Overlanding SFA Engine Conversion?
IndianaJones7746
Town: Citrusdal
Vehicle: 84 SFA Hilux
Real Name: Ben
Thu Sep 08, 2011 10:22 pm
Hi guys
I'm sure this topic have been dealt with to death, but I'll appreciate it if you'd humor my question.
If you were to do an engine conversion on an overlanding SFA Hilux, which engine would you choose?
The criteria is as follows:
Must be a Toyota engine
Must be fitted to a manual gearbox
Must have more power than an EFI 4Y(2.2L) or EFI 22R(2.4L)
Fuel consumption of at least 8km/l when cruising at the national limit, fully loaded with overlanding gear.
Must be reliable, as it will be used in remote places.
So, what will it be? 3RZ-FE, 7M-GE, 1JZ-GE, 2J-GE, 2L-T, KZ-TE or something else?
And if it is an EFI engine, which management system would you recommend? Dictator, Go-Tech, etc?
Thank you
Fri Sep 09, 2011 3:18 am
Hi Ben, sorry can't give you one direct answer, but if the vehicle is say going to travel through Africa I would considder the the following:
- Availability of spares of the enjines mentioned above
- Which of these enjines are commonly found
Consumption of the enjine would be of concern but no longer the main priority
jm2cw :thumbup:
zepplin
Vehicle: GX Cruiser
Real Name: Steve
Club VHF Licence: HC 127
Fri Sep 09, 2011 6:54 am
You'd have to go the diesel route to get that consumption under those conditions.
Cruzer GX 80 1hz Manual
Cruzer VX 80 LTD 1hd-ft auto
ThysdJ
Club VHF Licence: HC102
Fri Sep 09, 2011 7:15 am
Hi Ben,
First of all define "Overlanding", or at least what you mean by that. Into Africa, or around the corner to a trail/national park 200km's away?
I have to agree with Mark. If you want to go into Africa, keep it as low-tech and standard as possible.
GeorgeJvR
Town: Louis Trichardt
Vehicle: 2008 Prado 4.0 V6, 1989 SFA S/C 2.2
Fri Sep 09, 2011 7:38 am
What do you want to spend?
Kom wat wil ek bly 'n Bul!
IndianaJones7746
Town: Citrusdal
Real Name: Ben
Fri Sep 09, 2011 7:57 am
Thanks for all the replies thus far guys.
With "overlanding", I mean I'm planning to travel with tour groups into our neighbouring countries (Namibia, Botswana, etc), not to travel to Tanzania, or Egypt.
I'm able to do most of the conversion myself, and could go up to R18000 for the engine alone.
zepplin
Vehicle: GX Cruiser
Real Name: Steve
Fri Sep 09, 2011 8:01 am
A normally aspirated diesel will give you the consumption but not the speed. 3L or 5L.
SuidWes
Town: Durbanville
Vehicle: Prado 120 VX
Real Name: Jaco
Club VHF Licence: B35
Fri Sep 09, 2011 8:20 am
Personally don't like conversions.
Only way te get close to your requirements would be to fit a Mazda Diesel :oops: - Speak to Hoppy. Beleive me the engine looks like it was designed for the SFA.
Stef
Vehicle: '98 LTD
Real Name: Stefan
Club VHF Licence: X107
Fri Sep 09, 2011 8:27 am
All the engines will have some risk ascociated with it. Stock 4y or 22R will be most reliable.
If you have to do a conversion, I would go 7M or 2JZ (if VVTi std ECU is a must). Both of these will fit to the std W56 gearbox with proper bell housings and no adaptor plates AFAIK. Don't think the 1JZ will give better consumption with a huge load :think: Might be worthwilw to carry a spare mapped ECU & HP pump on a trip.
Rebel 4x4
Town: Port Elizabeth
Real Name: Thomas
Fri Sep 09, 2011 10:17 am
Stick to the plain 4y, you can take the engine apart and put it back yourself in the middle of nowhere! :laugh2:
Sent from my iPhone
Thabogrobler
Club VHF Licence: x223
Fri Sep 09, 2011 1:33 pm
Sorry but not all of your requirements are obtainable in one package - Buy a new 3.0 D4d and then you MIGHT get close!
IndianaJones7746
Town: Citrusdal
Real Name: Ben
Fri Sep 09, 2011 6:23 pm
Thanks again for you input guys
Would a 5L give better fuel consumption than a KZ-TE, under those conditions?
If I go for a 7M or 2JZ, what would be the best fuel consumption I could hope for, also fully loaded at cruising speed?
Also, who sells standard ECU's for 2JZ motors?
