'87 Hilux DC Re-build
Members' DIY projects
Knuppel
Town: White River
Vehicle: '87 SFA HILUX D/CAB
Real Name: Marius
Wed Sep 02, 2015 9:54 am
After the introductions viewtopic.php?f=137&t=39895&p=471501#p471293 I think it is time to start the build thread as things are going fast on some days :celebrate:
Once done this Hilus will be my daily ride so it needs to be reliable. At this stage i am thinking seriously about fitting a 1UZ but my mind is still investigating and pondering the thought and work involved.
I bought the vehicle knowing that the gearbox is buggered and that the engine may be blown, confirmed once I got it started at the yard :o:
This bakkie looks good from far but far from good, as stated before "a good base to work from".
Image Link Broken
Image Link Broken
Knuppel
Town: White River
Real Name: Marius
Wed Sep 02, 2015 9:55 am
And so the fun started
Image Link Broken
Image Link Broken
Knuppel
Town: White River
Real Name: Marius
Wed Sep 02, 2015 10:24 am
Some more pics of progress.......for those who battle to read
Sold the rims it came with, fitted 10" X 15" rims with 32 X 11.5 X 15 tyres
Image Link Broken
Image Link Broken
Image Link Broken
Knuppel
Town: White River
Real Name: Marius
Wed Sep 02, 2015 10:26 am
:dance1:
Image Link Broken
Image Link Broken
MOFASA
Real Name: Johno
Club VHF Licence: X119
Thu Sep 03, 2015 4:34 pm
Fit a WL 2.5 Turbo Diesel
If fitted correctly its the BEST conversion for the price....
I have one fitted and WILL NEVER change it......
ImageImageImage[rimg=206x128]
Knuppel
Town: White River
Real Name: Marius
Thu Sep 03, 2015 6:20 pm
It had one in, not impressed with the conversion work but I believe the WL is not too bad. I need more power however. The one I stripped out has compression comming out the wrong holes :twisted:
pampoen
Town: Gordons Bay
Real Name: Luke
Thu Sep 03, 2015 10:08 pm
Can i suggest that if you're looking for a lexus v8, to go for the vvti with original ECU to keep things reliable and running as they should, also large gains can be had over the non vvti v8 with fuel economy. Google v8 solid, or lextreme.co.za, you can pick up a unit complete with gearbox controller and all the other stuff, lambda sensors, air flow sensor and all the wiring in a nice neat bundle to a water proof fusebox for R18500. It also comes with obd 2 plugs and a flash diagnostic for on the go info.
Knuppel
Town: White River
Real Name: Marius
Fri Sep 04, 2015 10:46 am
Got your message on the other thread also, Thanks!
Knuppel
Town: White River
Real Name: Marius
Fri Sep 04, 2015 10:54 am
Body getting a good scrubbing, the inside floor area is rubberised :aggresive:
I suspect something was hidden :twisted:
Image Link Broken
Knuppel
Town: White River
Real Name: Marius
Fri Sep 04, 2015 11:00 am
The problem.......
Image Link Broken
Where the problem started, rust patch was cut and replaced, so no more water into cab :celebrate:
Image Link Broken
Closing the inspection hole back up.
Image Link Broken
Knuppel
Town: White River
Real Name: Marius
Fri Sep 04, 2015 11:22 am
Image Link Broken
JohanW
Town: Strand
Fri Sep 04, 2015 1:39 pm
Marius, consider enlarging that drainage hole. Also maybe remove the bottom lip. If you can stop leaves and all manner of rubbish collecting in there and having the water drain completely you will never have rust issues again in that area.
Knuppel
Town: White River
Real Name: Marius
Fri Sep 04, 2015 4:16 pm
I have been checking it from all angles there, metal fatigue is part of the problem and is caused by that drain hole not supporting the motion coming from the front cab mounting. Increasing the hole size will increase the flexing in that part. The way we have smoothed it out will ensure no water remains standing there. We also filled all the crevices and cracks with sikaflex. I was thinking about fitting a gause below the vent grid to prevent leaves from falling in. Good suggestion, thanks
Fri Sep 04, 2015 9:53 pm
Nice work there! :thumbup:
The gauze is a good idea, some vehicle have it as standard and it certainly does help, but personally I think that the finer dirt that gets in there is just as much to blame if it's allowed to accumulate - it retains moisture. Ideally there should be no grooves, hollows / depressions, cracks or crevices where it can begin to accumulate.
