Feite volgens wikipedia,
1UZ-FE
The 4.0 L (3,968 cc or 242.1 cu in) all-alloy 1UZ-FE debuted in 1989 in the first generation Lexus LS 400/Toyota Celsior and the engine was progressively released across a number of other models in the Toyota/Lexus range. The engine is oversquare by design, with a bore size of 87.5 mm (3.44 in) and stroke of 82.5 mm (3.25 in).[1] It has proved to be a strong, reliable and smooth powerplant with features such as 6-bolt main bearings and belt-driven quad-camshafts. The water pump is also driven by the cam belt. The connecting rods and crankshaft are constructed of steel. The pistons are hypereutectic.
Its resemblance to a race engine platform (6 bolt cross mains and over square configuration) was confirmed in 2007 by David Currier (in an interview with v-eight.com), vice president of TRD USA, stating that the 1UZ platform was based on CART/IRL engine design. It was planned to be used on GT500 vehicles, however its subsequent use in the Daytona Prototype use was not planned.
In its standard, original trim with 10:1 compression, power output is 191 kW (256 hp), torque of 353 N·m (260 lb·ft).[1]
1UZ-FE
The engine was slightly revised in 1995 with lighter connecting rods and pistons and an increased compression ratio to 10.4:1 resulting in peak power of 195 kW (261 hp) and torque of 363 N·m (268 lb·ft).
In 1997, Toyota's VVT-i variable valve timing technology was introduced along with a further compression ratio increase to 10.5:1,[1] bumping power and torque to 216 kW (290 hp) and 407 N·m (300 lb·ft). In the GS400 application, output was rated at 300 hp and 310 lb·ft of torque.
The 1UZ-FE was voted to the Ward's 10 Best Engines list for 1998 through 2000.[2][3][4]
Interessante feite Lexus V8
- Lappe
- Town: Groot Marico posbus 02 2850
- Vehicle: hilux v8 Lexus
- Real Name: george
Hiding doesn't stop evil, Return fire does
- Town: keetmanshoop
- Vehicle: toyota , land rover
- Real Name: willem
- Club VHF Licence: no
Re: Interessante feite Lexus V8
En julle sit hom in 'n hilux, hy hoort eerder in jou merzedes ! Hehe
- hilex08
- Town: Springs
- Vehicle: Hilex V8, Ford Ranger 2500 td, C55 AMG
- Real Name: Hennie
Geen wonder ek ry al die Golfies en BM's weg.....
- Lappe
- Real Name: george
Dan twyfel die ouens nog, wat om in hulle Hilux te sit.
Kan dit net nie verstaan nie.
