prop shuddering
- Town: lydney gloucestershire
- Vehicle: toyota hilux
- Real Name: jamie grindle
prop shuddering
hi i have a mark two hilux with a V8 fitted.
when i pull off in either reverse or forward it shudders.
my mate stood behind and said it is the prop shuddering.
once i get going it is fine.
i have had a new prop shaft centre bearing and new universal joints fitted but it still does it i have had the truck lifted slightly.
if anyone can help me it would be much appreciated.
thanks j
thanks j
Re: prop shuddering
According to my knowledge that doesn't sound like the propshaft causing the problem. If it was the prop it would have continued doing that in higher revs as well.
How old is your clutch? If you pull away in second does it also shudder?
- Vehicle: 2018 FJ Cruiser
Re: prop shuddering
Bananarama! Welcome.. it sounds like a slipping clutch problem to me too...
email: thysdj@gmail.com
- Scooter
- Town: JHB
- Real Name: Scott
Re: prop shuddering
Welcome Bananaman :!: May your stay be an experience and you experience be why you stay :!:
I will have to jump on the wagon here and say I reckon your clutch is shaped like your name, banana style
- Okkie Van Wyk
- Town: Middelburg
- Vehicle: 2011 Hilux 3.0 D4D D/C
- Real Name: Okkie
- Club VHF Licence: N019
Re: prop shuddering
Hi bananaman
Welcome here on the Best 4X4 forum by far
You say it is the same shape as the KZTE?
Had the same problem when i had the prop on my 2.7i replaced .The people made up a new shaft without the "Double Knuckle" and it shuddered from the start .but just at pull away and some times as you dropped the clutch for second .after balancing it several times the "knuckle" was put in and it was fine ever since
Hope it helps
Okkie
Hope it helps
Okkie
123 WEG MP
2011 Hilux Vigo 3.0 D4D D/C
VENI VICI VIDI
CAME, I SAW, I CONQUERED
VENI VICI VIDI
- Scorpion
- Town: Emmarentia
- Real Name: Johann
Re: prop shuddering
Welcome, Bananaman! Post some pics of your ride man.
1978 Land Cruiser HJ45
Re: prop shuddering
What Bell Housing have you fitted
When I researched the bigger engine conversions, a generic bell housing kept coming up as "a cause of shudder"
Only an original OEM was the answer
Hope this helps Jamie
Rich
(ex Yorkshire/Buckinghamshire/West Sussex Inmate)
Rich
- Hiluxdave_nz
- Town: Christchurch New Zealand
- Vehicle: 95 2.8 turbo d/cab hilux with a soild axle conversion ,diff locks,high steer falcon spring rear end
- Real Name: Dave
Re: prop shuddering
you mite have a bit of diff wrap running a v8 it can happen .
have a look at the snake racing version http://72.34.32.141/~snakerac/product_i ... 9d7d5316e9
my mate put one in his hilux "not a snake racing one" but made one out of two jonny joints and tube and he said it make heaps of difference in reverse no shudder and smother take off. or you clutch is stuffed or a g/box or engine mount could be stuffed .
- Hiluxdave_nz
- Real Name: Dave
Re: prop shuddering
your diff ratio could be a bit tall/high do you know what u have.
- Hiluxdave_nz
- Real Name: Dave
Re: prop shuddering
have a look at this this is on a old cruiser
- blom
- Town: Landrovia
- Vehicle: xj jeep & SERIES 3 & Isuzu KB 300 Dtec DC
- Real Name: Blom
Re: prop shuddering
Banana man now that you hanve all the opinions in the world as to your shudder let old blommie tell you what is wrong
1 check your gearbox mounting she is loose.
2 check your torq side engine mount she is loose
now quickly fix and thank me later (send some over the sea beer this way)
regards
blom
Grensvegter van LANDROVIA
Re: prop shuddering
Blom blom ... he's our man.... if he can't do it... we'll find someone that canblom wrote:
regards
blom
- Suli
- Vehicle: Hilux SFA & Vigo D4 D
- Real Name: Suleiman
Re: prop shuddering
I get that same sHaKeS :? in reverse and more when going up an incline...
So i will check all of the above.... Scweet
- Vehicle: '96 D/C Raider
- Real Name: Bennie
Re: prop shuddering
Ja as Blommie said ist check the mountings on the engine and GB. If that is fine, then check your prop to ensure that the slip joke is aligned properly so that the universal joints line up, if not pull the slip joke apart and rotate so that the UJs line up before reassembling it.
Is your gearbox not maybe facing upwards to the rear as a result of the conversion so that the angles on the UJs are too big? If so dropping the rear of the gearbox and sometimes the centre bearing if you have a high rear suspension lift to minimize the angles on the UJs may also help a bit.
