070K020GL PILLAR INNER REAR RH HILUX 05 ON 1 X R 525.00
611320K040GL PILLAR OUTER FRT UPPER LH HILUX 05 ON 1 X R 870.00
611310K020GL PILLAR OUTER FRT UPPER RH HILUX 05 ON 2 X R 1 000.00
4714835010GL PIN TENSIONER SPRING BRAKE PEDAL HILUX ALL 2 X R 15.00
1788567011GL PIPE INTAKE PLASTIC ON ENG 1KZ HILUX 1 X R 515.00
131015406002GI PISTON 2L STD 3 X R 717.50
1664931020GL PLATE COVER NR 2 TENSIONER PULLEY HILUX D4D 2 X R 10.00
1665931011GL PLATE COVER TENSIONER PULLEY HILUX D4D 3 X R 7.50
5828735030GL PLATE GEAR BOOT HILUX NEW 4X4 2 X R 140.00
451050K030GL PLATE HORN BUTTON CONTACT HILUX D4D 1 X R 112.50
746160K020B0GL PLUG GRAB HANDLE LH HILUX D4D 1 X R 7.50
4231505800GL PLUG S/SHAFT REAR (SERVICE) HILUX 2.7 (1998-2005) 19 X R 14.00
6113135030GL POST FRONT NEW HILUX S/C RH 1 X R 1 152.50
6102435100GL POST INNER FRONT HILUX (98-05) SCB LH 1 X R 792.50
6153135060GL POST INNER REAR D/C NEW HILUX RH 1 X R 345.00
6153235030GL POST INNER REAR S/C HILUX (98-05) LH 1 X R 332.50
6161135090GI POST REAR OUTER NEW HILUX S/C RH 1 X R 1 350.00
0444630120GL POWER STEERING PUMP KIT 5L 1 X R 247.50
1637154030GL PULLEY WATER PUMP 5L 3 X R 310.00
163715030GL PULLEY WATER PUMP HILUX 2.7 3RZFE 1 X R 262.50
1657354081GI RADIATOR HOSE 3L BOTTOM ON RAD W/PS 3 X R 237.50
165710L030GL RADIATOR HOSE TOP HILUX 05on 1 X R 75.00
612100K020GL RAIL ROOF RH HILUX 05 on 1 X R 262.50
612130K010GL RAIL ROOF SIDE RH D/C HILUX D4D 2 X R 770.00
613040K020GL REINFORCE PLR LH UPPER HILUX 05 on 1 X R 647.50
613030K020GL REINFORCE UPPER RH HILUX 05 on 1 X R 765.00
611080K010GL REINFORCING FR PLR RH HILUX 05 ON 2 X R 730.00
8324289414GL REV COUNTER LN65 HILUX 1 X R 827.50
4260305738GL RIM CAP HILUX 2X4 (1984-1998) 3 X R 25.00
614130K020GL ROCKER PANEL OUTER RH HILUX 05 on 1 X R 545.00
614110K010GL ROCKER PANEL OUTER RH HILUX D4D 1 X R 595.00
6121135030GL ROOF SIDE RAIL NEW HILUX D/C RH 1 X R 322.50
6787235050GL RUBBER DOOR LH REAR D/C HIL N/S 1 X R 470.00
1756254110GL RUBBER EXHAUST FRONT HILUX LN65 2 X R 110.00
533830K010GL RUBBER WIPER COWL HILUX D4D 1 X R 75.00
2934164130GL SEAL ALTERNATOR FRONT 5L HILUX 5 X R 115.00
9056248001GI SEAL H/P STEERING BOX HILUX LN/YN/RN 2 X R 45.00
9031101254GL SEAL M80/82 HILUX SIDE SHAFT LOCAL 1 X R 8.75
2934164030GL SEAL VACUUM PUMP HILUX NEW 2LII5L 2 X R 105.00
3336426010GL SELECTOR SLEEVE HILUX 3RD/4TH 1 X R 400.00
3350135150GL SHAFT COLUMN SHIFT HILUX 4X2 1 X R 250.00
