Ek het na 'n lank sukkel vir my heatshields in die hande gekry teen wat ek dink, 'n billike prys is.
ATS-Motorsport verkoop sheet 1mx1m vir R200 excl vat. Kan tot 1700F hanteer en kan gesny word om orals in te pas. Word gemaak van Aluminium en fibers.
http://www.ats-motorsport.co.za" onclick="window.open(this.href);return false;
Heat Shields
- Vehicle: Ry die vyand
- Real Name: Reynard
- Club VHF Licence: B01
Heat Shields
Elands4x4
Elands4x4
- Sifu-Lux
- Town: Mount Vernon Illinois
- Real Name: Andrew
Re: Heat Shields
Good to know ! I see they have some other nice stuff too :)
Sifu-Lux....I will miss you
- Toybox
- Vehicle: Hilex
- Real Name: Jonathan
- Club VHF Licence: X100
Re: Heat Shields
Yip, I've got a mate who ended up using my leftover sheet for that very purpose Cas... After one of his passengers put a bare foot on one of the seat belt bolts and got burnt he promptly set about fastening the heatsheild to the underside of the cab. It worked a treat.
I'm not sure how long it's going to last though, the water and mud has caused it to start looking a bit tatty, but it still works!
Re: Heat Shields
Jip Cassie, dit gaan teen die firewall en ratkas tonnel. Ek wil dit ook gebruik in die vloer waar die exchaust gaan loop. Ons voete brand klaar met die 3RZ, so die Lexus dink ek dit kan erger wees.CasKru wrote:Gaan jy dit tussen die kajuit en die uitlaatstelsel sit?
Elands4x4
Elands4x4
- krazy_kameleon
- Town: Fourways
- Real Name: Rick
Re: Heat Shields
Just a tip on installing:
forget glue, just use rivets with big washers - then it doesn't matter what you drive through...
