'87 Hilux DC Re-build
- Knuppel
- Town: Somewhere in Africa
- Real Name: Marius
After the introductions viewtopic.php?f=137&t=39895&p=471501#p471293 I think it is time to start the build thread as things are going fast on some days
Once done this Hilus will be my daily ride so it needs to be reliable. At this stage i am thinking seriously about fitting a 1UZ but my mind is still investigating and pondering the thought and work involved.
I bought the vehicle knowing that the gearbox is buggered and that the engine may be blown, confirmed once I got it started at the yard
This bakkie looks good from far but far from good, as stated before "a good base to work from".
- Knuppel
- Real Name: Marius
Re: '87 Hilux DC Re-build
And so the fun started
- Knuppel
- Real Name: Marius
Some more pics of progress.......for those who battle to read
Sold the rims it came with, fitted 10" X 15" rims with 32 X 11.5 X 15 tyres
- MOFASA
- Real Name: Johno
- Club VHF Licence: X119
Fit a WL 2.5 Turbo Diesel
If fitted correctly its the BEST conversion for the price....
I have one fitted and WILL NEVER change it......
[rimg=206x128]
[rimg=206x128]
- Knuppel
- Real Name: Marius
It had one in, not impressed with the conversion work but I believe the WL is not too bad. I need more power however. The one I stripped out has compression comming out the wrong holes
- Town: Gordons Bay
- Real Name: Luke
Can i suggest that if you're looking for a lexus v8, to go for the vvti with original ECU to keep things reliable and running as they should, also large gains can be had over the non vvti v8 with fuel economy. Google v8 solid, or lextreme.co.za, you can pick up a unit complete with gearbox controller and all the other stuff, lambda sensors, air flow sensor and all the wiring in a nice neat bundle to a water proof fusebox for R18500. It also comes with obd 2 plugs and a flash diagnostic for on the go info.
- Knuppel
- Real Name: Marius
Got your message on the other thread also, Thanks!
- Knuppel
- Real Name: Marius
Body getting a good scrubbing, the inside floor area is rubberised
I suspect something was hidden
- Knuppel
- Real Name: Marius
The problem.......
Where the problem started, rust patch was cut and replaced, so no more water into cab
Closing the inspection hole back up.
- JohanW
- Town: Strand
Marius, consider enlarging that drainage hole. Also maybe remove the bottom lip. If you can stop leaves and all manner of rubbish collecting in there and having the water drain completely you will never have rust issues again in that area.
- Knuppel
- Real Name: Marius
I have been checking it from all angles there, metal fatigue is part of the problem and is caused by that drain hole not supporting the motion coming from the front cab mounting. Increasing the hole size will increase the flexing in that part. The way we have smoothed it out will ensure no water remains standing there. We also filled all the crevices and cracks with sikaflex. I was thinking about fitting a gause below the vent grid to prevent leaves from falling in. Good suggestion, thanks
Nice work there!
The gauze is a good idea, some vehicle have it as standard and it certainly does help, but personally I think that the finer dirt that gets in there is just as much to blame if it's allowed to accumulate - it retains moisture. Ideally there should be no grooves, hollows / depressions, cracks or crevices where it can begin to accumulate.
- MOFASA
- Real Name: Johno
Will you be rebuilding that WL or selling it?Knuppel wrote:It had one in, not impressed with the conversion work but I believe the WL is not too bad. I need more power however. The one I stripped out has compression comming out the wrong holes
[rimg=206x128]
[rimg=206x128]
- Knuppel
- Real Name: Marius
I sold,it as is, on Friday, got R9k for it. Seems to be a saught after item.
- Knuppel
- Real Name: Marius
Work comes first so progress accordingly
The bottom of the cab is done now, will focus on some surface rust on the chassis.
Then the cab will go back to the chassis. Still have to go buy a Lexus.
What colour to paint this little beasty, white it will not be.
- Reinart21
- Town: Secunda
- Real Name: Reinart
Marius, what Lexus are you looking to use? Going auto or manual route?
- The Legend
- Real Name: Dawie
- Club VHF Licence: X93-
I like that khaki colour very muchKnuppel wrote:Work comes first so progress accordingly
- Knuppel
- Real Name: Marius
Sorry, I missed your post, will be using the lexus vvti with auto box with adaptor to t/box.Reinart21 wrote:Marius, what Lexus are you looking to use? Going auto or manual route?