510830K050GL SIDE STEP RH HILUX D4D 1 X R 1 395.00
220196A511GI SOLENOID FUEL CUT HILUX 2 X R 745.00
9056027010GL SPACER SIDE SHAFT FRONT HILUX 2.7 12 X R 12.50
480460K020GL SPRING PLATE HILUX (06on) 6 X R 215.00
90507T0002GL SPRING TENSIONER BRAKE PEDAL HILUX D4D (2005-2011) 1 X R 15.00
521420K010GL STAY BUMPER FRONT LH HILUX 05 ON 1 X R 72.50
4561135130GL STEERING KNUCKLE ARM RH HILUX (98-05) 1 X R 597.50
694100K040GL STRIKER PLATE DOOR REAR HILUX/ FORTUNER D4D 2 X R 50.00
4867135030GL STRUT BAR HILUX 2X4 LH (CARTOR) 2 X R 575.00
1210167080GI SUMP 1KZ HILUX 1 X R 2 090.00
3533060050GL SUMP HILUX D4D AUTO 1 X R 332.50
8431028180GL SWITCH ASSY TURN SIGNAL HILUX 1 X R 787.50
8493014090GL SWITCH DOOR LOCK CNTRL HILUX 98-05 1 X R 147.50
3336830120GI SYNCHRO 3RZ 4TH 1 X R 240.00
6628005700GL TAILGATE CHAIN HILUX YN 2 X R 22.50
9091603121GL THERMOSTAT HILUX OLD SHAPE 1 X R 175.00
3123035061GI THRUST BEARING HILUX 3L/5L 2 X R 200.00
1356125010GL TIMING CHAIN GUIDE YN 1 X R 105.00
6793860050A0GL TRIM TAIL GATE LH HILUX D4D 1 X R 70.00
444160K010GL TUBE RETURN P/STEERING HILUX 05 ON 1 X R 70.00
90117T0002GL U BOLTS NEW HILUX 4 X R 80.00
5391135220GI VALANCE HILUX NEW 2X4 4 X R 817.50
5391135220GL VALANCE HILUX NEW 2X4 3 X R 817.50
160270L010GL WATER PIPE TURBO HILUX D4D 1 X R 75.00
6817335020GL WEATHERSTRIP REAR INNER NEW HILUX RH 1 X R 90.00
681640K010GL WEATHERSTRIP REAR OUTER LH HILUX D4D 1 X R 210.00
681630K010GL WEATHERSTRIP REAR OUTER RH HILUX D4D 1 X R 210.00
755310K010GL WINDSCREEN RUBBER HILUX 05ON 1 X R 170.00
852110K010GL WIPER ARM RH HILUX D4D 3 X R 222.50
851500K030GL WIPER LINK HILUX D4D 1 X R 615.00
851100K030GL WIPER MOTOR FRONT HILUX/FORTUNER D4D 1 X R 1 365.00
REPLACEMENT PARTS
2770057060RL ALTERNATOR REGULATOR 2L/2H 1 X R 227.50
4333039295RL BALL JOINT LOWER 4X2 HILUX 8 X R 120.00
4335039075RL BALL JOINT UPPER HILUX YN 2X4 6 X R 102.50
2191271021RL BASE PLATE CARB 4Y 3 X R 30.00
9036330032RL BEARING (OUTPUT SHAFT CENTRE ) HILUX 6 X R 110.00
1320554024RL BEARING BIG END 2L OLD 0.5MM 1 X R 162.50
1320354024RL BEARING BIG END 2L STD 3 X R 162.50
1304162030RI BEARING BIG END 5VZ STD 1 X R 227.50
9036531002RI BEARING HILUX COUNTER SHAFT CENTRE 5 X R 225.00
9036834001KRL BEARING KIT FRONT WHEEL HILUX 2X4 8 X R 80.00
9036804133KRL BEARING KIT REAR WHEEL HILUX LOCAL DIFF 3 X R 112.50
9039187702RL BEARING NR 2 ALTERNATOR HILUX 4.0 V6 2 X R 72.50
7322106910RL BELT SAFETY STALK LH UNIVERSAL 3 X R 72.50
