Rear locker
- NicoP
- Vehicle: Hilux 2.7, SFA conversion, 33" Maxxis, 4.5 inch lift
- Real Name: Nico
Rear locker
Last night i wanted to fit the "new" diff with the 4.88 ratio. But no luck. Not even the other cente portion fits in to my current casing. So i put the old diff back toghter and now the diff lock stays engaged. Any Idea what can cause this to happen. I did put it in 4wd pushed the button for the locker and still nothing it stays engaged. Even in 2wd.
- HiluxJunkie
- Town: Middelburg MP
- Real Name: Simon
- Club VHF Licence: N15
Re: Rear locker
Is die diff fisies gelock? Is dit nie net 'n limit feedback probleem?
- Jaco Versfeld
- Town: Western Cape
- Real Name: Jaco
- Club VHF Licence: X69
Re: Rear locker
Hi Nico,
Is only the Difflock light on, or is the difflock mechanically engaged?
NicoP wrote:Last night i wanted to fit the "new" diff with the 4.88 ratio. But no luck. Not even the other cente portion fits in to my current casing. So i put the old diff back toghter and now the diff lock stays engaged. Any Idea what can cause this to happen. I did put it in 4wd pushed the button for the locker and still nothing it stays engaged. Even in 2wd.
Re: Rear locker
I'm guessing you have a Gearmax or simular fitted and when you put everything back you miss aligned the fork that enables the difflock.
You can read more here viewtopic.php?f=3&t=2049&st=0&sk=t&sd=a&hilit=gearmax" onclick="window.open(this.href);return false;
The fork in the first picture needs to slide into the groove shown in the second picture. m2cw.You can read more here viewtopic.php?f=3&t=2049&st=0&sk=t&sd=a&hilit=gearmax" onclick="window.open(this.href);return false;
- NicoP
- Real Name: Nico
Re: Rear locker
dis n import diff op die 2.7. die diff is fiesies gelock en die liggie is ook aan.
- NicoP
- Real Name: Nico
Re: Rear locker
Die fout is gevind. Het die motor van die centre portion af gehaal en gekyk dat hy werk. Het toe die locker geaktiveer buite die centre portion en hom net so terug gesit. Als in en vas het ek die locker knoppie gedruk om te deaktiveer en als werk nou reg. Die locker het geaktiveer toe ek als terug aan mekkar gesit het en die motor was in die af posisie. Dis hoekom die locker nie gedeaktiveer het nie.