MOFASA
Real Name: Johno
Sun Sep 06, 2015 9:50 am
Knuppel wrote:It had one in, not impressed with the conversion work but I believe the WL is not too bad. I need more power however. The one I stripped out has compression comming out the wrong holes :twisted:
Will you be rebuilding that WL or selling it?
Knuppel
Town: White River
Real Name: Marius
Sun Sep 06, 2015 3:57 pm
I sold,it as is, on Friday, got R9k for it. Seems to be a saught after item.
Knuppel
Town: White River
Real Name: Marius
Wed Sep 09, 2015 1:02 pm
Work comes first so progress accordingly
The bottom of the cab is done now, will focus on some surface rust on the chassis.
Then the cab will go back to the chassis. Still have to go buy a Lexus.
What colour to paint this little beasty, white it will not be.
Image Link Broken Image Link Broken Image Link Broken
Reinart21
Town: Secunda
Real Name: Reinart
Wed Sep 09, 2015 5:36 pm
Marius, what Lexus are you looking to use? Going auto or manual route?
The Legend
Real Name: Dawie
Club VHF Licence: X93-
Wed Sep 09, 2015 5:45 pm
Knuppel wrote:Work comes first so progress accordingly
I like that khaki colour very much
Knuppel
Town: White River
Real Name: Marius
Sat Sep 12, 2015 10:07 am
Reinart21 wrote:Marius, what Lexus are you looking to use? Going auto or manual route?
Sorry, I missed your post, will be using the lexus vvti with auto box with adaptor to t/box.
Reinart21
Town: Secunda
Real Name: Reinart
Mon Sep 14, 2015 5:42 am
Sorry Marius, I think I meant to ask what ECU?
Knuppel
Town: White River
Real Name: Marius
Mon Sep 14, 2015 10:18 am
Reinhart, will be using the original one intended for the engine, OEM!
I don't want to spend the next three years tuning, and tuning and tuning.................
Plug and play as far as possible. Even going to get the OEM Shifter.
Knuppel
Town: White River
Real Name: Marius
Mon Sep 14, 2015 10:30 am
Look what I got over the week-end. Small steps but they count a lot.
Replacement facia for the vent controls R50! :celebrate:
The old one is a bit perished.
Image Link Broken
Knuppel
Town: White River
Real Name: Marius
Mon Sep 14, 2015 10:35 am
Been playing with some colours
This first one is a definite NO-GO
Image Link Broken
This one has my attention........and its a Toyota colour
What do you guy thinks.....or am I boring you?
Image Link Broken
Image Link Broken
Mon Sep 14, 2015 10:38 am
That orange looks brilliant :thumbup: :thumbup:
Knuppel
Town: White River
Real Name: Marius
Mon Sep 14, 2015 10:50 am
Swambo also likes the orange! so I am on the right track :D:
Toyota 86!! se kleur
It pops... I like
Image Link Broken
Image Link Broken
Mon Sep 14, 2015 11:07 am
:drool: :drool: :thumbup: :thumbup:
Reinart21
Town: Secunda
Real Name: Reinart
Wed Sep 16, 2015 1:00 pm
Great colour choice!! :thumbup: :thumbup: :clap: :clap:
Knuppel
Town: White River
Real Name: Marius
Fri Sep 18, 2015 10:27 am
Progress is slow but the chassis is ready.
Will be fitting 1UZ vvti with auto box
Going to use OEM shifter so that ALL the electronics will be OEM.
Adaptor for 1UZ Autobox to Hilux T/box is being manufactured( Two week lead time)
When all the goodies are ready I will go collect in PTA.
All paint has arrived but still busy preparing the body
Chassis completed.
Image Link Broken
The paint is amazing, depending on the angle to the sun it changes colour.
Image Link Broken
Image Link Broken
MOFASA
Real Name: Johno
Fri Sep 18, 2015 12:56 pm
:drool: :drool: :drool:
:subscribed:
LouisZ
Fri Sep 18, 2015 2:43 pm
Sjoe daai kleur gaan verskriklik mooi lyk. :thumbup:
As dit sal help kyk na die ene. Kan help met die uitleg op die 3UZ binne die enjin kompartiment.
