This may look like a stupid question to some of you but I just can't figure out an easy way to remove and attach my tonneau cover. The cover attaches to the back and sides of the load bin with an elastic thread, but it seems that behind the cab it needs to slide in from the side. The rollbar makes sliding it in pretty tricky. Is there an easy way to do this?
Help needed with Tonneau cover and rollbar
- dantjie
- Town: kuilrivier
- Vehicle: HILUX SFA LTD 2.4 EFI
- Real Name: Danie
Re: Help needed with Tonneau cover and rollbar
Hi carel
Nope sorry no bypasses on this one u must make sure that the rope inside the tonneau cover fits snuggle into the rail if it came out, u must loosen the elastic thread at both sides till by the roll bar and almost remove the cover and the slide it into the rail from one side to the other and then retighten the rope again.
- Town: Stellenbosch
- Vehicle: 2008 Hilux D4D
- Real Name: Carel
Dankie Dantjie!
