SFA Hilux Rebuild/3UZ Lexus Conversion
- Reinart21
- Town: Secunda
- Real Name: Reinart
Re: SFA Hilux Rebuild/3UZ Lexus Conversion
Let it not be said it takes little work to rebuild a hilux
Since the last update, we got quite a bit of work done.
Gents, who ever decides to rebuilt/rewire the harness of one of these newer tech bad boys with sensors and solenoids vir ALLES, sterkte ou boet!
My wiring is about 75% complete, gona be using full e-throttle like was intended, if it gives me hassles I'll chuck it and go cable.
To get to my 2 knock sensors to check the plugs and trace the wires, I had to remove the intake manifold, decided to have a look inside as I had to install 2 new sensors, MAP and Intake Air Temp.
Underside of the Manifold. Quite a lot of petrol "dampe" and what else was inside, friend said some places chuck a bit of petrol into the mani to help it start on the floor when customers come round to buy them, whatever the case it got an overhaul and clean etc. Must say them guys with the thick glasses knew what they were doing, something that would have been nice is to have a sort of stepper motor on the runner control actuator rather than an full open full close, but it works.
The end is in sight, at least to get as far to start the motor and hear it come to life.
Got Exhaust Headers, made to clear the chassis with a bit of extra runner length, hopefully it will free up the motor some.
38mm Runners, with 63mm exit flange. Will be a single pipe system, as I need Air Fuel Ratio Wideband Controller and it needs to be fed from both banks of the v8. Also I'm hoping it sounds better than avg raspy jap v8 .
So the project is coming along, slowly, but we're going in the right direction.
Will try to update more frequently as we go along.
- JohanW
- Town: Strand
Deur dinge die eerste keer reg te doen en pynlik perfek te werk, gaan jy aan die einde met 'n meesterstuk sit. Hou so aan.
- Knuppel
- Town: Somewhere in Africa
- Real Name: Marius
Some progress
- Reinart21
- Town: Secunda
Marius, ons try!!
- Reinart21
- Town: Secunda
Het die week ook heelwat gedoen gekry, maar sal moet fotos neem vir bewyse.
Eers gesukkel om torque converter in te kry, hy moet n paar keer in gly voor hy op sy plêk, youtube you yster . Net om agter te kom hulle sê as jy jou torque converter skoon gemaak het, sit 1 quart ATF in voor jy hom op die ratkas monteer. Weer kom hy uit en vinnig weer terug
Toe het ons die exhaust mani's op die engine vas, harnas op sy plek en die engine terug gesak, magtag, "Fits like a glove"!! Engine mounts op, everything in place.
Fuseboks met relays is op gemaak, moet net die coil/triggers uitsorteer. Dit gaan interesant wees.
4 goed wat ek moet af werk voor ek hom kan start:
Fuel pressure regulator fit met sy toevoer pypies.
Radiator pypies opmaak en insit.
Power steering pomp en boks, sal laat die spesialis dit uitsort.
Die laaste 12v common feed drade na die motor opsit, ignition switched koppel en die e-throttle calibrate( die LINK ecu moet hom leer ken . Snaaks genoeg, dit maak glad niks saak dat ek een van ons 1KD D4d the throttle pedals gebruik nie, hy is heel happy met hom
- Reinart21
- Town: Secunda
VInnige vragie, op die trigger coil van a 4 punt relay, maak dit saak of sy gront konstant is, en jy "trigger" hom met positief, soos ignition switched, of as jy hom konstant positief gee soos ignition switched en hom "trigger" met negatief??
- Knuppel
- Real Name: Marius
Dit maak nie saak nie.
- Reinart21
- Town: Secunda
I know this is reviving a very old thread, just wanted to give an update... FYI when doing everything on your own, progress is only as fast as the hours you can spare
I've done about 500 kms with the 3u, pulls like a beast on 33"s and only 75% Throttle (Felt it would be wise to dial down the power for the first part of any teething problems).
To do list is still long but we'll get there.
Recent Additions:
Big shout to the 4x4direct team, they make getting things to spend your money on way too easy
- Headlight booster harnass - 100% worth the time (5mins) spent installing.
- Led replacement globes all round incl dash lights.
V8solid
- 2x Relay and Fuse holder totaling 10 Relays all used
- Help with alternator wiring etc, thanks Derick!
Ill do a proper right up soon.
Sure not going to use that filter offroading, no need to pick up stones
Not sure how to get videos up here, I have some start up, first drive for evidence ofcourse
Recent Additions:
V8solid
- LouisZ
Hi
Jis dit loop nou mooi. Dis amper klaar.
Wat het julle gemaak om die rev counter te laat werk?
Upload it to youtube, then get the share link on youtube and paste it in the forum between the "Video" linkNot sure how to get videos up here, I have some start up, first drive for evidence ofcourse
Code: Select all
[video]http://youryoutubelinkhere.com[/video]
- Reinart21
- Town: Secunda
Baie eenfoudige "work-around",
Dit behels slegs n paar komponente, R300 seker totaal maar dan simulate jy basies net coil ignition deur die rev counter.
Gebruik n golf 1 se 7 pin ignitor, (Goldwagen vra onder R150), n 4 of 5 pin relay dan maak jy n circuit op wat dan earth deur jou rev counter. Werk soos n bomb en 100% reg.
As jy my jou email of so gee, dan mail ek die inligting deur