7321106910RL BELT SAFETY STALK RH UNIVERSAL 3 X R 72.50
9010514069RL BOLT CRANK PULLEY 4Y 10 X R 47.50
5330135060RL BONNET HILUX 1.8/2.4/2.7/3.0 (1998-2002) 1 X R 1 920.00
5201189108RL BRACKET BUMPER FRONT RH HILUX LN 1 X R 30.00
4740530010RI BRAKE ADJUSTER HILUX RH RN46 1 X R 55.00
4740630010RI BRAKE ADJUSTER LH HILUX RN46 1 X R 55.00
4351205600RL BRAKE DISC HILUX 4X2 4 X R 417.50
4755005600RL BRAKE SLAVE CYL HILUX 4X2 13 X R 107.50
0447605600RL BRAKE SLAVE CYL KIT HILUX 4X2 OLD 1 X R 47.50
521190K021RL BUMPER FRONT HILUX 05on W/HOLE 1 X R 615.00
5211189140RL BUMPER FRONT HILUX YN 67 1 X R 390.00
5211106731RL BUMPER FRT O/S HILUX LOWER BLACK 1 X R 390.00
9038518046RI BUSH SHACKLE FRONT HILUX OLD (84-98) 177 X R 15.00
90385T0002RL BUSH SHACKLE SPRING HILUX (05on) LOWER 165 X R 7.50
90385T0001RI BUSH SHACKLE SPRING HILUX (05on) UPPER 71 X R 12.50
90385T0001RL BUSH SHACKLE SPRING HILUX (05ON) UPPER 202 X R 12.50
1351171901RL CAM SHAFT 2Y/3Y/4Y 10 X R 720.00
1350154020RL CAMSHAFT 2L2 4 X R 719.00
7539535040RL CLIP SPAT NEW HILUX (YELLOW) 13 X R 7.50
3147030260RL CLUTCH SLAVE CYL 4Y 17 X R 125.00
1116154070RL COMBUSTION CHAMBER 2L OLD 61 X R 107.50
1110654120RL COMBUSTION CHAMBER 3L 4 X R 107.50
1110654170RI COMBUSTION CHAMBER 5L 9 X R 150.00
4860635121RL CONTROL ARM LOWER LH 4X2 HILUX 3 X R 115.00
4860535121RL CONTROL ARM LOWER RH 4X2 HILUX 4 X R 120.00
8162045280RL CORNER LAMP LH HILUX IMPORT CHROME 2 X R 115.00
8162089147RL CORNER LAMP LH HILUX YN 4X2 BLACK (O/W) (86-94) 2 X R 55.00
8161189170RL CORNER LAMP RH HILUX YN 4X4 CHROME (B/W) (94-98) 3 X R 65.00
1340871010RL CRANK PULLY 4Y 4 X R 107.50
1341173010RL CRANK SHAFT 4Y 3 X R 282.50
430400K010RL CV JOINT INNER HILUX (2005-2011) 1 X R 295.00
1110104Y00CRI CYLINDER HEAD 4Y COMLETE 1 X R 4 500.00
1925163011RL DISTRIBUTOR 4Y MODULE 1 X R 150.00
1910171020RL DISTRIBUTOR CAP 4Y ELECTRONIC 4 X R 35.00
6700489160RL DOOR SHELL REAR LH OLD SHAPE HILUX 4 X R 1 500.00
670020K080RL DOOR SHELL S/C LH HILUX 2005ON 2 X R 1 500.00
670010K080RL DOOR SHELL S/C RH HILUX 2005ON 1 X R 1 500.00
1636144032RI FAN BLADE 4Y SOLID 7 X R 162.50
1111575031RI GASKET CYLINDER HEAD 3RZ 2.7 9 X R 330.00
0411154093RL GASKET SET 3L W/HEAD GASKET 6 X R 270.00
1121371020RI GASKET TAPPIT COVER 4Y 4 X R 150.00
6812289107RL GLASS 1/4 VENT HILUX YN LH 2 X R 77.50
4764220010RI GUIDE CABLE BRAKES HILUX YN 4X4 48 X R 12.50
9024908068RI HANDBRAKE LEVER SWIVEL PIN HILUX OLD YN 20 X R 10.00
