Driving a Hilux 2007 Double cab pick-up. Bought it secondhand here. It seems the right front side keep on touching the body when we go through a pothole.
any ideas what i can do?
Lifting the front of Hilux 2007
- JacoSom
- Town: Machadodorp
- Vehicle: Toyota Hilux dcab d4d 4x4
Jaco Lourens
- AmadaXtreme
- Town: Centurion
- Vehicle: Fortuner d4d 4x4
- Real Name: Cobus
Re: Lifting the front of Hilux 2007
Could be only the shocks that needs replacement or is the front lower than the back? Remember if the shocks are worn, the vehicle will bottom out alot quicker.
You can fit coil spacers to lift the front, but if fitted with aftermarket bumper and other accessories I would rather recomment to fit an upgrade front spring to raise the vehicle and a good performance shock
AmadaXtreme Cobus 071 641 7947 or Rory 072 759 2926
Suspensions
Suspensions
- Town: gauteng
- Vehicle: hilux
- Real Name: mark
phone maugene engineering in pretoria they do the spacers to lift the front
