Brakkenjan's change from Ordinary to Custom
Bulletjie-3
Vehicle: Hilux Raider SFA met 7M-GE engine
Real Name: Everdt
Re: Brakkenjan's change from Ordinary to Custom
Post by Bulletjie-3 »
Op[ die foto waar die looms ingetrek is wys die gearlevers en links van hulle is die boksie.
JohanM
Town: Meyerton
Vehicle: Prado 120 4.0 V6
Club VHF Licence: HC126
Post by JohanM »
Everdt,
Daai is my power outlets op die floor console maar daai sal ook nog oor gedoen word.
Bulletjie-3
Real Name: Everdt
Ek het so geraai maar was nie seker nie. Jou wa is behoorlik toegerus ne ? Gerieflik.
JohanM
Town: Meyerton
Post by JohanM »
Bulletjie-3 wrote:Ek het so geraai maar was nie seker nie. Jou wa is behoorlik toegerus ne ? Gerieflik.
Dankie Everdt, maar daar is nog plek vir baie verbetrings!! Ek is amper nou klaar met alles, maar dit gaan nog so rukkie wees voordat als klaar is, dan sal ek sê hy is behoorlik toegerus. :thumbup:
JohanM
Town: Meyerton
Post by JohanM »
Here is a few pictures of the latest changes and progress on my SFA.
The engine bay wiring is done, taped up and routed. Dual battery system is connected. Lights is replaced with new H4 Hella light inserts. The VHF radio wiring is pulled through. Also the NL monitor is routed into the cab. The Aerial is fitted tn the cable is pulled through. Still need to route it into the headlining but that to be done once the rest is done. Also the left side of the dash is completed.
Here is some pictures.
Here is the aerial mounted outside.
(37.52 KiB) Downloaded 664 times
Inside where it still needs to go into the roof lining
(45.31 KiB) Downloaded 664 times
The new look inside the bonnet..
(60.44 KiB) Downloaded 664 times
The Interior so far...
(46.63 KiB) Downloaded 664 times
The lights. Old Vs new. taken on brights without the spotlights in daylight. Bith lights are running no extra relays, only Osram nightbreakers and decent wiring.
Left side is new, old one is 23 years old.
(52.79 KiB) Downloaded 664 times
Both lights new lenses on brights.
(55.59 KiB) Downloaded 664 times
Donkey
Club VHF Licence: X122
Post by Donkey »
So far so good, well done, pity we won't catch up at the GTG
Tumelo Maketekete
The Legend
Real Name: Dawie
Club VHF Licence: X93-
Post by The Legend »
Stadig maar seker kom jy klaar-Stuk werk om op trots te wees.Well Done Johan :thumbup:
JohanM
Town: Meyerton
Post by JohanM »
Baie dankie Dawie, ja dit vat ook al heelwat langer as wat ek aanvanklik beplan het, maar dit kom stadig aan!!!
Thumelo, it won't be ready in time to use and also got some time issues that needs to be dealt with as a priority. We will catch up at a later stage!!! :thumbup:
JohanM
Town: Meyerton
Post by JohanM »
So I dummy fitted the instrumentation cluster, and connected up all wiring after fitting the alarm system again in place. It started first time without any hassles and everything was working 100% as it should be.
So I started to tidy up the last wiring, and also refitted all the last bits in place. Then made a bracket and mounted the Kenwood VHF radio in the roof.
Also I routed the aerial through the side panel into the headliner and just spread the cable out nicely so that it doesn't overlap.
I fiited to low level cabin/reading/navigation lights to the inside of the cab. I mounted them low down as I dont like the blinding light from the overhead console's that is currently available.
Here is some last pictures of the instalation. Next up will be the door pockets and centre console...
(56.08 KiB) Downloaded 630 times
(58.49 KiB) Downloaded 630 times
Thunder02
Town: East Rand
Vehicle: IFS Hilux
Real Name: Neil
Club VHF Licence: HC105
Post by Thunder02 »
Johan,she is looking great :thumbup:
Scout motto:be prepared....
www.4x4direct.co.za
Post by Family_Dog »
Nice work, Johan. Have you thought about spraying the TK7160 heatsink black?
