EFI - losing revs when revving + under load
- Jaco Versfeld
- Town: Western Cape
- Club VHF Licence: X69
Hi There,
I recently "serviced" Mufasa, did an oil change, new spark plugs and replaced the low pressure fuel filter in front of the High pressure pump. (At what intervals should I replace the high pressure filter?)
Any case, recently Mufasa is struggling at higher revs, around 3700 - 4000, the car will lose momentum and then go and lose momentum. The rev needle will also fall about 100 or 200 revs. This is aggravated if I am going uphill, or have a wind from the front.
Lately Mufasa is idling very low, at around 400 - 500 RPM, even when warm.
I also hear the fuel pump cavitating some time.
Are there any tests that I could do to fault find the problem? (I would love to get Mufasa right for Saturday's day trip at Berakah...) I suspect that the fuel system might get in some air due to me fiddling with the fuel filter. In the past, if the MAP sensor pipe came lose, the engine didn't rev correctly.
Any other suggestions?
Thanks,
Jaco
Thanks,
Jaco
Re: EFI - losing revs when revving + under load
Sounds like fuel starvation. Did you fit the correct size fuel filter and did you fit it the correct way.
- Jaco Versfeld
Fuel filter is definitely fitted correct way - I double checked.CasKru wrote:Sounds like fuel starvation. Did you fit the correct size fuel filter and did you fit it the correct way.
The the diameter of the fuel filter's pipes are 8 mm, is there anything else I should take into consideration?
Thanks,
Jaco
Did the fuel pipe not maybe kink when you worked on it? It sounds like the HP pump is batteling to get enough feed to maintain the fuel pressure needed. At low engine RPM you will maybe not notice it but the higher the RPM the more pronounced it will become.Jaco Versfeld wrote:Fuel filter is definitely fitted correct way - I double checked.CasKru wrote:Sounds like fuel starvation. Did you fit the correct size fuel filter and did you fit it the correct way.
Thanks,
Jaco
- Jaco Versfeld
CasKru wrote:Did the fuel pipe not maybe kink when you worked on it? It sounds like the HP pump is batteling to get enough feed to maintain the fuel pressure needed. At low engine RPM you will maybe not notice it but the higher the RPM the more pronounced it will become.Jaco Versfeld wrote:Fuel filter is definitely fitted correct way - I double checked.CasKru wrote:Sounds like fuel starvation. Did you fit the correct size fuel filter and did you fit it the correct way.
Thanks,
Jaco
Thanks Cassie, I will check.
I do smell fuel when I have driven the vehicle, therefore my suspicion that I didn't fasten one of the clamps. But I will check if I didn't bend the fuel pipe while replacing the fuel filter.
What is the replacement interval on the HP filter?
Thanks,
Jaco
aaaah... sounds like you are sucking in air on the inlet sideJaco Versfeld wrote:
Thanks,
Jaco
Not sure about the canister type fuel filters but I replace mine every 30 000km
Check that the vacuum pipe hasn't dislodged or got bent/blocked on the plenum chamber or behind dicktator ECU itself. Happened on Bolt, I fitted a T piece to stop the pipe snagging and getting blocked. It's critical that there are no leaks/blockages on the vac circuit.
- Club VHF Licence: X93-
Jaco are you sure about the 8mm pipe.I know for a fact that Louis only use 10 mm pipe.The low presure inline filter in my case is 10 mm GUD filter part nr BC10Jaco Versfeld wrote:Fuel filter is definitely fitted correct way - I double checked.CasKru wrote:Sounds like fuel starvation. Did you fit the correct size fuel filter and did you fit it the correct way.
The the diameter of the fuel filter's pipes are 8 mm, is there anything else I should take into consideration?Thanks,
Jaco
- LouisZ
Jaco, kyk na die Vacuum pyp. Ook op die filters se klamps en ook of die petrol pyp nie geknak is nie. Die fuel filter, die metaal een kan mens omtrent elke 25000-30000km vervang. Die klein blastiek filter is BC10. Altwee filters het rigting op. Die een vacuum pypie vanaf die fuel regulator na die manifold kan ook af wees.
