1uz to Toyota Gbox (G,W series)
- BlumTRD
- Town: South Africa
- Real Name: David
Made some adaptors
Laser cut
Cnc Drilled
Tapped
Twin plate (self centering )
because the other adaptors are single plate
incl gbox bolts and bell bolts
I use howe trowout bearings
but if you want to run std clutch fork etc
i can weld the stud on for your pivot pin
R590 each
NOTE 1U not 2U bellhousing
Laser cut
Cnc Drilled
Tapped
R590 each
Re: 1uz to Toyota Gbox (G,W series)
David, please excuse my ignorance... but is this adapter plate used for mating the lexus bellhousing to a non-standard(non-lexus) autobox??
- BlumTRD
- Real Name: David
Hi Mr B
The adaptor are for the manual box(s)
Yn Hilux old shape
And
98-05 Hilux
But I can make the adaptor
For R154 (supra box) , R151 , R150
Kzte box
And new big box for D4D and 2.7
Yn Hilux old shape
And
98-05 Hilux
Kzte box
- AM Racing
- Real Name: Dylan
I have the D4D. How reliable is the throw out bearing vs the oem external clutch slave and what clutch would be used with this set up?
David, soos gewoonlik lyk jou goed baie netjies en dis billik geprys!
Vertel bietjie meer vir die dommer ouens(soos ek) wat is 'n throw out bearing en wat is daai braided pyp wat bo jou ratkas uitkom?
En watter ratkas gebruik jy nou op jou Hilux?
Tx David, again another question for clarity(for me)... this adapter allow you to use the std 1UZ bellhousing and mate it to the SFA manual box??
I know the guys usually use a totally different bellhousing to match the 1UZ to the manual box. If I'm correct what are the benefits of going the adapter route over the whole bellhousing?
- AM Racing
- Real Name: Dylan
My concern with the complete bellhousing is the quality. If its not made right it can be skew and cause damage and it can crack. Provisional pricing of the bellhousings is around R2500 depending who you get it from. So R590 is a great option. Flywheels around R2400. SO: That is almost the price of a motor :wth:Mr_B wrote:Tx David, again another question for clarity(for me)... this adapter allow you to use the std 1UZ bellhousing and mate it to the SFA manual box??
- BlumTRD
- Real Name: David
AM Racing wrote:I have the D4D. How reliable is the throw out bearing vs the oem external clutch slave and what clutch would be used with this set up?
All parts on Howe Trow out can be replaced
o rings etc
But the guys in States and Aus doesn't have props with them
As to Clutch ... 2.7 Hilux or Old supra or 3 Ton Dyna Truck
all depends on the flywheel .
Mr BAM Racing wrote:My concern with the complete bellhousing is the quality. If its not made right it can be skew and cause damage and it can crack. Provisional pricing of the bellhousings is around R2500 depending who you get it from. So R590 is a great option. Flywheels around R2400. SO: That is almost the price of a motor :wth:Mr_B wrote:Tx David, again another question for clarity(for me)... this adapter allow you to use the std 1UZ bellhousing and mate it to the SFA manual box??
my current box are a frankenstein (Old series) R154 with sfa R1fa case transfer (both top shift) running duals .
All Sfa Hilux can bolt up with these adaptor
The reason i'm prefering these adaptors are that the cast Belhousings
From suppliers around does have weak spots , crack , skew etc
Thats why i trust the factory auto belhousing
And its cheaper
Thabo
Dankie Ek sit maar bietjie elbow gries in
- Gunta
- Real Name: Mark
Very nice option
Makes serious sense! One day when I'm in a position to go the V8 route I'll get some from you David...
- Vehicle: HILUX,CRUISER,FORTUNER
- Real Name: ALEX
David kan ek daai thrust bearing met die pype by jou koop ek wil graag daai sisteem op my bakkie sit. en prys asb
- Gunta
- Real Name: Mark
David, just a stupid question. By putting in an adaptor plate doesn't it prevent the the spigot from going in deep enough by the thickness of the plate?
- Town: JHB
- Real Name: Derrick
Nice way to go. Myself I would stick to the internal throw out thrust bearing instead of cutting a gap out the side of the bell to
get the fork thru. You say that you can mate it to a W range box ? My understanding is that the R range box has a longer spigot shaft
and enturn alows for the thickness of that plate. Myself I would not go for a W range box behind a V8, I think the gears will land up in the prop shaft in a few days time.
V8 SOLID
- Evert Deyzel
- Vehicle: 94 Hilux DC 2.2
- Real Name: Evert
+1Gunta wrote:David, just a stupid question. By putting in an adaptor plate doesn't it prevent the the spigot from going in deep enough by the thickness of the plate?
92 Hilux dc 2.2
MikeM suspension with 50mm lift
- BlumTRD
- Real Name: David
Evert Deyzel wrote:+1Gunta wrote:David, just a stupid question. By putting in an adaptor plate doesn't it prevent the the spigot from going in deep enough by the thickness of the plate?
Just an example ,
my old 3rz belhousing are alot deeper
and the auto belhouseing 10.225 shallow
So the the plate 10mm ensures that the spigot still sits in the same
- Evert Deyzel
- Real Name: Evert
So correct me if I'm wrong.
What you are saying is that the "total depth" of the lexus bellhousing + the adapterplate is the same as the "total depth" of the standard sfa bellhousing?
Evert
Evert
92 Hilux dc 2.2
