Steel head gasket for a 7M engine
- Dingo
- Vehicle: 95 4x4 DC Hilux, 7MG engine, EFS suspension, Home made custom off-road canopy.
- Real Name: Scott
Various topics and references have been made that the 7MGE and 7MGTE motors tend to blow the head gaskets and that when replacing these gaskets one should replace with a steel one for better reliability.
Can anyone point me in the right direction as to where I can get one of these gaskets.
Re: Steel head gasket for a 7M engine
Give Hoppy (Allan Venter) a call... he knows exactly what you need to get, and where to get it... (021) 982 8232
Steel!??? ... I've never heard about that .... annealed (softened) copper, yes, but not steel. Let us know what Hoppy says.
There are steel gaskets that get used for this purpose Andy. Kaspaas is fitted with a Reinz steel and copper gasket though... and the head bolts is torqued somewhat over spec. No head gasket problems..
Never too old .... we live and learn!
- Spartan
- Town: Vanderbijlpark
- Real Name: Jaco
Kry n Ajusa staal gasket en lees die installation details wat saam met hom kom, dit werk as jy lees.
MOBILITATE VINCERE
Spartan
Spartan
- Dingo
- Real Name: Scott
Hi Thys
Thank you for the help / info, I'll give Allen a call a bit later or on monday.
Just been to the engineering shop to look at why the gasket was leaking water - wasn't the gasket, but one of the water pipes at the back of the head. The head was already removed and we checked the bottom end and found that the rings and bearings need redoing , so the decision was made - redo the whole thing - so my monster will soon have a new heart.
Scott, isn't it cheaper to buy another decent condition 7MGE, I heard some say it's cheaper to just replace it??
I know that it's cheaper to replace a Lexus V8, than it is to redo the heads...
Bretton, even if this is true, it's still a better option to refurbish the existing motor provided the bores are still OK. At least then you know what you have and that everything is taken care of giving you peace of mind and trouble free motoring. With a 2nd hand replacement motor it's 'luck of the draw'.OOM_B wrote:Scott, isn't it cheaper to buy another decent condition 7MGE, I heard some say it's cheaper to just replace it??
- Dingo
- Real Name: Scott
Mud Dog, my decision was based on your thinking. I looked at just getting another engine and dropping that in, but by the time you've got the engine, changed all the belts and fitted it the pricing was about R2k' difference and for that amount I decided to go with that I knew the motor was good and peace of mind.
The bore, pistons and crank are all good and all that needs doing is a hone, new bearings and rings and the head will be totally recond.
- Gunta
- Real Name: Mark
You should look at a Cometic head gasket and a set of ARP steel head bolts.
You can get it from Turbo and Nos in Jetpark Johannesburg.
Mine has been in for 5 years now and over 150 000km
- Dingo
- Real Name: Scott
Should be getting my Baby back this weekend, looking forward to driving her again. Let you all know how she goes.
- Gunta
- Real Name: Mark
What have you done and what has cost so far? I am also looking at rebuilding mine now. I have done almost 300 000km on it now and it has started to use some oil now.
- Dingo
- Real Name: Scott
Hi Mark
appologies for the delay inresponse, I've kinda been outta the office.
Yes I got my baby back and she's running sweet. I haven't done much milage as yet, so I can't give you too much feedback.
Basically I rebuilt the whole engine.
- new psitons & rings ( rebored the cylinders to one size up)
- bearings
- complete refurbishment of the head ( re-seated the valves, new guides, skim, etc.)
- new HT leads, plugs
- steel gasket ( from Gemini Spares)
- Remove and refit engine
- The engine rebuilders felt that the water pump and oil pump was still okay, so thet didn't replace that.
With all of that, I'm sitting on R12k. The job was done by Henco Motors in Benoni.
What I have noticed, with everything all nice and new and tight that the engine temperature is now running 5-10 degrees hotter. I'll have to moniter that and if need be upgrade the radiator. I might even do this anyway, as I believe the current radiator is the original.
- bearings
- Dingo
- Real Name: Scott
300 000kms, damn that's serious milage. What do you do with the vehicle to get that milage?
- Town: Pretoria-Mayville
- Vehicle: 1992 2.2-EFI Hilux 4x4 with Maus conversion,freeflow,Rear Electric Locker'2005 BMW 320i, 2015 Hilux 3d4d dc 4x4
- Real Name: Marius
Scott,Dingo wrote:Hi Mark
- bearings
Can you please give me the contact details of the oke who fixed your bakkie?I am also thinkong of redoing my engine and the price you mentioned is not that much as I have got qoutes for,please also advise if you are happy with that guys work or did you have any problems regarding the service or quality of work?
- Dingo
- Real Name: Scott
Hi Marius
Henco Motors
17 Park Street
Benoni
011 421-8035
Dewald.
As of right now I have had no issues with Dewald in terms of service and everything seems to be working all okay. He told me that it would take about 2 weeks to do the job and that's how long it did take. I am happy so far.
I would suggest that you give him a call and go around, see him and discuss the work to be done.
Henco Motors
17 Park Street
Benoni
011 421-8035
Dewald.
- Real Name: Marius
Thanx will doDingo wrote:Hi Marius
Henco Motors
17 Park Street
Benoni
011 421-8035
Dewald.
- Dingo
- Real Name: Scott
I'm going to Bela-Bela this weekend to spectate a regional car rally and am taking the bakkie with. That should give me a round trip of about 400kms, should be able to get a nice feel of the engine.
- Gunta
- Real Name: Mark
Hi Scott, I do about 60 - 70 thousand km a year. I am an estate agent and I sell plots and farms as well so I drive alot. What size pistons did you use and what make? I am thinking of boring mine out a bit as well. I was thinking of using BMW pistons as I met a guy a few years ago at Turbo and Nos who races these engines and he uses them. I need to get a bit more info on this first before I start.
- Dingo
- Real Name: Scott
Hi Mark
I'm not too sure what pistons were used, the guys that rebuilt my engine also use to race the 7M motor in Off-road Hilux SFA, so I left all the rebuilding details up to them.
What radiator have you got fitted to your bakkie, any issues on overheating?
- Gunta
- Real Name: Mark
Nope, I have a 3 core radiator that is used in the diesel engines. It works like a charm and sits on a quarter.
- Dingo
- Real Name: Scott
Hi Mark
I assume you are refering to the 2,8 diesel engines that were in the same SFA shapes. I think the operative thing is that the radiator must have 3 cores.
- Gunta
- Real Name: Mark
I am not sure if it came from the 2.8, but you must definitely use a 3 core. I have no issues with cooling. I have been runing this conversion for 6 years now.