1111573040RI HEAD GASKET 2Y 9 X R 107.50
HLP9557RL HEADLAMP PROTECTOR HILUX (2002 ON) 1 X R 75.00
8342016040RL HEAT SENDER 4Y 1 X R 30.00
9038618002RI IDLER ARM BUSH HILUX 2X4 19 X R 10.00
4549035130RL IDLER ARM HILUX YN 4X2 1 X R 390.00
2139172280RL IDLING JET 4Y 4 X R 47.50
4528035151RL IGNITION HOUSING HILUX YN 4X2 8 X R 227.50
1633171010RL INLET RADIATOR HOSE BOTTOM 4Y 2 X R 270.00
692060D080B3RL INNER OPENER FRONT LH HILUX D4D 1 X R 72.50
692060D080A0RL INNER OPENER FRONT LH HILUX D4D (BROWN) 2 X R 72.50
692050D080B3RL INNER OPENER FRONT RH HILUX D4D 1 X R 72.50
6975112030E1RL KNOB DOOR BUTTON HILUX (BROWN) (86-89) 5 X R 12.50
4760235020RL LEVER BRAKE ADJUSTER LH HILUX YN 4 X R 72.50
4760135020RL LEVER BRAKE ADJUSTER RH HILUX YN 9 X R 72.50
8970935250RL LOCK SET DOOR HILUX (98-05) 3 X R 235.00
3332135111RL MAINSHAFT HILUX 4X4 YN 2 X R 720.00
8791089122RL MIRROR HILUX 4X2 RH 1 X R 300.00
8794089124RL MIRROR LH HILUX 4X2 (84-98) 1 X R 227.50
1236154143RI MOUNTING ENGINE L (LN30) 1 X R 55.00
9017910051RL NUT MANIFOLD 4Y 14 X R 3.00
6921012260RL OUTER DOOR HANDLE FRNT/REAR LH/RH HILUX 05 ON 2 X R 85.00
1632171010RL OUTLET RADIATOR HOSE TOP 4Y 1 X R 330.00
1310354070KRL PISTON 2L2 KIT 0.50mm (020) 4 X R 810.00
1310354101RL PISTON 3L 0.5mm (020) 4 X R 227.50
131000045411RL PISTON 3L 1.0mm (040) 4 X R 270.00
131015412003RL PISTON 5L 040 4 X R 347.50
4745620010RI PLATE REAR BRAKE SHOE GUIDE HILUX 94 X R 12.50
164000C220RL RADIATOR HILUX (05on) 2.7 VVTI 3 X R 1 500.00
1640075260RL RADIATOR HILUX 3RZ 2.7 (98-05) 1 X R 990.00
4260305738RL RIM CAP HILUX 2X4 (1984-1998) 2 X R 20.00
1301135071RL RINGS 22R STD 1.5 1.5 4.0 1 X R 295.00
1301154100RL RINGS 2L STD 1 X R 227.50
1301454120RL RINGS 3L 1.0mm (040) 1 X R 295.00
1301154130RL RINGS 5L STD 1 X R 490.00
1390171010RL ROCKER SHAFT 4Y 1 X R 450.00
241850RL ROLLBAR HILUX (98-04) S/C STEEL 1 X R 1 500.00
9031148014RI SEAL 3RZ CRANK FRONT 7 X R 35.00
9031188003RI SEAL 3RZ CRANK REAR 18 X R 120.00
9031130010RI SEAL G/G HILUX SPIGGOT 2.7 4X4 20 X R 42.50
9031132015RI SEAL POWER STEERING BOX HILUX YN 20 X R 25.00
9031348001RI SEAL SIDE SHAFT REAR HILUX 15 X R 47.50
9031141007RL SEAL T/F HILUX OUTPUT REAR 4X4 2.7 1 X R 55.00
9031135040RI SEAL TIMING COVER HILUX 21 X R 47.50
4851105732RL SHOCK FRONT HILUX YN56 4X2 2 X R 595.00
4804735170RL SHOCK PLATE HILUX LH 1 X R 132.50
4804635170RL SHOCK PLATE HILUX RH 1 X R 132.50
