So I have started with the big job and I have a couple of questions, any/all assitance help would be greatly appreciate, Mark has already given me some advice thats going to help, Thanks Mark.
I have the standard SFA.... Have cut off the original 4y brackets on the chassis legs and placed the engine in without the headers (exhaust manifolds - original)
Have gone the route of manual with the moulded bellhousing.
1. The Hand brake bracket is a problem, had to take it off, engine push's up against the firewall, it this correct, do I need to move it?
2. Other head is very close to the other side firewall
3. Using original engine mounting brackets with smaller round rubber mountings.
4. Sump, Steering arm and alternator are VERY close to the chassis, sump is almost touching.
5. Very worried that the Original Manifolds are going to catch on the chassis legs.
I'm I doing something wrong? Do I have to do a body lift and how much.....
As mentioned, any help, assistance, suggestions would help, I have attached a couple of pics to illustrate my hickups.
![Beg :beg:](./images/smilies/beg.gif)
