I have just completed a timing chain replacement and when I got everything back together I noticed there was no electricals, (dash lights etc, failed to come on). Found a lug on the negative earth wire that leads directly to the fender panel was worn, so replaced that. Lights come on in dash, engine turns, but feels as though the battery is flattish. Battery is not flat, with 12v at battery terminals and also when measured earthing to the block. Voltage is a lot lower when earthing to a panel. Also, when trying to start the earth wire from the negative terminal to the side panel begins to overheat & smoke.
Does anyone have any idea as to what could be causing this???????
Electrical (earth?) problem 1994 22r
- Town: Meyerton
- Vehicle: Hi-Lux 4X4 93'SFA
- Real Name: Abraham
- Club VHF Licence: X32
Re: Electrical (earth?) problem 1994 22r
Replace the earth from the body to engine or better take it from the battery to engine.
- Town: Gormanston
- Vehicle: Hilux 2.8D
- Real Name: Taz
The main earth from the battery to the engine seems fine, it is showing exactly the same voltage as there is across the terminals...no power loss there.
There are two earths coming from the battery...one to the fender (smoking, overheating), & the other (main) to the block. It is the one to the body that seems the problem...but why?
- cprinsloo
- Town: Nelspruit
- Vehicle: 1998 D/C 4x4
- Club VHF Licence: X52
Hi,
IIRC there is an earth cable from the engine to the chassis, then from the chassis to the body, and then from the body to the battery neg pole. All potential places for IR drop issues.
In any case, overheating and smoke points to high resistance, which will cause IR drop (which you only get when current is drawn, if you measure when no current is drawn all should measure OK). Like Boet said, install a welding cable directly between bat neg and engine, then you should be fine.
Cheers,
C
Cheers,
C
1998 Hilux D/C Lexus VVTi
- Town: Gormanston
- Real Name: Taz
Getting dark here now, so will have to check this out tomorrow. Will look at what has been suggested and see if it helps.
Thanks for the responses so far :)
- Town: Gormanston
- Real Name: Taz
I couldn't lay my hands on a new cable, so I cleaned up all the contacts around the block on the main earth lead, and....brooooooom she lives again
Thank you for the advice & help.
- cprinsloo
- Town: Nelspruit
Glad you're sorted!!Taz wrote:I couldn't lay my hands on a new cable, so I cleaned up all the contacts around the block on the main earth lead, and....brooooooom she lives again
Did you stay up late or got up early??Posted: Sat Jun 20, 2015 3:57 am
