New Hilux Revo engine info
- Hoppy
- Vehicle: Hilux SFA & IFS
- Real Name: Allan 0721291160
The 1GD-FTV is a 2.8L (2755cc) straight-4 common rail diesel engine with a variable geometry turbocharger and Intercooler. It has 16 valves and a DOHC (double overhead camshaft) design. Its compression ratio is 15.6:1. Bore x stroke is 92.0 mm x 103.6 mm. It generates 177 horsepower (132 kW) at 3400 rpm, and 450 newton metres (330 lbf·ft) of torque at 1400-2600 rpm when mated to a 6-speed automatic transmission, depending on target market and emission specifications. With manual transmission, outputs are 177 horsepower (132 kW) and 420 newton metres (310 lbf·ft).[citation needed] Average fuel consumption (in JC08 method) is 11.2 km/l.
This engine will be used in Toyota Land Cruiser Prado, second generation Toyota Fortuner and eighth generation Toyota Hilux.
2GD-FTV[edit]
The 2GD-FTV is a 2.4L (2393cc) straight-4 common rail diesel engine with a variable geometry turbocharger and Intercooler. It has 16 valves and a DOHC (double overhead camshaft) design. Its compression ratio is 15.6:1. Bore x stroke is 92.0 mm x 90.0 mm. It generates 150 horsepower (110 kW) at 3400 rpm, and 400 newton metres (300 lbf·ft) of torque at 1600-2000 rpm when mated to a 6-speed automatic transmission, depending on target market and emission specifications. With manual transmission, outputs are 150 horsepower (110 kW) and 343 newton metres (253 lbf·ft)
The engine is a genuine Toyota unit, not a Cummins or Isuzu as speculated.
2GD-FTV[edit]
aev@iburst.co.za
Re: New Hilux Revo engine info
Interesting. They didn't give the fuel consumption for the 2.4, wonder if that's because it may be heavier on fuel than the 2.8
- Agteros
- Vehicle: Toyota FJ Cruiser
- Real Name: Hugo
Would love to see the torque figures for the V6. Power is apparently 207kW. Must be uprated version of the current FJ/Prado engine @ 200/202kW.
2020 FJ Cruiser
Me think the 2.4 will be a good buy.
2.4's torque is only 20nm less than the 2.8, me also thinks the 2.4 will be a good one.
I am sure one must be able to get fuel consumption figures from Thailand or other countries where it is already available.
- AM Racing
- Real Name: Dylan
Looks like the manuals are detuned to compensate for the looses incurred with the auto box. Some chipping would probably see them wake up considerably.... But that's just me. Not even my lawnmower is standard!
Some more engine porn on the Revo's...
ESTEC GD Engines of Toyota Hilux Revo
GD Engines come with ESTEC (Economy with Superior Thermal Efficient Combustion) technology and is a downsized turbocharged direct injection engine with superior thermal efficient combustion. This engine features a combination of a cylinder head with an integrated exhaust manifold and a turbocharger, and achieves high-speed combustion using a fan spray direct and port injection system and a high in-cylinder tumble ratio. The GD engine is capable of both seamless and invigorating acceleration while also ensuring superior thermal efficiency. We are therefore expecting superior performance with minimal fuel use.
As indicated above, GD engines use commonrail fuel injection technology operating at ultra high pressures of up to 135 mpa (1350 bar or about 19,580 psi) which is about 8 times more than the pressure of conventional fuel injection systems within a “common rail” that feeds the injectors on all four cylinders. This is combined with a 32-bit ECU standard with Toyota Hilux Revo which controls fuel quantity, valve-timing, and boost pressure at different engine parameters resulting in best fuel economy and also full utilization of power during acceleration. Pilot injection is also utilized by the common rail fuel system to smooth engine operation. Small amounts of fuel are introduced into the combustion chamber prior to the main injection event, reducing lag time and promoting more continuous and complete combustion. Exterior and interior engine noise is also reduced.
