Vigo electric window problem
oxydog
Vehicle: '98 Hilux SFA 2.8D 4X4 D/C, '06 Hilux 4.0 V6 4X4 D/C
Real Name: Jarus
Club VHF Licence: J67
Wed Aug 08, 2012 7:32 am
Does anyone else have a problem with the driver's window not automatically going down completely when it's cold? It only goes down 10 - 20 cm at a time, then stops, so you have to push the button again. This only happens in the cold (in other words, it happened a lot the last 2 days!) - when it is warmer, it rolls down automatically until it is completely open, like it should.
Bees (Toy)
'98 Hilux 2.8D 4X4 D/Cab
• ARB Bullbar
• Safari Snorkel
• GearMax Rear Locker
• Front Runner bakkie slide
• 31" BFG MT's
'06 Hilux 4.0 V6 4X4 D/Cab
• Level-it kit (Front)
• Custom integrated bullbar
• Custom replacement bumper
• Eurolux 1500W inverter
• Midas driving lights
• 31" BFG AT's
Polarbear2008
Real Name: Theunis
Club VHF Licence: X49
Wed Aug 08, 2012 7:58 am
Jarus I am going to take a chance and say it has to do with the rubbers that the window runs in. The auto down system works on resistance. When the window travels to the end of the rails, the motor takes up load (because the window is not moving anymore) and the system stops. It sounds to me like there is friction between the window and the rubbers that is causing the same effect (as above) when it is cold. You can try spraying silicone spray in the wind side rubbers (where the window runs) and see if this helps.
My 2c worth
Monroe Gas Magnum shocks
Dual loadbox slides
Wishlist:
Alu canopy
Warn Winch
oxydog
Real Name: Jarus
Wed Aug 08, 2012 8:05 am
Thanks Theunis, I'll give the silicone spray a try. Sounds at this stage like I'm the only one having this problem?
Bees (Toy)
• ARB Bullbar
• Safari Snorkel
• 31" BFG MT's
• 31" BFG AT's
Wed Aug 08, 2012 8:07 am
Give it a good clean before spraying..... :wink2:
oxydog
Real Name: Jarus
Wed Aug 08, 2012 8:29 am
Thanks Mark, will do.
Bees (Toy)
• ARB Bullbar
• Safari Snorkel
• 31" BFG MT's
• 31" BFG AT's
Polarbear2008
Real Name: Theunis
Wed Aug 08, 2012 11:32 am
Jarus
Please give some feedback if it works or not.
Dual loadbox slides
Wishlist:
Alu canopy
Warn Winch
Mon Aug 13, 2012 8:54 am
Jarus, any luck?
oxydog
Real Name: Jarus
Tue Sep 04, 2012 12:41 pm
Sorry guys, been a bit busy lately. Nope, haven't done it yet, but as the weather improved, the problem went away. I'll have to wait for it to get cold again before I try it, otherwise I won't know whether it worked or not. Looks like that might happen later this week...
Bees (Toy)
• ARB Bullbar
• Safari Snorkel
• 31" BFG MT's
• 31" BFG AT's
oxydog
Real Name: Jarus
Thu Mar 23, 2017 1:57 pm
OK, so I finally decided to try this 5 years down the line (oops). Shop attendant suggested that I use something other than silicone spray, as it might attract lots of dust. He sold me a can of Wynflon (Wynns PTFE based lubricant).
• The good: It works like a charm.
• The bad: It smells TERRIBLE!
So my suggestion - Don't use this inside your car for ANY purpose! :lmao:
Bees (Toy)
• ARB Bullbar
• Safari Snorkel
• 31" BFG MT's
• 31" BFG AT's
Obelix and Dogmatix
Town: ROODEPOORT
Vehicle: HILUX 4.0 V6 4x4 named Obelix, donated to some clown, HILUX 4.0 V6 4x4 named Obelix II Onca front and rear Amade extreme Suspension and under water breathing apparatus
Real Name: Quentin
Thu Mar 23, 2017 2:51 pm
Janus, mine started doing the same thing a week ago, hot temperatures, also think that it has to do with the window rubbers. will give it a good clean and take it from there
God made man before
woman so as to give him time
to think of an answer
for her first question
oxydog
Real Name: Jarus
Thu Mar 23, 2017 3:31 pm
Funny, mine did it in cold weather. I think the problem is the same though - A good clean should do the trick!
Bees (Toy)
• ARB Bullbar
• Safari Snorkel
• 31" BFG MT's
• 31" BFG AT's
