Building a trailer?!?!
- Pote
- Town: Hartbeespoort
- Club VHF Licence: X228
Hi all the Hilux people
I want to find out from all the know how here.....
Is it possible to build your own trailer and have it registered. I have heard that you may not do this any longer...
Is this so or are there a procedure you have to follow when wanting to do this....
- Obelix and Dogmatix
- Town: ROODEPOORT
- Real Name: Quentin
Re: Building a trailer?!?!
Pote
As far as I know to get a 'built from scratch 'trailer registered you have to get SANS approval etc. You best bet would be to take a registered trailer and to build on the registered chasis what your needs are.
must highlight that the above is what I have heard from others.
Obelix
Obelix
God made man before
woman so as to give him time
to think of an answer
for her first question.
God made man before
- Town: Citrusdal
- Vehicle: 84 SFA Hilux
- Real Name: Ben
AFAIK you are allowed to home build a trailer with a payload of up to 750kgs, any more and you have to be a registered trailer builder.
But others here might know better.
- Pote
750 kg should be enough for a off road trailer. Shouldn't it?????IndianaJones7746 wrote:AFAIK you are allowed to home build a trailer with a payload of up to 750kgs, any more and you have to be a registered trailer builder.
- Bliksempie
- Town: Pretoria Montana
- Vehicle: 2.4 SFA
- Real Name: Robbie
- Club VHF Licence: HC115
Johan,
Ek het self een gebou en 'n 1.5t (Braked Axle) ingesit. Die sleepwa was in die omgewing van 500kg toe ek hom verkoop het. Ek moes nog die rail systems en kombus gedeekte inbou... So, ek sal eerder voorstel dat mens kyk na 'n groter gewig en sterker as. Dit hang natuurlik af van hoe groot jy hom wil maak. Met die tong in die kies, gaan ek wel noem dat ek die "nie so wettiglike" manier gevolg het, en deur 'n kontak ekstra betaal het om hom op die pad te kry.
- Attachments
- Trailer 2.jpg (41.13 KiB) Viewed 2076 times
- Trailer.jpg (53.09 KiB) Viewed 2076 times
- Toppie4x4
- Town: Centurion
- Real Name: Andre
Ja die maklikste is om n ou sleepwa te koop en dan oor te bou. Ek gaan my challenger se 2.5 ton as vervang met een wat remme het, sou jy belangstel in die as laat weet. Dit het die gewone ses gat hubs, wat dieselfde is as n hilux. Andre
- Town: Citrusdal
- Real Name: Ben
Having a 750kg payload does not mean you have to use a 750kg axle, you can use heavier duty items.
It just means that if they do pull you off at a weighbridge, you should be within that limit.
Just remember to keep all slips of parts you acquired with the build, the traffic department will ask for it.
Your local traffic department should know the procedure, at some point you will need the police to assign a number to the chassis, the trailer will have to go through roadworthy, etc, etc.
- jacques kotze
- Town: Nelspruit
- Real Name: Jacques
I have a half build 5,5m trailer with brand new brake axles, coupler, parking jacks and all the rest. Just to find out the law has changed and you can't register it if it is homebuild. Just paid for a 6m double brake axle. I just ordered the chassis/frame - 6m frame, no loadbed/deck,no paint, no sides or anything. Just the axles, rims and tyres, coupler, lights & wiring and data dot with papers from a registered trailer builder. Paid R29 800 incl.
As far as I know, you cannot register a home-built trailer any more. What you can do is to either follow the route that Jacques was forced to (as above) or you can approach a registered trailer builder and ask if he would be prepared to register it for you. Most often they will not because that's their business, they will probably suggest you give them your custom requirements and they will build it. Remember that they become the registered manufacturer and should something go wrong (like an A-frame snap), resulting in an accident with loss of life the finger will point at them. They could loose their registration.
If they are prepared to do it, they will more than likely want to first inspect the trailer for competent welding, material adequacy and integrity of design. For this they will probably charge you heavily, almost as much as if they had built it themselves, so it's not really worth it.
Another option is to buy a cheap old dilapidated / rusted trailer that's already registered, one that has a registered load capacity suitable for your requirements and either use the axle and base or build a new base for it. If the old one had a plate with chassis number on it, just transfer that to the new base - or if there was a number stamped into the chassis, then stamp that same number into your new chassis. I'm not too sure about this, but if it's a relatively new trailer (first year of registration) then beware because it could have been photographed at registration and that photo goes into the e-natis database. If your rebuild does not resemble the original, you could have problems if they ever have reason to check.
The issue is with the welding - registered trailer builders use coded welders (or are supposed to)
EASIEST would be to get a "rolling chassis" from a registered trailer builder, then build what you want ontop of it ....
go for a braked axle from the get go.
Check your tow vehicle and use this for the weight limits of the trailer - DONT exceed this or you are asking for trouble at a weigh bridge.
- Pote
Thanks for all the input...
I know the guys around the corner from me that builds trailers.. I will ask them....
- Stef
- Vehicle: '98 LTD
- Club VHF Licence: X107
My little 4 footer was photgraphed at the pound; had to get a new chassis number issued & stamped as the old serial number was too short.Mud Dog wrote: I'm not too sure about this, but if it's a relatively new trailer (first year of registration) then beware because it could have been photographed at registration and that photo goes into the e-natis database. If your rebuild does not resemble the original, you could have problems if they ever have reason to check.
Whether the pics go into e-natis I dunno, there is an Audi driving the e-toll roads with my trailer's plates...
- louis fourie
- Club VHF Licence: X101
StefStef wrote:My little 4 footer was photgraphed at the pound; had to get a new chassis number issued & stamped as the old serial number was too short.Mud Dog wrote: I'm not too sure about this, but if it's a relatively new trailer (first year of registration) then beware because it could have been photographed at registration and that photo goes into the e-natis database. If your rebuild does not resemble the original, you could have problems if they ever have reason to check.
Same probem here. I have a truck driving with my trailer's plates:mad:
