vibration hilux 4x4
- Town: cape town
- Vehicle: hilux 4.0 4x4
- Real Name: david
vibration hilux 4x4
Hi all after fitting a level it kit in the front of my 2008 hilux I now feel vibration between 50 and 60 I can feel it more in the floor than in the sterring wheel , also at 80 the bakkie starts to bounce then clears around 90 does anyone know of this?
- Real Name: Etienne
- Club VHF Licence: Etman
Re: vibration hilux 4x4
Try to loosen the propshaft while vehicle is on the ground so that it can middle the center bearing again. Happen to me, done that and problem went away.
Did you use a 20mm or 30mm kit? Did you have the alignment done after the install?
- Town: cape town
- Real Name: david
Where do I loosen the prop ? At both ends or just one end ? I fitted the 30mm which gave me a 50mm lift
- Town: cape town
- Real Name: david
Hi Piet I fitted the 30mm at supaquick beleville and yes they did alignment and new shockspietpetoors wrote:Did you use a 20mm or 30mm kit? Did you have the alignment done after the install?
