Towing a ski boat and overlanding- What to choose?
- Town: Epsom
- Vehicle: 1988 Hilux 4wd Single cab. 2007 DC 4.0l V6
- Real Name: Martin
Hi Guys
I am sitting in the UK and in the process of retiring the '88 SFA, single cab, 2.2 petrol to Mozambique. I travel regularly to our place in Moz and need to keep a vehicle in Nelspruit for this purpose. The vehicle needs to be:
1. Reliable, simple and safe for the ghastly Moxambique roads
2. Be able to tow a 21ft ski boat and launch it in deep, soft sand
3. Be able to transport passengers and be adapted for the occassional overlanding trip
I have managed all of the above with the Hilux until now, but as tough as it is, it cannot satisfy all the criteria. I figure that I need a decently powered DC or SW, in manual that relies on the minimal amount of electronic wizardry. I, of course considered the 3.0 D4D vehicles, until I read about the problems of varying qualities of diesel in southern Africa. Then I considered the V6 petrol Hilux or Fortuna, only to find that all the later models are auto! The Land Cruiser 4.5l DC conversion was a possibility, but it would take a brave man to drive through Mozambique regularly without airbags. This leaves me with the choice of a +/- 2008 V6 Hilux DC/Fortuna or a 2006 LC 100 GX 4.5l EFI as far as I can establish. My budget can extend to approximately 350 000 and I had honestly thought that I would have a range of later model vehicles to choose from that were not unmanageably heavy on fuel. As it turns out I have very few vehicles to choose from and they all seem to have had multiple or, worse, an unknown number of previous owners and poor service histories.
Am I missing a trick here guys? Are the stories of 500ppm diesel vs 50ppm overhyped? I am at my wits end and desperately need the input of my learned fellow club members.
All advice much appreciated.
Martin
Martin
- george
- Town: Velddrif
- Vehicle: Triton 3.5l V6
- Club VHF Licence: HC107
Re: Towing a ski boat and overlanding- What to choose?
Hi Martin.
i would seriously consider a diesel.Petrol is just so expensive in Moz.The D4D should be excellent for your aplication. Just put an extra racor filter in.My2C
- Jaco Versfeld
- Town: Western Cape
- Real Name: Jaco
- Club VHF Licence: X69
What about a Prado? Why do you exclude automatic gearboxes? I think the auto will make towing quite easy, and an auto in sand is only a pleasure.
You can get a decent Prado in the range of R250 k, and then could use the other R100k for petrol
Trigg's broom wrote:Hi Guys
Martin
- Town: Epsom
- Real Name: Martin
Thanks Jaco, I have considered the Prado, but I don't really know the vehicle. I am very much a man who likes to manually lock hubs, engage low range, lock diffs etc. I was under the impression the Prado does all of that for you and if the system fails while in the boonies......
My worry with the auto transmission is the extrememly difficult, steep beach launch/retrieval I have to contend with. I am constantly "feathering" the clutch to prevent getting bogged down. With an auto does one just engage DRIVE and cruise out?
George, if it is as easy as fitiing an extra filter, then the world is my oyster. Excuse my ignorance, but I assume the filter deals with the 500ppm diesel and thus saves the injectors. Is it as simple as that?
- Town: nelspruit
- Vehicle: d4d d/c
- Real Name: digby
martin,buy yourself an 80/100 series vx in moz(jap import+15/30k US)you wil never look back
- Jaco Versfeld
- Real Name: Jaco
The only problem I have with auto's is to drive down very steep declines, and hopefully someone can share a few tips on that. With a manual, you put it in low range first, and feather the brakes when needed. My wife's Prado has a L option on the auto, but with low range selected, it is still way to fast for me - or I need to practice a bit more.
I am quite impressed with the Prado. The "hubs" are permanently locked, but you have a center diff that you lock with a gear when you select high range or low range. This is quite manual, and not much that can go wrong when down in the boonies. I once was a passenger in a double cab 4x4 of another make, where you select 4wd with a switch. Yes, and that day the electronics did let us down, and we couldn't do the trail as we could not select 4x4. So yes, I share your concern, but in my opinion the Prado has a much smaller probability to give you hassles, since the center diff is still selected manually.
Trigg's broom wrote:Thanks Jaco, I have considered the Prado, but I don't really know the vehicle. I am very much a man who likes to manually lock hubs, engage low range, lock diffs etc. I was under the impression the Prado does all of that for you and if the system fails while in the boonies......
- Town: Epsom
- Real Name: Martin
Digby, just when I am reconsidering the D4D instead of the LC, a D4D owner suggests the LC! I see you are from Nelspruit; have you, or do you know of anyone who has, bought a Moz vehicle and imported it into SA? Unfortunately the new vehicle is to stay in Nelspruit for transport to our site. The Hilux SFA will stand on site in Moz.
Jaco, your endorsement will definitely have me checking the used Prado ads. Thanks for the prompt advice.
- Town: nelspruit
- Vehicle: d4d d/c
- Real Name: digby
martin,no you cant import to sa from moz(not that I know of)hard to find a better towing/overlanding vehicle better than 80/100 series cruisers,luv my d4 but not in the same league(probably get stoned for this )had 80 gx/vx's prior to the lux and changed to the dble cab for other reasons.trust me ,if you're going to tow a heavy boat,get a cruiser,station wagon not a pickup, my 2 cents
But I guess if you have an address in Moz you can register it in Moz and use it in SA
If you pay that little for a Cruiser the fuel consumption does not matter
- Town: Epsom
- Real Name: Martin
I think you are stuck with a Temporary Import Permit for only 30 days each time you bring it into SA, in much the same way as when you take your SA vehicle into Moz.
Ok, time for a cat amongst the pigeons:
Consider a Nissan Patrol 4.8GL(manual) or GRX(Tiptronic)
For the same year as the Cruiser you will find it either R100k cheaper or 100k km less or, if you are patient, both!
Both the Patrol and Cruiser will not easily give you more than 5km/l.
Oh, and the Patrol has 190kw vs 165...and bulletproof diffs, gearbox, etc. Also way less prone to get stolen/highjacked! Cruisers and especially Hilux'e and Fortuners get nicked quite often, especially so close to the border...
- Town: Epsom
- Real Name: Martin
The Patrol has a huge reputation in Australia and Zimbabwe. Are there many available in SA's used car market? I will start trawling.
Unfortunately the Patrol does not have a huge following in SA, but there are a few for sale. Take your time and shop around!
