Sticky windows
pampoen
Town: Gordons Bay
Real Name: Luke
Sticky windows
Post by pampoen »
Hi guys,
Is there any way to get my windows to wind up and down smoothly without it catching? I have this issue with all 4 of them.What do you guys do to get them to wind down without working out for a week.
Another question I read an awesome article years ago where I think it was MRb that replaced his outer door seals with aftermarket ones. Would LOVE to read that article again, I might even do an update on it.
Once again, thanks in advance! :thumbup:
mossie89
Town: Paarl
Vehicle: Toyota Hilux D/C 4x4 4.0 v6
Real Name: Riaan
Re: Sticky windows
Post by mossie89 »
Try to spray your window traks and rubbers with silicone spray, it worked on mine
The Legend
Real Name: Dawie
Club VHF Licence: X93-
Re: Sticky windows
Post by The Legend »
mossie89 wrote: Sat Aug 19, 2017 2:01 pm Try to spray your window traks and rubbers with silicone spray, it worked on mine
:thumbup: or graphite powder
Re: Sticky windows
My experience with silicone is that it works for a short while and then becomes sticky again, especially in damp weather. The graphite powder is a better option, but there again it's not a long term solution because the graphite slowly dissipates. However, it's almost impossible to remove the silicone which then remains as a permanent problem whereas graphite you just reapply when ever necessary. :winkx:
pampoen
Town: Gordons Bay
Real Name: Luke
Re: Sticky windows
Post by pampoen »
tnks guys. Graphite powder it is!
Lorry
Town: durban
Vehicle: D4D hilux DC $X$
Real Name: Lorenzo
Re: Sticky windows
Post by Lorry »
Just some info. My drivers window starting sticking and got worse and worse then one day I heard a clunk when I tried to wind my window down. After a lot of swearing and stripping the door panel, it tuned out that the spot weld sheared on the link arm from the motor to window slide mech. after a new weld all was in order, I use silicon spray now and it works like a charm, I also clean and check the seals that they are clean now. This causes less swearing on my part :)
