Powerful but slow hilux
- Town: Polokwane
- Vehicle: Toyota
- Real Name: Andrew
Hi There, I am sure someone can help, I have recently changed out my 2.2 motor and replaced it with a V6 3L SX motor, however the max speed I can get out of the hilux is 110km/h at around 4500rpm. (1990 model) anyone know what one can do to change this?
Re: Powerful but slow hilux
Conversions, conversions.........when will the guys learn......
Send 'Spartan' a note / pm
Did you change the gearbox/diff ratios as part of the conversion?spearpoint wrote:Hi There, I am sure someone can help, I have recently changed out my 2.2 motor and replaced it with a V6 3L SX motor, however the max speed I can get out of the hilux is 110km/h at around 4500rpm. (1990 model) anyone know what one can do to change this?
- BlumTRD
- Town: South Africa
- Real Name: David
change the diff
4.875 to 4.566
4.875 to 4.566
Don't forget to change the front diff as well, or you will have a major problem when in 4x4 mode.
The song "Don't you just know it?" comes to mindFamily_Dog wrote:Don't forget to change the front diff as well, or you will have a major problem when in 4x4 mode.
- Town: Polokwane
- Vehicle: Toyota
- Real Name: Andrew
Thanks, much appreciated, do you know where one can purchase these diffs?
Any Gearbox/Diff specialist should be able to help you. Probably about R4k per each, maybe a trade in if yours are in good nick.
- Riceburner
- Town: JHB
- Vehicle: D2 V8
- Real Name: Darryl
Its cheaper to fit 33"s and a lift kit. 50mm lift and 50mm body lift. Looks trick. Check the timing on the V6 before any rash thoughts.
- Town: pretoria
- Vehicle: 911 Carreara MB CL 500 MB 500SEC MB 450 SLC CHRYSLER CROSSFIRE CONVERTABLE SFA HILEX JEEP 5.2 V8 FORD RANGER LEXUS
- Real Name: Fana
Maybe you must shift the box in to high range because I think you are in low because a 4.875 diff gives you 140 km|h at 4000 rpm in high range in 5th gear .
