Fuel tank is cracked on the seam - where to get a new one made?
WayneMan
Town: Joburg
Vehicle: Toyota Hilux KZTE 4x4 DC
Real Name: Wayne
Wed Oct 21, 2015 2:14 pm
My fuel tank on my KZTE double cab is cracked on the seam and is leaking.
I have not asked the agents for a price on a new one, and Im sure it will cost a bomb!
I am going to take the tank to Northern Off Road and they will see if it can be successfully repaired.
Failing that, does anyone know I can get a new one made ?
Most of the 4x4 shops manufacture and supply auxiliary or long range tanks, but not replacements for the original.
Ill try post some photos when I get the tank later this afternoon.
Thunder02
Town: East Rand
Vehicle: IFS Hilux
Real Name: Neil
Club VHF Licence: HC105
Wed Oct 21, 2015 3:10 pm
N1 4x4
Scout motto:be prepared....
www.4x4direct.co.za
FIRSTGEER
Town: King WilliamsTown
Real Name: Tony Geer
Club VHF Licence: HC 109
Wed Oct 21, 2015 8:28 pm
Hi there Wayne.I suggest you try one of the radiator/ tank repair firms in your area.I would also insist that they weld strips across the seams for re-enforcing and to prevent problems in the future.Good luck with your repairs.
Haboob
Town: King Williams Town
Real Name: Edge
Club VHF Licence: HC129
Thu Oct 22, 2015 9:13 am
Quite possible to repair and it must be a S/S tank otherwise it would probably not have cracked.
Have strengthening ribs added on both sides as it is possible that it will happen again if you do not do this.
Scrap yards should also be able to assist you if the fixing has problems for any reason, but then make sure that you get the tank cleaned out properly, before installing...
This is a good time to fit an extra tank if you have overlanding plans for the vehicle..
HABOOB means "Dust Storm"
WayneMan
Town: Joburg
Real Name: Wayne
Tue Oct 27, 2015 9:43 pm
Thank you guys for the feed back.
I managed to source a 2nd hand tank from a scrap yard. Just need to figure out how to clean it properly and then ill get it installed.
Haboob
Real Name: Edge
Wed Oct 28, 2015 11:37 am
This is a good time to fit an EXTRA (ADDITIONAL) tank if you have overlanding plans for the vehicle..
