Power Supply Unit
- etiennel22
- Vehicle: 2003 Hilux 3.0 KZ-TE D/C Raider 4x4
- Real Name: Etienne
Power Supply Unit
Good day,
Hope anyone can help me.
Does anyone know what this brown round thing is? after some googling I think it is a fuse.
It is from a 12VDC 3,2A UPS Power Supply Unit.
Thank you
Regards
Thank you
Regards
Re: Power Supply Unit
do you have a photo from a different angle ?
typically capacitors that release smoke .....
but I dont see any "farad" value .... but then again very often components on commercial pc-boards dont display all info ...
- etiennel22
I will upload another photo tonight.
But from what I can gather it might be this, http://za.rs-online.com/web/p/products/2260967/" onclick="window.open(this.href);return false;
How many wires from it? You'll have to look at the other side of the PCB for that. It looks more like a full-wave bridge rectifier to me, so will probably have four equidistant leads.
Whatever, it certainly looks like it is now "fused".
Edit: Aah, might be a Wickmann fuse!
- Stef
- Vehicle: '98 LTD
- Club VHF Licence: X107
Looks like a fuse yes. Cylindrical (electrolytic) caps are normally used in power supplies are usually marked clearly ito Polarity as well and bulges at the top when blown.
- etiennel22
There is 2 wires from it going into the PCBFamily_Dog wrote:How many wires from it? You'll have to look at the other side of the PCB for that. It looks more like a full-wave bridge rectifier to me, so will probably have four equidistant leads.
- Jaws
- Town: Sharonlea
- Vehicle: 2009 D4D 4x4
- Real Name: Herman
You are correct it's a
Bussmann fuse
Bussmann fuse
- etiennel22
So can I buy a new one and just replace it?
Sent from my GT-I9500 using Tapatalk
buy a couple ..... the fuse is not the problem - just an indicator of the actual over current .....
- Stef
- Vehicle: '98 LTD
+1 Replace and switch on without load, if it blows again there is a short/faulty component on the board.
- etiennel22
Thank you, will give it a tryStef wrote:+1 Replace and switch on without load, if it blows again there is a short/faulty component on the board.
- etiennel22
Got the replacement fuses. But as soon as I plug in the unit it blows again. So I guess there is something else wrong.
- Stef
- Vehicle: '98 LTD
Sounds like you have a dead short somewhere between L -N.
- etiennel22
- Stef
- Vehicle: '98 LTD
Easiest is to measure with a multi-meter to see if that is the case...then follow the actual tracks on the back to see if there is any obvious shorts like a piece of wire/solder or maybe against the enclosure when assembled etc.
With that eliminated, check the major components one by one
- etiennel22
Will give it a go when I get a chance. Thanks
- etiennel22
Finally got time to test the unit. So it seems the yellow Polypropylene Film Capacitor next to the Fuse is also dead.
Found a place that sell those capacitors hopefully I can get the unit working tonight. Holding Thumbs