JohanM
Town: Meyerton
Post by JohanM »
Thunder02 wrote:Johan,she is looking great :thumbup:
Niel, thanks a lot, its been a long time working to finish itup to this stage.
Family_Dog wrote:Nice work, Johan. Have you thought about spraying the TK7160 heatsink black? -F_D
Eric, No I havent thought about it, but it is sitting so high in the roof that I like the alu finished look. Also nothing else is going to be added up here as all the important things are fitted down at normal dash height.
I still need to pop around to klerkies to bring my truck so you can inspect my arial connection that I made to see if it is correct as I did it according to the info on the forum, but cannot test it as there is no one in my town that is also a member with a vhf radio.... :oops:
Be careful.... I have a habit of keeping things that come to Klerksdorp if i like them. Will post a pic a bit later of what is currently in my yard... ;)
Here is proof of "what followed me home"...
Danman
Vehicle: 2009 Fortuner 4.0 V6 aka "BosBuffel"
Real Name: Danie
Post by Danman »
Nee man Oom Eric,
Die mense hier by die werk dink ek het hondsdolheid soos ek sit en kwyl.
As ek vandag in die hospitaal opeindig is dit Oom se skuld.
Toe maar Danie, hy's nou weg!
The owner collected it again today. I tried to convince him I still needed it for 6 months to ensure that his radio really worked as we promised him, I even asked him to fill both tanks 'cos I needed to try it in 29MHz AM world, daar onder in die Kaap. But he mumbled something about it being his livelihood (he is a tour operator). Oh well, it was good while it lasted :)
JohanM
Town: Meyerton
Post by JohanM »
Very nice Eric, I hope you enjoyed it while it lasted. Those diesel motors are a treat in their own way to drive. :thumbup: :thumbup: :thumbup:
So today I decided to clean my truck after 3 months of being tresseled up in the air. Then as I went about cleaning it, I decided to see what improvement I got after sorting the charging circuits out. So I started it up, let it idle for 5 minutes to let the national luna solenoid kick in so that both batteries gets charged. The main battery was almost full, and the deepcycle was @ 75% on the monitor. I turned on the radio, switched on all the lights and the spotlights, the aircon was also switched on and the doors were left open....
I got my Fluke meter out, and tested 14.2V on the front & rear battery. No load charge front & back is 14.5V.
I was so happy that I decided to do the front door pockets this afternoon. I set about starting to size up the plywood to be used, when I had a small accident. :oops: :oops:
This was the outcome of it, so now I cannot finish the project until its healed, and also im having to type with 1.5 hands at most, mainly now only one hand.
So till next weekend when I should be hopefully able to finish it the Lux will rest clean in the garage.
The Legend
Real Name: Dawie
Eina Johan,Dit kan nie lekker wees nie.Net bly vir jou part dat jy nie n vinger verloor het nie.
Ouch Johan, I feel your pain!!
JohanM
Town: Meyerton
Post by JohanM »
Dawie, ja darem net die nael geshatter en die nealbed se weefsel is beskadig, maar dit sal weer mooi herstel volgens die dokter. Eric, yes the pain is not your average type, but then its not really that bad either.
Some of the things that I have bought myself for the Lux and just to make travelling more interesting, is a Lunar Telescope which I can use to view both land, stars and the moon.... Also bought a Celestron digital hikers compass/altimeter which is now mounted to the dash of my Hilux. It gives me barometric pressure, maximum altitude, current altitude, temperature outside, compass reading with digital display and also it has a weather forecast function.
Below is a picture of a similar telescope as the One I bought... Now I need to make a special carrycase with foam padding for it, to be able to transport it in my SFA...
Im sure this combined with a star gazer map will be able to supply me with hours of night time solitude in the bush while looking up the galaxy.....
Thunder02
Town: East Rand
Vehicle: IFS Hilux
Real Name: Neil
Post by Thunder02 »
I like the idea of the telescope permanently in the hilux,hope your finger heals real soon so you can get her back on the road :thumbup:
www.4x4direct.co.za
JohanM
Town: Meyerton
Post by JohanM »
The end of the road is nearing with all the mods getting done one at a time. The finger is almost completely healed, but the nail will still take time to regrow.