Knuppel
Town: White River
Real Name: Marius
Fri Sep 18, 2015 3:53 pm
Sjoe, maar daai is netjiese werk!!!!!! :drool:
Ek mik in dieselfde rigting vir onder die bonnet. Dit moet lyk asof hy so uit die fabriek kom.
1UZ & 3UZ is identies dieselfde, wat het jy gebruik vir engine mountings as ek mag vra, n prentjie sal duisend woorde spreek :beg:
Waar kom daai expansion tenkie vandaan?
Reinart21
Town: Secunda
Real Name: Reinart
Fri Sep 18, 2015 4:00 pm
Ek sit met presies dieselfde probleem. Engine mountings...
Kom kêrels dis vir n goeie doel!! Help bietjie uit...
LouisZ
Fri Sep 18, 2015 4:23 pm
Die bottle is 'n VW golf sin :silent:
Ek neem fotos van die mounts vanaand vir julle.
Ignoreer die cone filter, die ordenlike boks moet nog in.
Knuppel
Town: White River
Real Name: Marius
Sat Sep 19, 2015 8:19 am
:thumbup: Dankie Louis, dit gaan baie help
LouisZ
Sat Sep 19, 2015 11:36 am
Fotos is op my thread van die mounts.
Nogals se as jou Hilux klaar is sal dit verskiklik koppe laat draai.
Knuppel
Town: White River
Real Name: Marius
Sun Sep 20, 2015 9:08 am
Dankie Louis. Gaan probeer om haar te laat blink!
Knuppel
Town: White River
Real Name: Marius
Tue Oct 06, 2015 4:00 pm
Image Link Broken
Image Link Broken
Image Link Broken
Image Link Broken
Image Link Broken
Agteros
Vehicle: Toyota Hilux 2200 4x4 DC
Real Name: Hugo Janse van Rensburg
Tue Oct 06, 2015 4:11 pm
Dit lyk regtig regtig amazing.... :clap: :thumbup:
2012 FJ Sport Cruiser
1986 Hilux DC 4x4
Pietman
Town: Nelspruit
Vehicle: 2005 Hilux V6 4L D/C 4X4
Tue Oct 06, 2015 4:18 pm
Lyk spogerig :thumbup: :thumbup: :thumbup: :clap:
EX ALTO VINCIMUS
MOFASA
Real Name: Johno
Wed Oct 07, 2015 6:31 am
When you done it going to be 1 of a kind.....
Please give us a breakdown of cost so far cos I am thinking maybe its time for MOFASA to get a rebuild
Wed Oct 07, 2015 6:45 am
Agteros wrote:Dit lyk regtig regtig amazing.... :clap: :thumbup:
+1 :drool: :drool: :thumbup:
Knuppel
Town: White River
Real Name: Marius
Thu Oct 08, 2015 10:10 am
MOFASA wrote:When you done it going to be 1 of a kind.....
Please give us a breakdown of cost so far cos I am thinking maybe it's time for MOFASA to get a rebuild
I will give you a breakdown on the costs of the complete project so far but I have an unfair advantage that most people don't have!
+R40 000 Bakkie
-R 9 000 Engine
-R 2 500 Wheels and rims
+R 0 Wheels and rims I have had those for a while and are paid for
+R 6 000 Paint
+R 6 000 Adaptor
+R16 500 Engine & gearbox
+R 750 OEM Fuel pump
+R2 800 OEM Rear Sump
+R2 500 OEM Shifter
+R 0 Bodywork
+R 0 Metal work
+R 0 Cleaning
+R 0 Engine mountings (Made in house)
+R 0 25mm Lift kit ( Made in house)
R60 500 total
Knuppel
Town: White River
Real Name: Marius
Thu Oct 08, 2015 10:14 am
Thanks for all the compliments so far Guys!
Some days lots of progress and other days ZERO
As time allows. :boss:
MOFASA
Real Name: Johno
Thu Oct 08, 2015 10:40 am
+R40 000 Bakkie
-R 9 000 Engine
+R 6 000 Paint
+R 6 000 Adaptor
+R2 500 OEM Shifter
+R 0 Bodywork
+R 0 Metal work
+R 0 Cleaning
R60 500 total
Not bad if you take the price off the bakkie its good pricing.....
Whats your advantage do tell
rayv
Town: Empangeni
Vehicle: Toyota Hilux 4x4 98 SFA DC
Real Name: Ray
Thu Oct 08, 2015 11:09 am
Wow Amazing !