Toyota Hilux Revo 2015 2016 All New Hilux Configurations
31 variants of All New 2015 2016 Toyota Hilux Revo will be offered in the three engines in both 5 speed & 6 speed manual and 6 speed sequential Auto transmission: 2400 cc ESTEC GD Diesel, 2800 cc ESTEC GD Diesel and 2700 cc Dual VVT-i Petrol Gasoline in Single Cab, Smart Cab and Double Cab:
5 Speed and 6 Speed Manual Transmission Hilux Revo Diesel
2016 Toyota Hilux Revo 2.4 2GD-FTV VN four-cylinder intercooled turbocharged diesel engine Manual – 150PS and 343Nm of torque between 1400 and 3400rpm,5-speed manual transmission.
2016 Toyota Hilux 2.8 1GD-FTV VN four-cylinder intercooled turbocharged diesel engine Manual – 177PS and 420Nm of torque between 1400 and 2600rpm, 6-speed manual transmission.
6 Speed Auto Transmission Hilux Revo Diesel
2016 Toyota Hilux 2.4 2GD-FTV VN four-cylinder intercooled turbocharged diesel engine Auto – 167PS and 400Nm of torque between 1600 and 2000rpm, 6-speed sequential transmission.
2016 Toyota Hilux 2.8 1GD-FTV VN four-cylinder intercooled turbocharged diesel engine Auto – 177PS and 460Nm of torque between 1,600 and 2,400rpm, 6-speed sequential transmission.
5 Speed and 6 Speed Manual and 6 Auto Petrol Toyota Hilux Revo
2016 Toyota Hilux 2.7 2TR-FE Dual VVT-i – 166PS and will be available with both 5-speed and 6-speed manuals and a 6-speed sequential gearbox as well.
- zepplin
- Vehicle: Crooza VX 80 EFI
- Real Name: Steve
- Club VHF Licence: HC 127
There aint no substitute for cubic inches!!!!!!!!!
- Dirka
- Town: Doornpoort Pretoria
- Real Name: Dirk
The 3.5L V6 is an all new non-hybrid Atkinson cycle engine. Also GR series.Agteros wrote:Would love to see the torque figures for the V6. Power is apparently 207kW. Must be uprated version of the current FJ/Prado engine @ 200/202kW.
Here is the specs:
3.5L V6: Output: 207Kw Torque: 359 Nm at 4600 rpm.
Much more fuel efficient than current 4.0 V6 (1GR-FE)
..and then it's got some nice advances like the D4-S (both port and direct injected),
the tumble flow exhaust extraction and the self cleaning injectors that is slitted.
..also no more exhaust manifold (Gases goes through the head it seems)
The only thing is...it's produced for the Tacoma, and I can see no V6 on the new Hilux offerings so far.
- Town: Bellville
- Vehicle: V8 Disco 1
- Real Name: Dirk
NeeAgteros wrote:Would love to see the torque figures for the V6. Power is apparently 207kW. Must be uprated version of the current FJ/Prado engine @ 200/202kW.
Die v6 is 175kw
En iets soos 340/ 370nm
Ou motor
Nee... dis 'n splinter nuwe V6!Huismoeles wrote:NeeAgteros wrote:Would love to see the torque figures for the V6. Power is apparently 207kW. Must be uprated version of the current FJ/Prado engine @ 200/202kW.
Die v6 is 175kw
Ou motor
2GR-FKS
The 2GR-FKS combines the D-4S system from the 2GR-FSE with the simulated on-demand Atkinson cycle used in the 2UR-GSE and 8AR-FTS engines. The intake camshafts are equipped with VVT-iW and the exhaust camshafts are equipped with VVT-i. In the Tacoma the engine specifications are 207 kW (278 hp) at 6000 rpm and 359 N·m (265 lb·ft) at 4600 rpm.[9] In the Lexus RX 350 the engine specifications are 220 kW (295 hp) at 6300 rpm and 362 N·m (267 lb·ft) at 4700 rpm respectively. In the Lexus GS350 the engine specifications are 232 kW (311 hp) at 6400 rpm and 380 N·m (280 lb·ft) at 4800 rpm respectively.
