Auto-up on driver side window switch?
- Bushwacker
- Town: Vryheid Natal
- Real Name: Piet
I was looking at this topic on the Cruiser forum http://www.landcruiserclub.co.za/cms/in ... pic&t=9189 and had a look at my KZ's switch circuit but it is way different. Is there a way to change it to be auto-up aswell?
Another site: http://mr2.gordaen.com/mods/10/index.php
Re: Auto-up on driver side window switch?
Must be ... but I wonder how much effort and mod it will take. If I'm not mistaken the LC has a seperate little button (Click switch) which engages / disengages the auto up function, which you would need otherwise you will be permanently auto up / down, Then there must be some sort of sensors for the fully up / fully down positions, with cut-off. Then you gotta figure out where and how to place them, fit them and wire it all in (may also need a relay or two).
Seems a lot of effort for a trivial gain, in my opinion.
- Town: Springs
- Vehicle: Hilux 2700i
- Club VHF Licence: HC262
Piet,ek sal ook laaik om dit te doen en sommer op die ander kant ook.
- Spartan
- Town: Vanderbijlpark
- Real Name: Jaco
My vrou se RAV 4 was soos wat ons nou oor praat en ek verbeel my boet het eendag gese die trick le in die switch self, ek weet die Mazda BT50 4x4 is so want ek het n ruk met een moes ry voor hulle my n Lux gegee het.
MOBILITATE VINCERE
Spartan
Spartan
- Bushwacker
- Real Name: Piet
Ons wag nou net vir die slimmes om die fret more by die werk te lees
Ek is seker dis doenbaar
- Spartan
- Real Name: Jaco
Ek sal bietjie by Billy Hilux hoor wat se hy, daai ou laat my wonder of hy nie Hilux ontwerp het nie want hy verstaan die goed toe oe.
MOBILITATE VINCERE
Spartan
Spartan
- Bushwacker
- Real Name: Piet
Dis gaaf Jaco, wat naaaais sal wees is dat al die vensters kan toe gaan as die bakkie gesluit word :wth:
- Spartan
- Real Name: Jaco
Ek ken n n ou wat op sy kar dit gedoen het en as ek reg ont hou het hy n klein PC board gebou om daai trick te trek, sal by sy Ma hoor wa is hy en by hom ook hoor.Bushwacker wrote: wat naaaais sal wees is dat al die vensters kan toe gaan as die bakkie gesluit word :wth:
MOBILITATE VINCERE
Spartan
Spartan
- Vehicle: '96 D/C Raider
- Real Name: Bennie
EN wat sê ma?Spartan wrote:Ek ken n n ou wat op sy kar dit gedoen het en as ek reg ont hou het hy n klein PC board gebou om daai trick te trek, sal by sy Ma hoor wa is hy en by hom ook hoor.Bushwacker wrote: wat naaaais sal wees is dat al die vensters kan toe gaan as die bakkie gesluit word :wth:
- Bushwacker
- Real Name: Piet
Ja, wat sê ma
- Spartan
- Real Name: Jaco
Hou die hare boys, ek sal seker oor die naweek die auntie in die hande kry :roll:
MOBILITATE VINCERE
Spartan
Spartan
- Bushwacker
- Real Name: Piet
Kwaai Jaco
- Gertc
- Vehicle: 3.0L Fortuner
- Real Name: Gert Combrink
- Club VHF Licence: Xray05
Ok I had a look at the KZTE auto open window mechanism. The switch they use for the driver side window is totally different from the other 3 windows. If you want to convert all the windows to auto open/close you will need a extra pc board.
I would suggest getting a spare control panel and just modify the spare control. Then there should be no need to modify the wires in the door panel. The only modification should be to assure the power to the window winders stay on for longer. But that should be a small conversion.
You will need a switcth to change from auto to manual.
I thought of changing my Toyota alarm remote with a three or even a four channel remote. That way you could get added safety.
Button 1. Open only driver’s door.
Button 2. Open all the doors
Button 3. Lock all the doors and close all windows
Button 4. Lock all the doors but leave all windows 10mm open for those hot summer days.
Gert,
Is a simple drivers door auto up just a matter of changing the switch or does it also involve some high tech electronic bits?
- Gertc
Unfortunately it involves some "high tech" electronic. Toyota used a slider switch to operate a small timer circuit with a overload trip to stop the window.Thabogrobler wrote:Gert,
- Town: Springs
Gert,sal ek dieselfde skakelaar kan gebruik want dit is net outo down?
- Gertc
Yes you will be able to use the same switch. You will just have to add a extra button to change from “auto to manual” up and down.
The current switches will still be used. They will give the signal to the new controller board and the new controller board will operate the existing system.
- Town: Springs
Any idee where i can get n pc board like that?
- Gertc
The probleme is that I have to build one and sort out all the problems on it. Thats why I suggested that one should get a spare and modify the spare one. then if there is a probleme you can just unplug the faulty one and plug in the original one.
I don't like cutting wires and tampering with the wiring. that is looking for trouble.
Ok then, no 'Auto up' for me then...Gertc wrote:Unfortunately it involves some "high tech" electronic. Toyota used a slider switch to operate a small timer circuit with a overload trip to stop the window.Thabogrobler wrote:Gert,
- Gertc
Well just the other day I started closing all the windows while I was driving. The next moment my wife started speaking in some strange voice. Mmm her fingers were caught in the window.
Yes I did sleep on the couch that night.
I’m not a big fan of auto closing windows. And now I know why Toyota didn’t build it into the 4x4’s
But yes it can be done.
- Town: Springs
My simpathy for your wife,sure mine will do the same to me,but i am still interested in the mod.I will be carefull.
- Town: sydney
- Vehicle: hilux surf
- Real Name: darren
My surf has auto drivers window only
because its a Jap import it also has no pinch function to stop the window if your arm is in it,which i found out the hard way bloody hurts.
The main master switch on the drivers door has a few functions on mine
controls all windows
auto up (driver only)
window lock
key out window operation
it works in tandam with the door control relay and if the key is removed from the ignition all the windows are still operational untill the drivers door is closed.
If the master switch stuffs up it can be pulled apart and the contacts cleaned and its usually good for another couple of months.
These switches are AUD$400 new from Toyota and are the same as the switches used in the MX83 Cressida if you get that over there.
window lock
- Polarbear2008
- Real Name: Theunis
- Club VHF Licence: X49
My wife's corolla (2006 facelift) also has auto up
This would be nice, but something tells me there is more to it than just changing a relay or 2....
Monroe Gas Magnum shocks
Dual loadbox slides
Wishlist:
Alu canopy
Warn Winch
Dual loadbox slides
Wishlist:
Alu canopy
Warn Winch
