40mm Body Lift on 2002 KZ-TE
- Donkey
- Club VHF Licence: X122
Hi guys
I'm in the process of doing a body lift on my truck, and thanks to JohanM for the willingness to assist. I know there are one or two on the forum who have challenged this task before and therefore would appreciate some info on bolt sizes.
Below is what I could come up with:
I hope this will make sense to you, I worked from the back of the bakkie to the front. I could not measure the exact length of the bolts but I tried as much as I could. The bin has four (4) bolted places with bolts +- 40mm long.
From behind the rear doors, in front of the rear wheels, there's two (2) bolts on either side of about 80mm long, going forward but behind the front wheels and below the front doors, there's two (2) bolts on either side also about 80mm long. The very front is bolted on two (2) 40mm bolts.
In total there's 6 x 40mm bolts, and 4 x 80mm bolts.
Please assist with the exact length(s) and thickness of the original bolts.
:wth:
Warm regards,
:wth:
Warm regards,
Tumelo Maketekete
- Niel
- Real Name: Niel
Re: 40mm Body Lift on 2002 KZ-TE
It would be interesting to see what the fuel consumption is after the lift is done
- Donkey
Will let you know oom Niel.
Tumelo Maketekete
- Niel
- Real Name: Niel
Cool, there is a lot of oom's here but I am still under 60 year of age so I don’t quality for that title (not sure where oooooms fit in that age range)
- Donkey
Anyone older than me qulifies as an oom, oom.
Tumelo Maketekete
- Niel
- Real Name: Niel
my last hi-jacking post
I am only 18
I am only 18
- Johannes van die See
Niel
Jou hare lyk dalk agtien maar ek weetie so mooi van die figuur nie?
- Donkey
Ok, I have a suspecion we're drifting ever so slightly from the topic here guys,
This might distract the boffins who may be tempted to assist.
Bolt sizes is the focal point, as we meditate - mmmmmmmmmmmmmmmmmmmmmm,
Tumelo Maketekete
Tumelo... what bolt size would you like?
Donkey wrote:Ok, I have a suspecion we're drifting ever so slightly from the topic here guys,
- Bushwacker
- Town: Vryheid Natal
- Real Name: Piet
Best way is to remove driver side bolts & go buy 2 of each, 40mm longer
- JohanM
- Town: Meyerton
- Vehicle: Prado 120 4.0 V6
- Club VHF Licence: HC126
Piet I was also thinking along that same line!!! IIRC The bolts are all 10mm H.T Bolts... Just the lenghts that differ a bit..Bushwacker wrote:Best way is to remove driver side bolts & go buy 2 of each, 40mm longer
- Donkey
Mr_B, Johan and Piet thank you for your input, I was hoping someone may have taken the bolts out and knew the lengths, to avoid all the homework, before doing the actual homework. Thank you guys.
Tumelo Maketekete
- Town: Springs
- Real Name: Heinrich
- Club VHF Licence: X81
Thumelo, this is nothing technical in any way and probably will add no real value. But you might find this read interesting.
http://www.vehiclemods.net.au/products/ ... -vigo.html" onclick="window.open(this.href);return false;
Know what you don't know.
Thumelo, how's the progress going?
Here is another link with some info that may assist: viewtopic.php?f=3&t=9924&hilit=kzte+body+lift" onclick="window.open(this.href);return false;
