3 pin headlight socket
Vlak vark
Town: Phalaborwa
Post by Vlak vark »
so I want to put relays on my head lights. can some please indicate which wire is earth,dim and brite. if you look from behind towards the light. left- top- right- .
thanks.
Nico
Re: 3 pin headlight socket
Post by Family_Dog »
Have a look here:
http://www.hilux4x4.co.za/wire_spotlights/index.php" onclick="window.open(this.href);return false;
Vlak vark
Town: Phalaborwa
Post by Vlak vark »
dankie oom Eric.
The Legend
Real Name: Dawie
Club VHF Licence: X93-
Post by The Legend »
Nico
Hoekom koop jy nie die hele kit van 4x4 direct.Werk soos n bom en baie maklik om te installeer
Vlak vark
Town: Phalaborwa
Post by Vlak vark »
Dawie,ek het klaar die relays. sal die naweek kyk of ek die draad werk kan doen.
Vlak vark
Town: Phalaborwa
Post by Vlak vark »
so if I test, common is on top and only one (same) wire shows 12v on dim and brite. if 3 way pin is unplug out of bulb the bright light on cluster is not working, plug back and works??
this is confusing
