ARE BOSCH BRAKE PADS GOOD
- Alex2539
- Town: Walvis Bay
- Vehicle: HILUX LEGEND 45 V6 4.0 4X4
- Real Name: Alex
Hi there!
my brake pads are on the way out, Toyota quoted me R1800, Bosch R 400. so much price difference, how are bosch brake pads ? i have never used them before.. what can you recommend?
Bonded to Yotas
- Cinco
- Town: Marloth Park
- Vehicle: Hilux Vigo
- Real Name: Ian
- Club VHF Licence: HC243
Re: ARE BOSCH BRAKE PADS GOOD
If genuine Bosch yes. Make sure they are not knock offs.
Wishing my life away till the next trip!
- Alex2539
- Town: Walvis Bay
- Real Name: Alex
Will make sure, thanksCinco wrote:If genuine Bosch yes. Make sure they are not knock offs.
Bonded to Yotas
- Nick S
- Town: Bedfordview
- Vehicle: 3L Legend 45 D4D 4x4 DC/AT. RSI Canopy, Snorkel and Radio
- Real Name: Nick
- Club VHF Licence: HC219
Hi
I put Bosch on my lux.
Good news is that it stops, bad news is that they are very dusty.
But I can pay for a wash with the money that I saved by not letting Toyota do it.
To build bridges, you need to go to where the rivers are.
- Alex2539
- Town: Walvis Bay
- Real Name: Alex
thanks NickNick S wrote:Hi
Bonded to Yotas
I like the Bosch Pads as they are quite soft. This means a little more dust and they will not last as long. The benefit is that they stop well and do not unduly wear the brake disks.
- Alex2539
- Town: Walvis Bay
- Real Name: Alex
Ended up buying them, i must say i am quite satisfiedMars wrote:I like the Bosch Pads as they are quite soft. This means a little more dust and they will not last as long. The benefit is that they stop well and do not unduly wear the brake disks.
Bonded to Yotas
- Town: jhb
- Vehicle: hilux
- Real Name: ebrahim
Hi guys
Would warranty be affected if we replace pads elsewhere
Like you mentioned, Toyota is pricey on parts and labour!
No it will most definitely not affect your warranty.
- Real Name: Mark
Are there a lot of Bosch pads knockoffs going around? How do you tell the difference?Cinco wrote: ↑Thu Apr 19, 2018 6:27 pm If genuine Bosch yes. Make sure they check out weight loss shakes here and are not knock offs.
mmmmm, my 1999 Hilux's brakes are always screeming. Was worst with Feredos and still there with ATE.
Maybe I should try these softies and see if it solve the screeming problem.
Definitely worth a try although the ATEs are also quite soft in my experience.
Unfortunately I have no idea. I suppose the best way is to look at the packaging. With knockoffs they always skimp on the packaging. On the pads one should look at things like and anti-vibrating damping material (Does it appear of a good quality if there is any on), the composition of the friction material (Is it consistent in composition or does it contain shards of copper/metal that clearly looks rough) and the overall finish of the product such as the painting and the lettering.
Check out this video on how to check if Bosch Parts are genuine. https://www.youtube.com/watch?v=QrRqEP9Ugx8
Even if not following the process in the video you at least know to check for the secure key code on the Bosch part.
Surely the rip-off artists will have a legitimate product code on the packaging as well .......
It may be. I have to say that I have not had an issue with buying pirate Bosch brake pads.
- Vehicle: Toyota Hilux 4x4
- Real Name: JAMES
Buy a bottle of disc brake quiet, and apply it per the directions. PRESTO!! No more squealing.pietpetoors wrote: ↑Thu May 09, 2019 9:33 pm mmmmm, my 1999 Hilux's brakes are always screeming. Was worst with Feredos and still there with ATE.
- JAMES
