Boost pressures
invlhvn
Town: hobart
Vehicle: 1986 hilux
Real Name: cory
Boost pressures
Post by invlhvn »
Was wondering what's the most boost you can run in a (2l)2.4 diesel and what is standard ?
Vlak vark
Town: Phalaborwa
Re: Boost pressures
Post by Vlak vark »
Hi Cory.
I don't know about the 2.4 but 1kzte is normal boost is around 0.45 bar
and can go up to 0.75 bar.
I'm currently running mine on 0.7 bar with no problems.
I'm sure the boost are not far apart.
invlhvn
Town: hobart
Vehicle: 1986 hilux
Real Name: cory
Re: Boost pressures
Post by invlhvn »
What's that in lbs 10 ?
Vlak vark
Town: Phalaborwa
Re: Boost pressures
Post by Vlak vark »
Hi Cory
The calculation is 1 bar =15.503 pound/sq inch
0.7 * 15.503
=10.85lbs
Hope this help
Hoppy
Vehicle: Hilux SFA & IFS
Real Name: Allan 0721291160
Re: Boost pressures
Post by Hoppy »
I ran my 2.4 DT(2L2T) on .6 bar, it gave 85kw and 245nm, but i had to fit an intercooler to keep the EGT down.
The 2.5 Ford(WL) ran on .9 bar, 95KW and 300nm, with the same cooler.
Haven't dyno'd the 1KZ yet, but should do much the same as the Ford, but at lower RPM
invlhvn
Town: hobart
Vehicle: 1986 hilux
Real Name: cory
Re: Boost pressures
Post by invlhvn »
So 10 pound should be safe to run
Vlak vark
Town: Phalaborwa
Re: Boost pressures
Post by Vlak vark »
invlhvn wrote:So 10 pound should be safe to run
That is up to you,
take into consideration in what condition and mileage you have on your motor.
