Hi
I have a 2004 Hilux 3.0KZTE D/Cab 4x4.
Does anyone know of a good mechanic in the Durban area that knows these vehicles and can look for the problems that I am having with my vehicle?
Good KZTE Mechanic in Durban
- Town: Durban
- Vehicle: 2009 Fortuner 3.0D4D 4x4
- Real Name: John Hollow
- Oupa Stig
- Town: Johannesbug
- Real Name: Mickey
Re: Good KZTE Mechanic in Durban
John, if you specify your hassles on this forum, the guys might be able to give you some pointers as to what to look out for if and when you find your mechanic. Lots of knowledge floating around here....
- Town: Durban
Hi
I am not very mechanically minded.
I have a vibration at 80 - 100kmh which seems to turn into a loud hum at higher speeds. Also when going over speed humps or rough ground front suspension is very noisy. Also the engine seems very rough when idleing.
- Oupa Stig
- Town: Johannesbug
- Real Name: Mickey
Hang in there, answers, suggestions will be coming in...
Shocks, wheel balancing O.K.?
When was last service?
Fresh oil makes a difference, unless it's something more serious. Not very clued up myself either, which is why I joined the forum! :)
- Town: Durban
- Vehicle: hilux 4x4 KZTE
- Real Name: John
Had similar problems, check propshaft universal bearings and rubbers, especially rear.
engine rough idle, buggered if I know, I have the same problem,fuel pump refurbished and recalibrated, electronics diagnostic checked, possible touching of exhaust checked, engine mountings replaced, gearbox mountings replaced still rough. Has not seemed to affect performance at all so living with it until further notice :?
Front suspension the stabilizer bar arms have a washer and rubber affair going through the control arms, the washers often get punched through leaving the stabilizer floating and making a horrible racket, I replaced the washers with turned thicker units and no more hassles.
Check front stabilizer bar bushings as well
Truck now on 490 thousand Km and going strong.
- Town: Durban
- Vehicle: Hilux 3.0D4D 4x4 A/T
- Real Name: Rajeev
Hi.. I know I may be late with the reply, but go and see Daya's auto repairs..
He is a toyota specialist, he is very good.. I trust him with all my cars, he is well versed with the kzte, he has a Hilux as well..
His number is 031 5643009.
He is closed for the holidays, he reopens of the 5th..
Tell him Rajeev referred you.
2016 Hilux D/Cab 2.8 GD6 4x4 A/T
2014 Auris 1.6 XR
1994 Supra RZ Twin Turbo 6 speed
2015 Hilux D/Cab 3.0 D4d 4x4 L45 A/T - (EX)
2014 Hilux D/Cab 3.0 D4d 4x4 Raider Auto - (EX)
2013 Hilux D/Cab 3.0 D4d 4x4 Raider - (EX)
2013 Corolla 1.6 Sprinter - (EX)
2012 Corolla 1.6 Sprinter - (EX)
2009 Corolla 1.8 Exclusive - (EX)
2002 Corolla RXi 20V - (EX)
2008 Auris 2.0 D4D RX (EX)
2007 Lexus IS250 (EX)
2014 Auris 1.6 XR