I'd really like to build a SFA Hilux to tour with around Namibia, and then when I get to Luderitz or Walvis Bay, be able to climb dunes with the best EFI Cruisers.
kfxnando
Town: Germiston
Vehicle: Ford V6 3.4 Courrier soon to be powered by Yamaha!! Jeep GC 4.7 V8, Aygo broken traded for a Kia Picanto.2ex, 2012 Jeep GC 5.7 V8 Ovrrland
Real Name: Fernando
Fri Sep 09, 2011 6:32 pm
Thabogrobler wrote:Sorry but not all of your requirements are obtainable in one package - Buy a new 3.0 D4d and then you MIGHT get close!
there is your answer right there.
however would like to add that any conversion if done properly can be reliable.
in my Sierra had a Toyota gearbox, and had no problems with the conversion, must of easily done well over 100 000, and those days I was heavy on cars, and it was all done at home.
if done properly you could have the motor in the back and use the front as packing space and still be reliable IF done properly
all depends on your needs and what you willing to spend
good luck
gert-redelinghuys
Town: polokwane
Vehicle: 1996 hilux 2.4 4x4 dc raider rear locked 31 maxxis bighorns 2 inch lift
Real Name: gert
Fri Sep 09, 2011 7:01 pm
I am going to apologize beforehand , I am sorry if stepped on your toes . here is my 2cw , 1 I will the current motor do some tuning and some head work spend a few grand and keep the rest for petrol money , in any case a sfa is his happiest @ 90 to a 100 your on holiday not late for a meeting ... sure all of us would love a Lexus v8 ticking away in a hilux but you want to keep it as simple as possible , there aren't many auto elec between luderitz and walvis , simplicity is the way to go . so there is my 2cw "simplicity is the ultimate sophistication" as da Vinci would've said
Last edited by gert-redelinghuys on Fri Sep 09, 2011 9:46 pm, edited 1 time in total.
lock and crawl
niks loop soos `n john deere nie , behalwe `n hilux bakkie met `n john deere sticker agter op die bak
Rebel 4x4
Real Name: Thomas
Fri Sep 09, 2011 9:04 pm
gert-redelinghuys wrote:I am going to apologize beforehand , I am sorry if stepped on your toes . here is my 2cw , 1 I will the current motor do some tuning and some head work spend a few grand and keep the rest for petrol money , in any case a sfa is his happiest @ 90 to a 100 your on holiday not late for a meeting ... sure all of us would love a Lexus v8 ticking away in a hilux but you want to keep it as simple as possible , there aren't many auto elec between luderitz and walvis , simplicity is the way to go . so there is my 2cw
Totally agree! :thumbup:
Sent from my iPhone
ThysdJ
Fri Sep 09, 2011 10:51 pm
You are chasing the holy grail here. You want good consumption at speed (120 - 140), fully loaded, and good power to climb dunes. Aint gonna happen, not in a brick-shaped Hilux weighting close to 2 tons.
I have a 7MGE Hilux and with a RTT on and fully kitted for 3 weeks overlanding trip the best I could manage was 7.2km/l at 90km/h. The moment you go over 100 the wind resistance sucks your wallet dry.
It goes like this.... You want power, you get power. Once you got it, you will use it. Once you got used to it there's no going back and there goes the consumption out the window. :twisted: :twisted: By all means fit a more powerful motor if you want to, they are fun. :thumbup: :thumbup:
Sat Sep 10, 2011 8:25 am
I would also stick to standard but if you decide to divert from the standard motor and opt for a conversion I would personally look hard at a lexus V8 .... plenty power, low end as well and the motor is fairly cheap. Also the block is aluminium, not iron ... much lighter than the straight 6's and not much more weight than the 4Y (will save your front suspension). Where the cost will come in is the conversion itself. Remember also that with conversions which deliver more power, the drive-train should be upgraded as well ... more bucks. ;-)
IndianaJones7746
Town: Citrusdal
Real Name: Ben
Sun Sep 11, 2011 6:22 pm
OK, thanks guys.
I appreciate your insight.
FIRSTGEER
Town: King WilliamsTown
Real Name: Tony Geer
Club VHF Licence: HC 109
Sun Sep 11, 2011 9:06 pm
Hi there.I am driving my 5th hilux sfa which is a non turbo 2,8 diesel.Not very fast but bullet proof and get about 8,5 km/l.I fitted a 7mge to previous sfa and it performed well but was too powerfull for the drivechain.Gearbox and diff problems occured. Keep the vechile standard for very far away overlanding trips.Less hastles and cheaper too.Thats my 2cents worth.Happy overlanding.
