Hi,
Does any one have a pipe diagram for all the vacuum pipes on the 3YE intake to the motor and all other bits and pieces? Using a dicktator setup with dual pickup mag adapted dissy.
After having been confused with the woring, and rereading all the EFI posts, I got that going, but cant find anything about the piping, and since the manifold missed quite a few, I'm not too sure what has to be and what not.
Please help!
Freddy
4y EFI vacuum plumbing
Re: 4y EFI vacuum plumbing
Hi Freddy, there's only 1 vacuum pipe required from the plenum chamber to the Dicktator EMU. The rest of the open vacuum ports on the plenum chamber can be blanked off. The cold start injector can also be removed and the hole plugged. Where is CT do you stay? I may be able to assist you as I've done a few of these conversions before.
- Vehicle: '85 SFA Hilux D/C Import
- Real Name: Freddy
Hi,
I sent you a PM.
I sent you a PM.
