Bashplate
coetzer94
Real Name: Vian
Mon Aug 07, 2017 11:28 am
Het iemand al hul bash plate blou of rooi gepowdercoat?
Ek wil die bakkie net kein bietjie laat uitstaan tussen al die swart en silwer plate?
Enige kleur voorstelle sal oorweeg word.
Die bakkie het nog die plastic bumper op, so dit gaan darm nie te veel uitstaan nie.
rigardt
Town: Alberton
Vehicle: 2012 DC Hilux D4D
Real Name: Rigardt
Club VHF Licence: HC348
Thu Aug 10, 2017 8:17 pm
I recently repainted mine.
made it black again. used a rubber bakkie lining paint. its like rubber. coated it with a roller. took a few days for each coat to dry but it was like 8 degrees outside !
from my research powdercoating is a problem
you can make it any colour you want but I wont powdercoat it.
its a bashplate after all.
when you bash it with powdercoat then its too difficult to touch up again.
with paint you can easily just fix where the paint has come off instead of having to re powdercoat the whole thing again
Thabogrobler
Club VHF Licence: x223
Fri Aug 11, 2017 6:54 am
An etch primer and QD enamel applied with a sponge roller should do the trick. Or perhaps hammerite?
coetzer94
Real Name: Vian
Fri Aug 11, 2017 8:47 am
Thanks for the insights, but i found a guy doing aluminuim plates for a decent price, so no more steel that needs to be painted.
I still think a coloured plate will look awesome; but well leave that for another day
Return to “General Mods”
