Fitting a snorkel
Traveler
Vehicle: Pathfinder 2.5 LE AT
Real Name: Heinrich
Club VHF Licence: X81
Did this one 2 weekends ago. And it is traumatic to say the least. You have to drill your Hilux full of holes. :shock:
Got my hands on a snorkel kit and instead of paying R750 for fitment went the route of fitting it myself. Did some reading on Aussie forums and got to know that with this kit you need to move the template as far forward as possible with your indicator light as the reference point. The template is a bit on the short side and you need to make provision for that.
Those little allen screws that go into the snorkel I used loctite to keep in place as they are then bolted through the fender to keep it in place with lock nuts.
I used an 89mm hole saw to cut the hole where the snorkel has to go into the fender. After that I used a power file to smooth the edges.
I blackened the ends of the bolts that go through the fender to keep the snorkel in place and then pushed it against the body. The template is not perfect so it showed the correct places to drill and only one lined up with what the template showed.
After all the holes where drilled I painted it with white Duco. Then I applied a generous amount of automotive silicone to the holes and around the bolts and rivets. Then I could bolt and rivet everything down.
The bolts supplied to attach the top of the snorkel with top bracket on the A-Pillar had heads there where to thick and they caught on the door frame on opening and closing, so I had to change them for round head 6mm allen head bolts. Now the clearance is fine.
I must say I am rather satisfied with my own installation.
After fitting snorkel I've extracted another 3kw from the engine as it breathes MUCH easier.
Know what you don't know.
Traveler
Real Name: Heinrich
Here are the last few pics.
Dankie Heinrich, ek sal dan sommer OOOODS se Tuna bring vir fitment as sy reg is.... :lol: :lol:
Dan kan jy die gate boor en ek hoef nie sleg te voel nie :yahoo:
Lyk baie netjies :thumbup:
Spartan
Town: Vanderbijlpark
Real Name: Jaco
Is daai voor rim van jou gebuig? of kyk ek maar net verkeerd?
MOBILITATE VINCERE
Spartan
Traveler
Real Name: Heinrich
............... ons kan gesels ..... :mrgreen: ek gebruik steeds valium om myself te kalmeer.
Ek het eers begin rustig raak nadat hy op was. Ek sou seker die hele job kon doen in 45minute, maar het amper twee ure gevat want ek het heeltyd met die boor in die hand gestaan en moed bymekaar skraap om te begin.
Ek dink jy kyk bietjie verkeerd Spartan. Rim is beslis nie gebuig nie. :lol:
Spartan
Real Name: Jaco
Oh ok :lol:
MOBILITATE VINCERE
Spartan
Traveler
Real Name: Heinrich
Spartan wrote:Oh ok :lol:
Die foto lyk bietjie weird. Jy het my amper laat skrik. :wth:
Spartan
Real Name: Jaco
:lol: :lol: :lol: :thumbup: maar jy sien wat ek sê
MOBILITATE VINCERE
Spartan
Job well done Heinrich. Hoop jy het die gate darem met ietsie behandel so dat die outjies nie roes nie. :thumbup: :thumbup:
Traveler
Real Name: Heinrich
Thanks Cassie, ja ek het hom met duco geverf, primer en wit. En die gate is goed gevul met auto silikon sodat water en ander gemors nie daar kan inkom nie.
Traveler wrote:Thanks Cassie, ja ek het hom met duco geverf, primer en wit. En die gate is goed gevul met auto silikon sodat water en ander gemors nie daar kan inkom nie.
Het niks minder van jou verwag nie :lol: :lol: :lol: :thumbup: :thumbup: :thumbup:
Traveler
Real Name: Heinrich
Thanks. ;-) :thumbup:
FUDGES
Vehicle: D4D 3.0l
Real Name: A.J.
Baie Nice jyt baie guts :shock2:
Kan ek myne ook maar bring my hart sal dit nie hou nie :blushing: :tease:
Watse snorkel is dit daai?
