enige raad sal wardeer word
Sorry man... het net gedog ek vra. My kennis is ma beperk tot petrol motorsSKRIK NIKS wrote:hello cassie
ek glo nie so nie ,want sac stel voor om n free flow op te sit as jy die chip op het
R1300 klink goedkoopSKRIK NIKS wrote:i have spoken to scorpion exhaust is krugersdorp,they ask R1300 for a stailes steel pipe from front to rear
if there is any one that done this on a dielsel enjine and has expirence any deffrence please let me know!
Yip!krazy_kameleon wrote:I paid R850 for mine with freeflow box but it was in mild steel as they had no stock
R1300 sounds like a bargain!
dont forget to put a security gate on the end to stop the skwatters from moving in...louis fourie wrote:Jan
Ek het gehoor 'n free flow sal ook 'n laer EGT tot gevolg hê. Ek het pyp grotes gehoor van 76mm. Enige kommentaar
Tx Andreandrevt wrote:kontak henk by SAC vanderbijlpark, gebruik my naam ,die nuutste mod op my D4D is puik 0169339972,
Heinrich, ek verstaan nie jou opmerking nie. Hoe hoor die druk, hoe minder die lug vloei of verstaan ek dit verkeerd?Traveler wrote:Maak seker al die buigstukke is lekker gelyk en verkieslik stadig. Nie 90Deg draaie nie.
Moet nie te veel soek van oversize pype nie, anders gaan jy nie genoeg druk in die pype kry om die turbo te spin nie.
76mm is perfect for the 3CT - I was going to fit that to mine with the top mount intercooler from the 2.8 mitziMOFASA wrote:Thanks for all the info as i need to change mine soon so will be going for the freeflow now....![]()
I must humbly disagree, you do not need to scavenge on a boosted engine.Traveler wrote:Maak seker al die buigstukke is lekker gelyk en verkieslik stadig. Nie 90Deg draaie nie.
Stem nie saam met wat nie??krazy_kameleon wrote:I must humbly disagree, you do not need to scavenge on a boosted engine.Traveler wrote:Maak seker al die buigstukke is lekker gelyk en verkieslik stadig. Nie 90Deg draaie nie.
You only need enough pipe after the turbo to convert the radial flow of gas to axial, that can usually be acheived rapidly through a reduction in diameter or an abrupt change of direction (eg 90deg bend) as soon as possible after the exhaust housing
Nay, dis interessant die verskillende opinies, nog asbblom wrote:![]()
liewe aarde ouens
dis nie 'n blerrie "racies" trok nie
dis 'n "budget" free flow op 'n kz
jan bou die ding van 63mm (bang for buks)
Definately not :!: Just interesting to hear differnt views on the matterkrazy_kameleon wrote:Mark, are you trying to start a war between Heinrich and myself??? :wth:
Blom, I fitted the 63 to my Ssang Yong Moose for exactly that reason. (see earlier post)
R850 bucks - 63mm mild steel from turbo back with a single 63mm freeflow box at the back
Nice sound, nice power
( and the budget shop I was at didn't have the tooling to bend 76mm or I would have done it)