- Reinart21
- Town: Secunda
Sorry Marius, I think I meant to ask what ECU?
- Knuppel
- Real Name: Marius
Reinhart, will be using the original one intended for the engine, OEM!
I don't want to spend the next three years tuning, and tuning and tuning.................
Plug and play as far as possible. Even going to get the OEM Shifter.
- Knuppel
- Real Name: Marius
Look what I got over the week-end. Small steps but they count a lot.
Replacement facia for the vent controls R50!
The old one is a bit perished.
- Knuppel
- Real Name: Marius
Been playing with some colours
This first one is a definite NO-GO
This one has my attention........and its a Toyota colour
What do you guy thinks.....or am I boring you?
- 4x4BEES
- Vehicle: Hilux 4.0V6
- Real Name: Kevin
That orange looks brilliant
- Knuppel
- Real Name: Marius
Swambo also likes the orange! so I am on the right track
Toyota 86!! se kleur
It pops... I like
It pops... I like
- Reinart21
- Town: Secunda
Great colour choice!!
- Knuppel
- Real Name: Marius
Progress is slow but the chassis is ready.
Will be fitting 1UZ vvti with auto box
Going to use OEM shifter so that ALL the electronics will be OEM.
Adaptor for 1UZ Autobox to Hilux T/box is being manufactured( Two week lead time)
When all the goodies are ready I will go collect in PTA.
All paint has arrived but still busy preparing the body
Chassis completed.
The paint is amazing, depending on the angle to the sun it changes colour.
Chassis completed.
- MOFASA
- Real Name: Johno
[rimg=206x128]
[rimg=206x128]
- LouisZ
Sjoe daai kleur gaan verskriklik mooi lyk.
As dit sal help kyk na die ene. Kan help met die uitleg op die 3UZ binne die enjin kompartiment.
- Knuppel
- Real Name: Marius
Sjoe, maar daai is netjiese werk!!!!!!
Ek mik in dieselfde rigting vir onder die bonnet. Dit moet lyk asof hy so uit die fabriek kom.
1UZ & 3UZ is identies dieselfde, wat het jy gebruik vir engine mountings as ek mag vra, n prentjie sal duisend woorde spreek
Waar kom daai expansion tenkie vandaan?
- Reinart21
- Town: Secunda
Ek sit met presies dieselfde probleem. Engine mountings...
Kom kêrels dis vir n goeie doel!! Help bietjie uit...
- LouisZ
Die bottle is 'n VW golf sin
Ek neem fotos van die mounts vanaand vir julle.
Ignoreer die cone filter, die ordenlike boks moet nog in.
- Knuppel
- Real Name: Marius
Dankie Louis, dit gaan baie help
- LouisZ
Fotos is op my thread van die mounts.
Nogals se as jou Hilux klaar is sal dit verskiklik koppe laat draai.
- Knuppel
- Real Name: Marius
Dankie Louis. Gaan probeer om haar te laat blink!
- Agteros
- Vehicle: Toyota FJ Cruiser
- Real Name: Hugo
Dit lyk regtig regtig amazing....
2020 FJ Cruiser
- MOFASA
- Real Name: Johno
When you done it going to be 1 of a kind.....
Please give us a breakdown of cost so far cos I am thinking maybe its time for MOFASA to get a rebuild
[rimg=206x128]
[rimg=206x128]
- 4x4BEES
- Real Name: Kevin
+1Agteros wrote:Dit lyk regtig regtig amazing....
- Knuppel
- Real Name: Marius
I will give you a breakdown on the costs of the complete project so far but I have an unfair advantage that most people don't have!MOFASA wrote:When you done it going to be 1 of a kind.....
Please give us a breakdown of cost so far cos I am thinking maybe it's time for MOFASA to get a rebuild
+R40 000 Bakkie
-R 9 000 Engine
-R 2 500 Wheels and rims
+R 0 Wheels and rims I have had those for a while and are paid for
+R 6 000 Paint
+R 6 000 Adaptor
+R16 500 Engine & gearbox
+R 750 OEM Fuel pump
+R2 800 OEM Rear Sump
+R2 500 OEM Shifter
+R 0 Bodywork
+R 0 Metal work
+R 0 Cleaning
+R 0 Engine mountings (Made in house)
+R 0 25mm Lift kit ( Made in house)
R60 500 total
- Knuppel
- Real Name: Marius
Thanks for all the compliments so far Guys!