Job well done, Heinrich! I feel your pain in regard to making a gaping big hole... at least we only cut 19mm ones and have nice little UV resistant rubber plugs to close them up with if we remove the antennas afterwards when the vehicle is sold ;)
Traveler
Real Name: Heinrich
A.J. wrote:Baie Nice jyt baie guts :shock2:
AJ, daai ene is van 'n parteverskaffer wat hulle probeer invoer het van China af, maar Toyota handelaars het nie belanggestel nie, toe kry ek hom by hom.
Daai snorkel is ek dink presies wat Duwayne probeer doen het, en ook presies wat jy nou Decleor 4x4 kan kry.
http://www.decleortrailers.co.za/" onclick="window.open(this.href);return false;
F_D, not so much fun to put the drill to the fender. Hurts plenty.... :blackeye:
Town: inniedorp
Vehicle: Toy
Heinrich MOOI gedoen.
Ek het my hele stelsel agterin self gebou .... maar toe maar betaal dat n ander man daai gate in Elders boor ......
Traveler
Real Name: Heinrich
ChrisF wrote:Heinrich MOOI gedoen.
Baie dankie Chris. Ek is bly ek het my tyd geneem. :beach:
Rieks
Town: Outjo
Vehicle: 3.0 D4D
Real Name: Rian
Baie goei jobbie Henrich! Ek moet se jy't guts! Ek moes twee klein gaatjies in my enjib kap boor om 'n solenoid te installeer. Vra nog steeds askuus elke oggend as ek in haar klim.
Watse Rock Sliders het jy op? Dit lyk interesant
andrevt
Town: sasolburg
Vehicle: raider d4d
Real Name: andre
bAIE BAIE GOED GEDOEN EK SAL MAAR VERSEKER EERS N PAAR BRANDEWYNTJIES VAT VIR SO N DRASTIESE STAP
Toyota Hilux 3.0 D4D 4x4
Town: inniedorp
Vehicle: Toy
Dink dis Uys se sliders daai.
Tiger7
Vehicle: TOYOTA HILUX 2.7VVT-I SRX 4X4
Real Name: Jonathan
Dit lyk Baie nice.
Hoe lyk dit van die kant af met die aantena? Pic asb.
Traveler
Real Name: Heinrich
Ek sal foto"s bysit in die volgende dag of twee.
Ek was bekommerd gewees oor die boonste bracket, maar hy sit netjies weg van die antenna af. En die antenna druk ook nie teen die rivets nie.
Blackadder
Vehicle: Toyota Fortuner 3.0 D4D, Ironman Bumper, OME, Dual Battery, BFG'S, TJM Snorkel, Navstar 220 29mhz radio, LAS Pro Rear Bumper, Frontrunner Roofrack
Real Name: Thinus
Club VHF Licence: X82
Dit lyk baie smart. Ek persoonlik sal dalk eerder my eie kind se mangel operasie doen voor ek daai gate boor...
Spartan
Real Name: Jaco
Blackadder wrote:Dit lyk baie smart. Ek persoonlik sal dalk eerder my eie kind se mangel operasie doen voor ek daai gate boor...
:lol: :lol: :lol: :lol: :thumbup:
MOBILITATE VINCERE
Spartan
Traveler
Real Name: Heinrich
ChrisF wrote:Dink dis Uys se sliders daai.
Dit is hoofsaaklik Uys se ontwerp op die rocksliders. Met so bietjie aanpassing waar ek gedink het ek kan dit so bietjie beter doen op my Hilux.
Ek het nog nie gedink aan die korrelasie tussen boor en mangels nie.... :mocking: :mocking: :lol: :lol: :lmao: :lmao:
Ek het 'n Whiskey oorweeg voor die boor, maar toe is ek bang ek boor dalk die linker fender.
Rieks
Town: Outjo
Vehicle: 3.0 D4D
Real Name: Rian
Heinrich, het jy vir ons mooi prentjies van jou sliders?
Traveler
Real Name: Heinrich
So bietjie off topic, maar julle vra so mooi.