RSE80712T-RL SLEEVE 2L 2 X R 95.00
RSM00706RI SLEEVE 5L 4 X R 95.00
9050605800RI SPRING BRAKE SHOE RETURN 4X2 HILUX 198 X R 12.50
9050418012RL SPRING STRUD BRAKE SHOES HILUX YN 4X4 37 X R 7.50
488200K010RL STABILISER LINK FRT LH/RH HILUX 4X2 05on 2 X R 107.50
9011610063RL STUD MANIFOLD 4Y 5 X R 1.50
9021009019RL TAPPIT SEAL 4Y 12 X R 12.50
3123060170RL THRUST BEARING 1KZ HILUX & PRADO 10 X R 142.50
3123035061RL THRUST BEARING HILUX 3L/5L 4 X R 120.00
1356859027VPRI TIMING BELT 2L (84-94) 6 X R 162.50
S12533303PRL V BELT 3RZ AIRCON 1 X R 30.00
1371554010RL VALVE EXHAUST 2L OLD 20 X R 42.50
1371575020RL VALVE EXHAUST 3RZ 4 X R 72.50
1112271020RL VALVE GUIDE 4Y INTAKE 16 X R 12.50
1371154010RL VALVE INTAKE 2L OLD 19 X R 42.50
1371175021RL VALVE INTAKE 3RZ 4 X R 105.00
1371154030RL VALVE INTAKE 5L 12 X R 42.50
9092504006RL VALVE NON RETURN 4Y CARB 1 X R 40.00
1220415022RL VALVE PC 4Y 2 X R 17.50
9091302072RL VALVE STEM SEAL HILUX YN (1988-1994) 9 X R 30.00
1621054070RI VISCO COUPLING 2L 8308-8808 5 X R 420.00
1621031010RL VISCO COUPLING 3Y/4Y 4 X R 390.00
2770013050RL VOLTAGE REGULATOR HILUX YN 1 X R 30.00
4135130060RI WASHER DIFF PINION HILUX LN/RN 43 X R 17.50
4135130051RI WASHER DIFF PINION HILUX LN/RN 38 X R 12.50
4136140021RL WASHER DIFF SIDE GEAR HILUX KZN/LN/RN 35 X R 17.50
9641143000RL WELCH PLUG 30mm 6 X R 3.00
5612189117RL WINDSCREEN RUBBER HILUX YN 3 X R 180.00
* Quantities on hand is subject to change
Prices excl VAT
Please contact our sales team at 012 545 0200
Cheetah Drakie
Town: Nelspruit
Vehicle: Toyota Hilux 2.7i
Real Name: Peter
Tue Apr 28, 2015 1:35 pm
Hi Marius,
The number on your website doesn't seem to be working. I am looking for a speedo cable for a 1999 2.7 Hilux. (3RZ-FE)
Regards
Peter
saan
Vehicle: 1995 Toyota hilux
Real Name: Ighsaan
Thu Sep 24, 2015 9:23 pm
Hi
Looking for a top end cluster for 95 SFA hilux box.
mcw
Town: krugersdorp
Vehicle: Prado 90 V6 3.4 Auto
Real Name: Martin
Club VHF Licence: X100
Sun Sep 27, 2015 10:35 pm
Hi saan
l have a stripped gearbox ifvyou are interested
mcw
Pete Brand
Town: Hartbeespoort Dam
Vehicle: GWM 2.2 - Toyota 4Y fuel injected motor
Real Name: Pete
Club VHF Licence: N/A
Wed Mar 29, 2017 4:12 pm
G'day
Please could
someone help me with the correct way to adjust the exhaust cam gear for cam chain replacement?
My appologies! Im little new to this, I have a Toyota Hilux 2.7 with the 3RZ motor!
Return to “Commercial Ads”
