Diff klap
- Town: Durbanville
- Vehicle: 2009 Toyota Hilux DC 3.0 D -4D 4X4
- Real Name: Ben
- Club VHF Licence: HC 136
Diff klap
I drive a 2009 Hilux DC, 82 000Km on the clock.
When I change gears and let the clutch go the diff makes a clap sound , this is when the drive-shaft grips in the diff I suppose. Is this normal for a Toyota? At times I drive the work Nissan NP 300 bakkie and it does not make that sound , the change over is smooth.
- Obelix and Dogmatix
- Town: ROODEPOORT
- Real Name: Quentin
Re: Diff klap
I had a similar feeling when pulling away (automatic) is was my propshaft and centre bearing that was tired.
God made man before
woman so as to give him time
to think of an answer
for her first question.
God made man before
- Town: Durbanville
- Real Name: Ben
Re: Diff klap
Nie op 82 000km nie.
- Hangover
- Town: Deneysville
- Real Name: Stef
Re: Diff klap
Maklik op 82000km... Dit hang net af of iets al die propshaft gestamp het...Whisky wrote:Nie op 82 000km nie.
Hangover(A.K.A die speelding)
1976 FJ45 4x4
1UZ-FE 4.0vvti
2" OME Suspension lift
1.5" Shackle lift
35" Geo MT's
Custom Bullbar
Lockright Locked rear
York OBA
20" LED bar
Nighthawk 100W spots
Dakar
2013 3.0D-4D 4x4 Hilux Dakar
1976 FJ45 4x4
1UZ-FE 4.0vvti
1.5" Shackle lift
35" Geo MT's
Custom Bullbar
York OBA
20" LED bar
Dakar
- Masekind
- Town: Lichtenburg
- Real Name: Drikus
Re: Diff klap
Ag nee ek dink ek sit met die selfde ding dit is seke nog n odd R3000+
- Toppie4x4
- Town: Centurion
- Real Name: Andre
Re: Diff klap
agree check the hanger bearing
- Town: ROODEPOORT
Re: Diff klap
MOET DIT NET NIE TOYOTA TOE WAT NIE!!!!!
Myne was in December reg gemaak vir onder R1500 as ek reg onthou dit was 3 nuwe univesal joints en die centre bearing, eerder dit as om die diff te overhaul. sterkte julle
God made man before
God made man before
- Masekind
- Town: Lichtenburg
- Real Name: Drikus
Re: Diff klap
Waar het jy parte gekoop ek het al gehoor die pirate centre bearings hou nie en Toyota vra by R1000 en die universal joints seke ok daar rond.
Re: Diff klap
It's easy enough to check if it's universals, centre carrier bearing or diff back-lash - just get in under there (you have enough clearance without the use of jacks, Ben), and check it by hand. First in neutral and start at the diff, turning the prop ecah way checking for play in the diff, then each uni one at a time. If you don't find any play after the last uni, put it into gear, lift the rear tyres off the ground and check the play from the gearbox / x-fer box.
Hopefully it's just one thing, but it could be a possibility of it being a combination of a little play in each (worst case). IMO it will rarely be the carrier that's at fault for your symptoms, but check it for sideways play at the same time - up / down as well as sideways. It should move about 2 to 3 mm either way, but the movement should feel firm, not sloppy.
- Town: Durbanville
- Real Name: Ben
Re: Diff klap
Dankie vir al die kommentaar.
Andy ek sal die naweek onder in kruip en mooi ronddraai. Ek het nog nie sulke slegte paaie of roetes gery dat ek die onderstel gekap of geskraap het nie.
Die klap kom al van lankal af.
- Toppie4x4
- Town: Centurion
- Real Name: Andre
Re: Diff klap
Beste is om hom te vat na die manne wat die propshafts reg maak, hulle haal hom vinnig af en toets hom voordat hulle quote.
