SAC Unichip & Wildcat Exhaust Upgrade - 3.0D4D Auto
- Andre de Jager
- Town: Krugersdorp
- Vehicle: Hilux 2011 3.0 D4D 4x4 DC (Auto)
- Real Name: Andre
Hi Guys
I'm running a 3.0D4D Auto, with suspension upgrade and 265/75R16 Muds on 8JJ Rims. The extra weight of accesories are about 500kg's. The conversion was done on 1520km on the clock.
SAC Founder Stephen Fischer did my upgrade himself and the results were as follow:
Gain in kW = 18.1
Gain in torque = 107Nm
The bakkie is a totally different vehicle. Much smoother aspecially with the auto. And what's best of all is that the most gain in nm is between 1500-3000 refs. The exhaust system is basically the same as the std one, but without cat-converter and made out of stainless steel with bigger diameter.
Here's the graph from standard with chip and Wildcat Exhaust system. Here's the graph from with chip and after exhaust were fitted. Before the chip I got 9.1km/liter
After the chip it went up to 9.9km/liter
This weekend we did a trip of 650km including gravel and offroad and I was highly impressed with the difference. I will test the durabillity of this conversion in future and will report back in due coarse.
Note:
The exhaust almost give a 7kW and 30Nm gain. There is no difference in the sound of the exhaust from std to after.
Also see the difference of the nm in the refs range on the flywheel.
78.6kW@3447rpm
to
96.7kW@2981rpm
243Nm@2937rpm
to
350Nm@2423rpm
Gain in kW = 18.1
Note:
78.6kW@3447rpm
to
96.7kW@2981rpm
243Nm@2937rpm
to
350Nm@2423rpm
"THERE ARE NO SHORTCUTS TO ANY PLACE WORTH GOING, EXCEPT IN A HILUX"
- Johannes van die See
Re: SAC Unichip & Wildcat Exhaust Upgrade - 3.0D4D Auto
Ek se al lankal SAC is kwai, weet nie hoekom party manne ontevrede is daarmee nie?
Lekker man, stats lyk baie goed!
- Town: Midrand
- Real Name: Nishan
nice gains
+ nice smooth graph!
brilliant!
Wat were the costs?
brilliant!
Wat were the costs?
Real drivers use three pedals
- Andre de Jager
- Town: Krugersdorp
- Real Name: Andre
+-10K
If you have a lot of accesories or do allot of towing it's a great buy.
- Modder
- Town: West Rand
- Vehicle: 2009 Hilux 3.0 D4D D/C 4x4
- Real Name: Alec
Nice man!
Wanneer kom vat jy my vir 'n spin?
''Life is an adventure! Cheers!'' - Kingsley Holgate
Born to hunt, forced to work!
My hart is die bosveld, maar my gat is in die stad!!!
- Frederick
- Town: Hendrina Mpumalanga
- Vehicle: 2011 Hilux. 2016 79 Land Cruiser
- Real Name: Frederick
- Club VHF Licence: X42
Hoe kry jy dit reg dat Mnr Fischer dit self vir jou doen? Ek het self al 'n paar chips in voertuie gehad met party goeie en party nare ondervindings. Die konsensus wat oor die jare bereik is, is dat die resultaat en betroubaarheid van jou enjin en chip hang af van wie die instalasie en stelwerk doen.
- Andre de Jager
- Town: Krugersdorp
- Real Name: Andre
Eesrte 800km trippie vol gelaai soos vir overlanding en die kragverskil is absoluut genius. Brandstofverbruik is verseker beter na die chip en die exhaust. Dit maak 'n reuse verskil, veral met die autobox wat bietjie lui aan die begin was. Offroad is die torgue teen lae toere net ongelooflik.
Ek sal dit definitief aanbeveel op enige moderne diesel model. Sit die glimlag terug op jou gesig.
- Town: Oudtshoorn
- Vehicle: 3.0 D4D 4x4 d/c 2009, 3" Lift, 33" BFG M/T's, 3" JWC Exhaust, EGT gauge, Unichip, Front Mount Intercooler, K&N Filter, Snorkel
- Real Name: Manie
Hi Andre
Also have a Unichip fitted by Dr Quincy in George on my 3.0 D4D 4x4 d/c manual,
145kW and 396NM on the Dyna. Fitted a free flow afterwards but didn't make a real difference when tested on the Dyna. Maybe they fitted the wrong size pipe and silencer box. What pipe diameter did Stephen put on your Hilux? And is the silencer a free flow box with the same dimension as the OE?
