SFA Turbo Diesel Conversion
IndianaJones7746
Town: Citrusdal
Vehicle: 84 SFA Hilux
Real Name: Ben
Post by IndianaJones7746 »
Hi
I want to convert my work-"donkey" 2.4D SFA Hilux to Turbo Diesel, and want it to keep it an all Toyota conversion.
Which of the following engines would you recommend:
1. 3C-T (2.2TD import)
2. 2L-T (2.4TD import)
I believe they are getting very scarce, which is a negative. But since there is a 2L (2.4D) currently in the bakkie, it should make the conversion to 2L-T easy.
3. KZ-TE or KZ-T(mechanical fuel pump from 2.8D 3L)
4. Obviously a 2.5 or 3.0 D4D would be great, but how difficult and expensive is such a conversion these days?
Where is a good place to source any of these engines?
Thanks very much
Please don't recommend a petrol engine or a Mazda 2.5TD.
Re: SFA Turbo Diesel Conversion
Post by Thabogrobler »
Hallo Ben,
1&2 - Amost impossible to get from the importers and if you can get, R12k+
3. My first choice
4. Ok, 3.0(1KD) will be my rel first choice but can easily set you back R34-40K - you might have to upgrade the gearbox aswell?
In my yard there is currently an SFA with a 2L-T motor in, it needs some attention, but it is not a rocket!
Good luck!
doppies
Town: keetmanshoop
Vehicle: toyota , land rover
Real Name: willem
Club VHF Licence: no
Post by doppies »
Why diesel ?
doppies wrote:Why diesel ?
Propably on a farm?
Farm = Diesel (almost) always available!
IndianaJones7746
Town: Citrusdal
Real Name: Ben
As Thabo says, always have diesel on the farm, and buy it directly from the depot.