Gaan Amazing wees Marius !
Sal baie graag wil sien waneer klaar is.
Knuppel
Town: White River
Real Name: Marius
Thu Oct 08, 2015 11:11 am
Mofasa, My advantage is in the Zero amounts! I have the labour of a panel beater, spray painter, boilermaker, turner and mechanics of my choice available.
Knuppel
Town: White River
Real Name: Marius
Thu Oct 08, 2015 11:33 am
Ray, julle sal hom sien hier! ;-)
niclemaitre
Town: Stellenbosch
Vehicle: 87 DC 2.8D
Real Name: Nic
Thu Oct 08, 2015 11:48 am
Knuppel wrote:Look what I got over the week-end. Small steps but they count a lot.
Image Link Broken
Where did you get that please?
SFA '87 DC "Rooies"
Knuppel
Town: White River
Real Name: Marius
Thu Oct 08, 2015 11:57 am
Scrap yard in Nelspruit, Izuco, on the Barberton road, have a friend that lives closeby and fetched me one.
I will ask and see if they can find another one.
niclemaitre
Town: Stellenbosch
Vehicle: 87 DC 2.8D
Real Name: Nic
Thu Oct 08, 2015 12:17 pm
Thanks!
Did your bumper arrive?
SFA '87 DC "Rooies"
Knuppel
Town: White River
Real Name: Marius
Thu Oct 08, 2015 12:27 pm
It arrived yes...........and they managed to break off the one corner piece :irate: I am practising to remain calm.
niclemaitre
Town: Stellenbosch
Vehicle: 87 DC 2.8D
Real Name: Nic
Thu Oct 08, 2015 1:18 pm
Knuppel wrote:It arrived yes...........and they managed to break off the one corner piece :irate: I am practising to remain calm.
Ag nee! As far as I know they are available as spares still.
Time Freight are not my favourite couriers...
SFA '87 DC "Rooies"
MOFASA
Real Name: Johno
Thu Oct 08, 2015 2:36 pm
Knuppel wrote:Mofasa, My advantage is in the Zero amounts! I have the labour of a panel beater, spray painter, boilermaker, turner and mechanics of my choice available.
That's luck.... Can I call on your services too please... :beg:
Knuppel
Town: White River
Real Name: Marius
Thu Oct 08, 2015 2:43 pm
Tomorrow!
Tomorrow never comes
MOFASA
Real Name: Johno
Thu Oct 08, 2015 3:22 pm
Knuppel wrote:Tomorrow!
:lmao: :lmao: :laugh2: :laugh2: :lmao: :lmao:
Knuppel
Town: White River
Real Name: Marius
Tue Oct 13, 2015 4:57 pm
Some progress pics
Cab prepared, ready for painting, just got to hang the doors but need to rebuild the driver door's hinges first
Image Link Broken
:shock2: Some body putty on the load body, I think the PO got putty for Xmas!!
Luckily I have a Panel beater and not a new part fitter
Load bin, we removed the panels so they can be repaired properly
Image Link Broken
Crazy body putty! :silent:
Image Link Broken
Image Link Broken
Putty removed
Image Link Broken
Image Link Broken
Rubberizing hiding some rust
Image Link Broken
Check the thickness :blackeye:
Image Link Broken
Knuppel
Town: White River
Real Name: Marius
Mon Oct 26, 2015 9:48 am
Some mechanical progress
Got my engine
Fitted gearbox adaptor
Mockup of engine into body
55mm lift on body
Image Link Broken
Image Link Broken
Image Link Broken
Image Link Broken
Image Link Broken
Image Link Broken
Image Link Broken
Image Link Broken
Image Link Broken
Image Link Broken
Image Link Broken
Wikkels
Town: Kathu
Vehicle: 1997 Toyota Hilux 2.4 D/C SFA - 2013 Mitsubishi Triton 2.5 4x2 D/C
Real Name: William
Mon Oct 26, 2015 7:23 pm
Dit gaan een awesome Hilux wees!! :thumbup:
The man who smile when things go wrong thought of someone to blame it on!
Reinart21
Town: Secunda
Real Name: Reinart
Tue Oct 27, 2015 6:50 am
Well done with the progress!
Where did you get your shifter?
Return to “Build your own:”