- Town: Bultfontein
- Vehicle: 2007 Hilux 2.5 D4-D 4x4
- Real Name: Dries
Goei dag Andre
Het n 2.5 met chip en intercooler (SAC) , sal die exh n verskil maak? en sal jy dit aanbeveel?
2007 Hilux 2.5 D-4D 4x4 S/C
Intercooler + Unichip (SAC)
BFGoodrich M/T
Longrange tank
Ironman rep bumper
BFGoodrich M/T
Longrange tank
Ironman rep bumper
- waynza
- Town: Gauteng
- Vehicle: Toyota Hilux 4.0L V6
- Real Name: Wayne
HI Adre, how has the upgrade affected your fuel economy??
The gains looks pretty good. how long does the upgrade and exhaust take to do?
" If you don't like something change it; if you can't change it, change the way you think about it."
- yotaman
- Real Name: Shane
Myne gaan in komende Maandag vir Chip, SS Free Flow, Branch en Filter (Midrand tak) Sal terug raporteer. Ek het nie geweet hulle gooi n B Branch ook in nie. kan nie wag nieJohannes van die See wrote:Ek se al lankal SAC is kwai, weet nie hoekom party manne ontevrede is daarmee nie?
Albert Einstein
Albert Einstein
- Stan_
- Town: JHB
- Vehicle: 3.0 D4d
- Real Name: Stan
- Club VHF Licence: T35
Andre de Jager wrote:Hi Guys
Gain in kW = 18.1
Note:
78.6kW@3447rpm
to
96.7kW@2981rpm
243Nm@2937rpm
to
350Nm@2423rpm
Hi Andre, are you still happy with the work they did on your truck. Thinking of sending mine in to do the same.
By the way, your truck looks awesome.
Stan
- andrevt
- Town: sasolburg
- Vehicle: raider d4d
- Real Name: andre
hi andre
praat met henk van steves op vanderbijl om jou exhaust ook te doen, dit maak n groot verskil
Toyota Hilux 3.0 D4D 4x4
- Andre de Jager
- Town: Krugersdorp
- Real Name: Andre
Hi. Ek weet nie presies watter dikte die pyp was nie, maar dit maak 'n verskil van so 10KW.
Ek het nou 29000km en geen probleme of klagtes sover nie.
Briljante modifikasie.
- VeeS1x
- Town: Pierre van Ryneveld
- Vehicle: 2010 Hilux 4.0l Double Cab 4x4, OME, TJM Winch, ARB Bumper, IPF Spots, LR tank, Dual Battery
- Real Name: Martin
Wat maak daai veranderinge aan jou waarborg, ek het `n 4l v6 en wil die cats laat uithaal maar hoor die waarborg sal dan sy gat sien
2010 Hilux 4.0l Double Cab 4x4 (Bismark MK2)
- BenRich
- Town: Boksburg
- Vehicle: Hilux 4.0 V6 4x4 BF Goodrich KM2 MT Old Man Emu Suspension, ONCA Rocksliders, Safari Snorkel, Stofpad Bashplate's National Luna Duel Battery System, Engel Fridge
Ek het ook die 4.0L en wil ook die cats laat waai...jy gaan jou waarborg verloor maar ek wil net graag weet of dit regtig nadelig vir die motor gaan wees....
- VeeS1x
- Real Name: Martin
Sorry - dis seker hijack, maar as ouens kan wegkom met freeflow systems op hulle gewaarborgde bakkies, dan kan decat mos nie warranty void nie, of moet ek ook die hele system laat doen?
- stephanvaneeden
- Vehicle: 2012 Hilux 3.0 D4D D/C 4X4
- Real Name: Stephan
Nou as ek my exhaust stukkend ry, reken julle my waarborg is weg. Ek het ook een van daai sac freeflows op, met 20 000 km op my bakkie. Die exhaust word nie gedek onder hulle waarborg nie, so jy kan nie jou waarborg verloor as die ding gebreek het nie.
- BenRich
- Town: Boksburg
Lees weer...net as jy jou cats laat uithaal!
