KZTE Brake problems
- pietdevs
- Town: Mosselbay
- Vehicle: Toyota Land Cruiser Troopy
KZTE Brake problems
I have a 4x4 KZTE with ABS brakes. When I do approx 70km/h and brake there is no brakes. This happens every now and again. Any suggestions on what is wrong pls?
Re: KZTE Brake problems
Sounds like the master cylinder seals need to be replaced
- SKRIK NIKS
- Town: krugersdorp
- Vehicle: hilux 3.0kzte
- Real Name: jan venter
Hello Pieter
Dit het al met my gebeur ,kyk na jou voorste wheel bearings ,hulle kom los ,en dan druk die brake discks the psitons op die calipers terug ,en as jy trap dan is darr niks ,maar as jy weer trap dan is die brieke reg vir n rukkie
Ek hoop die info help
SKRIK NIKS
- Hoppy
- Vehicle: Hilux SFA & IFS
- Real Name: Allan 0721291160
Explain "no brakes"
Does the pedal go to the floor with no resistance?
Does it go halfway?
Does it stay hard, but doesn't stop?
Does it go halfway?
aev@iburst.co.za
- Town: Centurion Gauteng
- Vehicle: Mazda Rustler 16v
- Real Name: Jan
If the pedal stays hard but no effect on braking the ABS actuator is faulty just remove the ABS relay and the braking system will be like normal brakes without ABS
- pietdevs
- Town: Mosselbay
Thanks for all the info. Some days I realise how valuable the forum is! I will do all the checks. Where is the ABS relay situated?
The brakes are hard when I step on it with no brakes.... I went through the exercise of bleeding the brakes to check for air but it is ok.
- pietdevs
- Town: Mosselbay
The brakes stay hard but does not stop - and then it works again.
- Dingo
- Vehicle: 95 4x4 DC Hilux, 7MG engine, EFS suspension, Home made custom off-road canopy.
- Real Name: Scott
pietdevs wrote:Thanks for all the info. Some days I realise how valuable the forum is! I will do all the checks. Where is the ABS relay situated?
- pietdevs
- Town: Mosselbay
Where is the ABS electrical plug situated? I want to disconnect and start here...
Look in engine bay, on the 2.7 it is on the steering wheel side close to the firewall. It is clearly marked ABS. Just pull the relay out.
Not sure if it is located at the same place on KZ
- Real Name: Jan
Small black box with two relays in on driver side in engine compartment near the brakebooster
