Spot Lights, delay, and then nothing.
Posted: Fri Sep 08, 2017 7:38 pm
by drew3
Hey guys.
Installed some new spot lights to my Lux a few weeks back, but haven't really had a chance to test them out. They are 70W LED Spots.
Drove around in the bushes last night and they work great, but something weird happened and happened again while testing today.
When I first turned them on.... instant sunshine! Then I decided to turn them off for a bit, turned them on again and.... slight delay but they came on. Off and on a bit later, longer delay but they came on. On the third or fourth go, they just don't come on at all?!?! At first I thought it was a bad connection on the relay but checking that hasn't sorted anything out.
I originally just had a set of old Hellas (50W Halogen) which were not doing much for me.
In the end I decided to keep the Hellas wired in and mounted, and I piggy backed the wiring for the new spots off of the old wiring harness which includes a relay and independent switch in the dash.
The original wiring for the Hellas is rather thick ( I couldn't tell you the size), and I am using a 30 AMP fuse for the whole setup.
If it isn't obvious, once left off for a good while, the spots go on normally but the process repeats itself. Oh and this effects the Hellas in the same way.
Any help will be greatly appreciated.We
Re: Spot Lights, delay, and then nothing.
Posted: Mon Sep 11, 2017 3:06 pm
by LouisZ
Does the Hella's switch the relay on on a separate switch or does it trigger with the brights?
Posted: Wed Sep 27, 2017 3:10 pm
by drew3
Sorry for the slow response. Ended up being a faulty relay. Not sure why but it would get stuck in the off position once warmed up or something.
Posted: Wed Sep 27, 2017 3:32 pm
by Mars
Good to know. Thanks for the feedback.