However, I carried on with the mods. I bought a small work lamp from Pieter, and made it my new worklight fitted to the back of my Truck. I still need to wire it onto the reverse light circuit, but that will get done this weekend. Here is pictures, please excuse the quality as it was taken with my phone's camera.
The remaining list of mods is not that long, but it is getting more and more expensive. Custom built long range tank, Custom made towbar with special carriers for the HL jack and things, Winch to be fitted and hopefully a LED light bar or two.
December will be my time to finish all the little projects. So next year I will upload the new pictures of all the adjustments I have made and some more of the full setup in action.
(43.62 KiB) Downloaded 486 times
The LED worklight upclose
THe way it looks from behind now.
Post by CasKru »
Jou projek kom nou lekker aan
JohanM
Town: Meyerton
Post by JohanM »
Dankie Cassie, ja dit is lekker om die vordering sover te kan sien en geniet. Binnekort sal ek weer kan kamp met alles netjies georden op hulle plekke. Maar die organisasie en dinge sal julle eers volgende jaar mag sien.
4x4Maniac
Vehicle: 2011 Jeep Wrangler Rubicon Unlimited (JKU) 3.8 Auto
Real Name: Werner
Club VHF Licence: X120
Post by 4x4Maniac »
Johan hopenlik gaan ons jou trokkie nou sien met al daai mods met die volgende GTG.
ORRA CALLSIGN X120
AKA Epsilon on 4x4Community
(2011 JKUR)
Rugged Ridge Light Guards
KC Spotlights
Previous:
Racer-X
Town: Port Elizabeth
Vehicle: none
Real Name: Julien
Post by Racer-X »
Any updates?
JohanM
Town: Meyerton
Post by JohanM »
Racer-X wrote:Any updates?
Indeed yes a lot but then again just havent had the time either. to read a lot or do a lot....
My truck has been modified to have the 81L IFS tank fit instead of the SFA 65L tank. Its a tedious project with lots of things to be changed and fabricated, but now my SFA runs quietly with the pump in the tank. Also I fitted a Corolla fuel filter that had the screw in fittings and a banjo fitting the other side. Now it is a solid fuel line running to the fuel rail and with enough movement to allow full engine tilting without pulling or twisitng the pipe.
Also I redid the complete packing system in the back as the one shown previously was made to be finished for a short trip. This time I strenghtened the frame, made my own sildes for the drawers, partioned them and made everything fit properly and securely. I have converted a old unused picknick back pack to be the new cutlery bag for cups, plates, mugs and the needed things. The drawers now boasts more packing space and also provide some better and faster loading unloading times as things all fit togtether one way only. The battery recieved its own enclosure, with additional storage space in which I pack the shower pump and a small hair dryer for the lady if needed. Also the inverter was mounted and is now used more often. Spare wheel has been moved to a central location as it promotes better access through all the side doors and frees up quite a lot of space in the side and when fully packed everything is just neatly in its place.
Also modified the towbar at the back, shortened the lower side tubes, fitted recovery points to the back, strengthened the mounting brackets, put hi lift jacking points on in the front and rear. Now I can lift the vehicle safely or recover another vehicle.
Next up from here will be to lighten the shower cubicle with alum tubes in stead of brass, make two swing arms for the towbar to fit the gas bottle, spade, hilift jack and a tube holder to hold long pipes within easy reach.
Also a 140/160 watt solar setup is under way to power the fridge all day when parked and to provide for power needed. The fuel tank is in development and will be fitted soon in the back making capacity 200L on board when going far away from tracks.
And last will be a Sat phone mounted in the vehicle as well as a winch as we travel often solo vehicle into very remote locations.
Time for some pictures now... :thumbup: :thumbup:
JohanM
Town: Meyerton
Post by JohanM »
Pictures of the fuel tank brackets being modified for the ifs tank
(64.68 KiB) Downloaded 156 times
(67.93 KiB) Downloaded 156 times
(47.78 KiB) Downloaded 156 times
Fuel filter location and mounting
(67.56 KiB) Downloaded 156 times
JohanM
Town: Meyerton
Post by JohanM »
Size matters.... :thumbup: :thumbup: Difference in size between the two tanks.