:clap:
Rieks
Town: Outjo
Vehicle: 3.0 D4D
Real Name: Rian
Baie Dankie Heinrich.
Terug na die snorkel!
Traveler
Real Name: Heinrich
Hier is daardie ekstra foto's wat die boonste bracket wys soos wat hy nou lyk. Verskoon maar die stof, die wind verwaai ons omtrent Maandag is Dreadnought gewas.
Bijl
Town: Bloemfontein
Vehicle: `87 dc 4x4 Hilux (import)
Real Name: Simon
Hi Heinrich,
Ek het `n voëltjie hoor fluit dat `n snorkel die engine bietjie kan versmoor en ook swakker brandstof verbruik gee.
Wat dink julle manne hier van?
Traveler
Real Name: Heinrich
Simon, ek dink daai storie is dalk as jy jou vinger in 'n snorkel druk terwyl iemand swem..... :mrgreen:
Jy kry BAIE meer lug in die engine in, as jy jou hand voor die ram hou kan jy voel hoe hy suig, na die snorkel het daar nog so paar perde losgekom, en brandstofverbruik is VERSEKER beter.
Ek moes nooit so lank gewag het om 'n snorkel op te sit nie.
Bijl
Town: Bloemfontein
Real Name: Simon
Dis wat ek ook gedink het, want die lug buite jou bonnet is baie koeler en skoner. Sal dan een van die dae vir my ook een moet aanskaf.
Jyt `n baie netjiese werk gedoen daar, pat yourself on the back! :thumbup:
Traveler
Real Name: Heinrich
Thanks man, ek is dankbaar ek het so lank gevat om alles te meet.
Jy sal nie spyt wees nie, ek reken mens maak die geld terug op die brandstof wat jy spaar.
Bushpilot
Town: Umhlanga Rocks
Vehicle: 2008 Hilux D4D 4x4
Real Name: Brent
Thanks for a good topic Heinrich. Still, I can't get it over my heart to take a drill to my Hilux! Does anybody know of someone who can fit a snorkel in the Durban area? I'm prepared to pay, just don't want to take a drill to my baby - who knows how it will affect my karma in my next life...
Sebata
Town: Cosmo City
Vehicle: '06 Hilux 4.0l V6 auto 4x4, Iron-Man front bumper, Ali3n Rock-sliders, Old man Suspention, Snokel, 31" Pireli Scorpion Muds
Real Name: Tau
Club VHF Licence: X125
Bushpilot wrote:Thanks for a good topic Heinrich. Still, I can't get it over my heart to take a drill to my Hilux! Does anybody know of someone who can fit a snorkel in the Durban area? I'm prepared to pay, just don't want to take a drill to my baby - who knows how it will affect my karma in my next life...
That's one heart breaking operation but the end results are awesome :thumbup:
Tau Sello
How does that old saying go? ..... No pain, no gain! :D: ;-)
Baie netjiese joppie Heinrich. Nee ek sal self maar moeilik daardie boor aanskakel!!
Opsmedic
Town: Port Elizabeth
Vehicle: 2001 Hilux KZ TE 4x4 D/C and Suzuki SJ413
Real Name: David
Club VHF Licence: HC 308
Ek het die naweek besluit om te kyk hoe lyk dit agter my Lux se snorkel. Daar kom ek toe af op 'n nes roeswurms. Ek alles skoon gemaak al die roes af geskuur en toe met rust converter behandel. Die modderskerm toe binne en buite met 'n lagie tectyl gespuit en toe ek die snorkel terugsit het ek twee stainless steel washers tussen die snorkel en modderskerm gesit sodat daar 'n gaping is vir water en stof om uit te spoel as ek die kar was. Hopelik is dit die einde van daai roeswurms.
BaasJo
Town: Sterkrivier
Vehicle: Hilux DC 3.0D-4D 4x4
Real Name: Jo
Hi David, het jy self die oorspronklike instalasie gedoen?
