Intercooler gasket leak
muki
Vehicle: Hilux 3.0 D4d D/C 4x4 A/T
Real Name: Mohamed
Tue Jun 26, 2018 6:04 pm
I seem to have a leak on my pipe from turbo to intercooler. I have already taken it off, cleaned and replaced. But still seems to be leaking. Logic dictates next step is to replace the gasket? It's a metal gasket.
Also, should there be oil coming out? This effectively means my turbo is leaking oil? Or does a turbo use oil normally? Image
Sent from my Mi A1 using Tapatalk
Kaaskrul
Town: Port Elizabeth
Vehicle: 2018 Hilux X-Cab 4x4 Dakar
Real Name: Pierre
Tue Jun 26, 2018 11:31 pm
Mine did the same. Just replace the steel gasket. Its like R50 from Toyota.
But dont strip the threads, that aluminium on cooler cant take alot of force.
Over time some oil do go through the system, no need to panic.
muki
Real Name: Mohamed
Wed Jun 27, 2018 10:45 am
Thanks, will make a turn by Toyota today.
muki
Real Name: Mohamed
Wed Jun 27, 2018 11:11 am
Discontinued part by Toyota. Would a vollumoid gasket be sufficient?
Wed Jun 27, 2018 12:12 pm
I cannot believe that it is discontinued. There are still many many of those vehicles on the road. In any Turbodiesel you will find some oil there. No reason to panic. I'm not sure if the vellumoid will work. Perhaps the thin one lightly coated with RTV on both sides?
Kaaskrul
Real Name: Pierre
Wed Jun 27, 2018 5:02 pm
The only gasket that will work there is the steel gasket trust me.
I called a buddy at Toyota. Yes he says the system shows discontinued, but its actually just a part nr change.
He will phone the factory tomorrow and get the new part nr, then you can go to your dealer and order it.
So just hang in there until tomorrow around 12.
muki
Real Name: Mohamed
Wed Jun 27, 2018 5:13 pm
Awesome, thanks very much. Will await your response
JohanM
Town: Parys
Vehicle: Prado 120 4.0 V6
Club VHF Licence: X45
Wed Jun 27, 2018 8:06 pm
Hi Mohamed
The part number that I can find on the system is 17116-0L010 but I'm suspecting this is the one that is changed into a new part number as Pierre mentioned.
Kaaskrul
Real Name: Pierre
Thu Jun 28, 2018 6:35 pm
Hectic day and I never called Toyota back.Will do that tomorrow sorry buddy.
muki
Real Name: Mohamed
Fri Jun 29, 2018 12:01 pm
No worries, thanks for the assistance.
Can confirm that 17116-0L010 is the discontinued part Number.