(73.12 KiB) Downloaded 156 times
Looking under the chassis its lower but not noticable in normal off road conditions.
(86.25 KiB) Downloaded 156 times
Made a permanent mount for the GPS that cannot come loose in dusty or bad corrugated roads. Got tired of the Nuvi heading south after a dusty drive and hitting a slight bump...
(204.79 KiB) Downloaded 156 times
(138.06 KiB) Downloaded 156 times
JohanM
Town: Meyerton
Post by JohanM »
Fitted the door pockets and they work really brilliant, should have done it a long time ago.
(201.41 KiB) Downloaded 155 times
Pictures of the towbar shortened, also now showing my radio call sign on the front and back. :thumbup:
Front
(262.58 KiB) Downloaded 155 times
Rear
(249.75 KiB) Downloaded 155 times
Rear recovery points
(188.15 KiB) Downloaded 155 times
Jacking points
(188.64 KiB) Downloaded 155 times
JohanM
Town: Meyerton
Post by JohanM »
The packing system:
Kitchen side.
(147.58 KiB) Downloaded 142 times
The equipment side
(164.96 KiB) Downloaded 142 times
Invertor mounted
(156.98 KiB) Downloaded 142 times
Batterybox inside
JohanM
Town: Meyerton
Post by JohanM »
The last pictures, inside from the sides and closed up
(199.71 KiB) Downloaded 142 times
(216.15 KiB) Downloaded 142 times
(219.95 KiB) Downloaded 142 times
Side view loaded with about 50% capacity.
(113.62 KiB) Downloaded 142 times
Bulletjie-3
Real Name: Everdt
Dis een mooi van daardie !!!
Oetie
Vehicle: Nissan Pathfinder 2.5cDi 4x4 auto
Real Name: Leon
Club VHF Licence: X255
Post by Oetie »
Nice rig Johan!!
One life, live it to the fullest!!
ORRA - X255
Clubs: Hilux 4x4; Nissan-Offroad; 4x4AG
The Legend
Real Name: Dawie
Baie netjies Johan en daar is nog hope pak plek oor. :thumbup:
Looking very good, Johan! So when are you moving to Klerksdorp so that we can incorporate some ideas into Bulldog...!! ;)
Hangover
Town: Deneysville
Real Name: Stef
Post by Hangover »
Johan
Waar het jy daai laaaaang drawer systeem lat maak of gekoop? Ek soek so lang een vir my Xtra cab... Myne moet net van daai plastic ammo kratte vat...
Hangover(A.K.A die speelding)
1976 FJ45 4x4
1UZ-FE 4.0vvti
2" OME Suspension lift
1.5" Shackle lift
35" Geo MT's
Custom Bullbar
Lockright Locked rear
York OBA
20" LED bar
Nighthawk 100W spots
Dakar
2013 3.0D-4D 4x4 Hilux Dakar
JohanM
Town: Meyerton
Post by JohanM »
Thank you guys for the positive feedback...
Lollie wrote:Baie netjies Johan en daar is nog hope pak plek oor. :thumbup:
Dawie baie dankie dit was bloed sweet en kleur volle taal ten tyne maar eks baie tevrede. Ek sal eendag bietjie nog alles inpak en fotos neem en dan weer alles uitpak en afneem sodat jy kan sien wat steek ek als weg daar binne.
Family_Dog wrote:Looking very good, Johan! So when are you moving to Klerksdorp so that we can incorporate some ideas into Bulldog...!! ;)
Uncle for this to be done we will have to move bulldog here into the workshop where magic sometimes happen!!!
Hangover wrote:Johan
Ek het hom self gemaak, my laaie is 1150mm lank buite maat. Als daarso is self gemaakte planne. Net die komponente gekoop en self gemaak.
Froll
Town: Vioolsdrift
Real Name: Roger
Club VHF Licence: N/A
Post by Froll »
Looks like a very good job done, very neat. :thumbup: :thumbup:
