Hi guys,
I would like some advice: Apparently, I don't have to spend R 15 k for a lift kit on my truck - I can achive SIMILAR results by just replacing the shackles with longer ones, as I had my blades re-rolled some time ago and added helper blades all round. I already have 4 ProComp shocks (for the 4" lift kit) which I will then also fit.
Any comments on this will be welcome. Please don't bite my head off - I know it will never be the same as fitting a proper IronMan, ProComp, OME or Dobinsons suspension kit, but I simply don't have that kind of money.
Is there anything else I should be aware of when doing this? Keep in mind that this is just a toy and work horse, I don't intend on driving it long distances (mostly to Rust de Winter and back), or at high speeds (as if the 2.8D even knows what that means - Shhh, you'll hurt its feelings ).
'98 SFA - Lift
- oxydog
- Real Name: Jarus
- Club VHF Licence: J67
'98 SFA - Lift
Bees (Toy)
'98 Hilux 2.8D 4X4 D/Cab
• ARB Bullbar
• Safari Snorkel
• GearMax Rear Locker
• Front Runner bakkie slide
• 31" BFG KM2's
'06 Hilux 4.0 V6 4X4 D/Cab
• Level-it kit (Front)
• Custom integrated bullbar
• Custom replacement bumper
• Midas driving lights
• 31" BFG KM3's
• ARB Bullbar
• Safari Snorkel
• 31" BFG KM2's
• 31" BFG KM3's
Re: '98 SFA - Lift
Increasing shackle length is normally something that I don't recommend. Bear in mind that you only achieve half the lift of the amount extended - a 2" extension only gives a 1" lift, but a 2" extension will allow for a significant amount of additional sway in the suspension. That means instability, not as important on trails as it is on highway travel, but since you use the vehicle as a "toy" it may not be so significant - just be careful on the open roads to and from your outings.
- oxydog
- Real Name: Jarus
Re: '98 SFA - Lift
Thanks Andy, will keep it in mind.
Bees (Toy)
• ARB Bullbar
• Safari Snorkel
• 31" BFG KM2's
• 31" BFG KM3's
• ARB Bullbar
• Safari Snorkel
• 31" BFG KM2's
• 31" BFG KM3's
- Big D
- Vehicle: SFA Hilux 2.2 BFi
- Real Name: Deon
Re: '98 SFA - Lift
The Procomp kit actually only has new leaf pack for the front. The rear uses your old leaf pack, with the addition of a 4 inch spacer (block) that fits between the blades and the axle. Maybe you can use a similar block in front as well?
Use a smaller block, and extended shackles, to achieve a similar lift? By just doing shackles you will only have a max of approx 1 inch lift for the reasons explained above by Andy..
Have you done a body lift? that is also a easy and cheap 1 inch "lift"
On the other hand, seeing that you already have the socks, Ask Mikem what they will charge for the 4 new leaf packs?? Retetioning of the old blades are more of a temporary solution as they will sag again, maybe the helper
- oxydog
- Real Name: Jarus
Re: '98 SFA - Lift
Thanks Deon, checking it out.
Bees (Toy)
• ARB Bullbar
• Safari Snorkel
• 31" BFG KM2's
• 31" BFG KM3's
• ARB Bullbar
• Safari Snorkel
• 31" BFG KM2's
• 31" BFG KM3's