- Dirka
- Real Name: Dirk
Mr_B wrote:Nee... dis 'n splinter nuwe V6!Huismoeles wrote:NeeAgteros wrote:Would love to see the torque figures for the V6. Power is apparently 207kW. Must be uprated version of the current FJ/Prado engine @ 200/202kW.
Die v6 is 175kw
Ou motor
2GR-FKS
+1
- Town: Hilux Country
- Vehicle: 07 hilux dc 4L v6 manuel, alu canopy, rock/s, full ome sport, Hoppy s/s custom exhaust, 33 grabber muds, compressor, exstra 80L f/t, dual battery,body lift,redpepper bumper,custom sound with sub,afternarket touchscreen entertain unit, dynoteck chip 188kw
- Real Name: Pierre
My ou v6 motortjie maak darem na n Hoppy exhaust en Dynotech chip 188kw en 399nm nie te sleg nie sal ek reken.
- 4x4BEES
- Vehicle: Hilux 4.0V6
- Real Name: Kevin
Net jammer jy kan nie die klank ook uitbeeld in syfers nie
- Town: Bellville
- Real Name: Dirk
Dirka wrote:Mr_B wrote:Nee... dis 'n splinter nuwe V6!Huismoeles wrote:NeeAgteros wrote:Would love to see the torque figures for the V6. Power is apparently 207kW. Must be uprated version of the current FJ/Prado engine @ 200/202kW.
Die v6 is 175kw
Ou motor
2GR-FKS
+1
175kw is wat toyota se brochure se
Sal laat iemand foto opsit
- Omo
- Vehicle: Ford Ranger super cab 3.0 xlt 4x4
- Club VHF Licence: HC236
Toyota se die volgende:
There a two kind of people. Those who pushes a door when it says pull and they who pull a door when it says push.
- Hilux 1
- Real Name: Tertius
- Club VHF Licence: HC137
nou is almal darem stil??
Nope... it looks like Toyota SA are set to keep the current 4L V6 (1GR-FE), as is in the Vigo. Yes, that is a 175Kw engine. The new engine, a 3.5L V6 (2GR-FKS), is 207kW to 235kW depending on tuning. We were hope this engine would be fitted to the local Revo, but it doesn't look like it will be available here in SA! Overseas it's used in the 2015 Toyota Tacoma.
- Dirka
- Real Name: Dirk
Yes..I would've love to see the 3.5 V6 in the new Revo also, but it was never destined for SA or a Lux.Mr_B wrote:Nope... it looks like Toyota SA are set to keep the current 4L V6 (1GR-FE), as is in the Vigo. Yes, that is a 175Kw engine. The new engine, a 3.5L V6 (2GR-FKS), is 207kW to 235kW depending on tuning. We were hope this engine would be fitted to the local Revo, but it doesn't look like it will be available here in SA! Overseas it's used in the 2015 Toyota Tacoma.
Aikona Hilux..ziggollo. nayda. ziltch..zip...eee nada.
Maybe our market is just too small or our Rand is net te poef.
But who knows..maybe oneday? How bout it Toy SA?
Those Atkinsons is fantastic and is something totally different to the Ottos.
But nonetheless. I'ts still good news to see the (old) 1GR-FE in the Revo.
It now comes wit a 6 sp (also from Aisin Warner I thinks)
So still lots of support and spares.
They are slowly but surely preparing us for the inevitable.... by the 2nd facelift the new Hilux will be running with a 2.0 BiTDi... Then where are you guys going to stick your "Only juice and milk comes in 2l" stickers??
Not to worry Thys... by then the jokes will be on the 1L 2cylinder 300kw quad turbo bi supercharged VW engine... that sips diesel because it's computer has been tampered with!ThysdJ wrote:They are slowly but surely preparing us for the inevitable.... by the 2nd facelift the new Hilux will be running with a 2.0 BiTDi... Then where are you guys going to stick your "Only juice and milk comes in 2l" stickers??
BTW... check out this 1 stroke engine...
http://libralato.co.uk/index.html
- JJBotes
- Town: Witbank
- Vehicle: KZ-TE
- Real Name: JJ
Would love one of these for my KZ.