Some days lots of progress and other days ZERO
As time allows.
As time allows.
- MOFASA
- Real Name: Johno
Knuppel wrote:I will give you a breakdown on the costs of the complete project so far but I have an unfair advantage that most people don't have!MOFASA wrote:When you done it going to be 1 of a kind.....
+R40 000 Bakkie
-R 9 000 Engine
+R 6 000 Paint
+R 6 000 Adaptor
+R2 500 OEM Shifter
+R 0 Bodywork
+R 0 Metal work
+R 0 Cleaning
R60 500 total
Not bad if you take the price off the bakkie its good pricing.....
Whats your advantage do tell
[rimg=206x128]
[rimg=206x128]
- rayv
- Town: Empangeni
- Vehicle: Toyota Hilux 4x4 98 SFA DC
- Real Name: Ray
Wow Amazing !
Gaan Amazing wees Marius !
Sal baie graag wil sien waneer klaar is.
- Knuppel
- Real Name: Marius
Mofasa, My advantage is in the Zero amounts! I have the labour of a panel beater, spray painter, boilermaker, turner and mechanics of my choice available.
- Knuppel
- Real Name: Marius
Ray, julle sal hom sien hier!
- niclemaitre
- Town: Stellenbosch
- Vehicle: 99 IFS DC 4x4
- Real Name: Nic
Where did you get that please?Knuppel wrote:Look what I got over the week-end. Small steps but they count a lot.
SFA '87 DC "Rooies" - sold
IFS '99 DC "Benny"
IFS '99 DC "Benny"
- Knuppel
- Real Name: Marius
Scrap yard in Nelspruit, Izuco, on the Barberton road, have a friend that lives closeby and fetched me one.
I will ask and see if they can find another one.
- niclemaitre
- Real Name: Nic
Thanks!
Did your bumper arrive?
IFS '99 DC "Benny"
IFS '99 DC "Benny"
- Knuppel
- Real Name: Marius
It arrived yes...........and they managed to break off the one corner piece I am practising to remain calm.
- niclemaitre
- Real Name: Nic
Ag nee! As far as I know they are available as spares still.Knuppel wrote:It arrived yes...........and they managed to break off the one corner piece I am practising to remain calm.
Time Freight are not my favourite couriers...
IFS '99 DC "Benny"
IFS '99 DC "Benny"
- MOFASA
- Real Name: Johno
That's luck.... Can I call on your services too please...Knuppel wrote:Mofasa, My advantage is in the Zero amounts! I have the labour of a panel beater, spray painter, boilermaker, turner and mechanics of my choice available.
[rimg=206x128]
[rimg=206x128]
- Knuppel
- Real Name: Marius
Tomorrow!
Tomorrow never comes
- MOFASA
- Real Name: Johno
Knuppel wrote:Tomorrow!
[rimg=206x128]
[rimg=206x128]
- Knuppel
- Real Name: Marius
Some progress pics
Cab prepared, ready for painting, just got to hang the doors but need to rebuild the driver door's hinges first
Some body putty on the load body, I think the PO got putty for Xmas!!
Luckily I have a Panel beater and not a new part fitter
Load bin, we removed the panels so they can be repaired properly
Crazy body putty!
Putty removed
Rubberizing hiding some rust
Check the thickness
Crazy body putty!
Putty removed
Check the thickness
- Knuppel
- Real Name: Marius
Some mechanical progress
Got my engine
Fitted gearbox adaptor
Mockup of engine into body
55mm lift on body
Got my engine
55mm lift on body
- Town: Kathu
- Vehicle: 1997 Toyota Hilux 2.4 D/C SFA - 2013 Mitsubishi Triton 2.5 4x2 D/C
- Real Name: William
Dit gaan een awesome Hilux wees!!
The man who smile when things go wrong thought of someone to blame it on!
- Reinart21
- Town: Secunda
Well done with the progress!
Where did you get your shifter?
