Hi Guys, can I use 220v Flex to wire up a 12v Led worklight, or must I use automotive wire?
Thanx.
Elvy
220 Flex can it be used for 12v
- Town: Marble Hall
- Vehicle: Hilux xtra Cab 2014,Isuzu 250 dtec 2011 ,Fortuner d4d 4x4
- Real Name: Elvy
2011 Hilux D4D 4x4 s/c
2008 Fortuner 4x4
1993 Hilux d/c sfa
2008 Fortuner 4x4
1993 Hilux d/c sfa
- niclemaitre
- Town: Stellenbosch
- Vehicle: 99 IFS DC 4x4
- Real Name: Nic
Re: 220 Flex can it be used for 12v
220v flex is usually low amp rating since the volts are relatively high. 12V is relatively low so the amps are higher but generally not excessively so. What's the max current draw on the lamp?
SFA '87 DC "Rooies" - sold
IFS '99 DC "Benny"
IFS '99 DC "Benny"
The wire "size" relates to the current it can carry :
Cable size in mm square....1...1,5...2,5...4.....6.....10...16
Current carrying capacity..11...14....18...25....32....43...57
You get "flex" from 1mm2 (read: one-millimeter-squared) up to 4mm2. As you can see the current carrying capacity varies drastically.
If you give a bit more information on your worklight (rated power) we can help with the wire selection.
- Town: Marble Hall
- Real Name: Elvy
Hi Chris,
It is the 27 watt work light from 4x4 direct. I do have the red and blue automotive wires,but because the wires wil be running on my cattlerails I wanted to go to black flex .
Thanx.
Elvy
Thanx.
Elvy
2008 Fortuner 4x4
1993 Hilux d/c sfa
2008 Fortuner 4x4
1993 Hilux d/c sfa
- niclemaitre
- Real Name: Nic
A 27W lamp will draw 2.5A at 12V
I(A) = P(W) / V(V)
That's easily within the spec of normal household extension flex
I(A) = P(W) / V(V)
IFS '99 DC "Benny"
IFS '99 DC "Benny"
Correct. The wire size could go down to 1mm2 (actually lower) and still do the job fine.niclemaitre wrote:A 27W lamp will draw 2.5A at 12V
I(A) = P(W) / V(V)
BUT - "run the wires ON the cattle rail" .... please make sure you have excellent fusing near the battery. You really dont want something damaging the insulation and shorting out onto the metal of the cattle rail.
- Stef
- Vehicle: '98 LTD
- Club VHF Licence: X107
I would fish it through one of the rails with grommets at entry/exit points
- Town: Marble Hall
- Real Name: Elvy
Thanx for the info.
Will do.
Will do.
2008 Fortuner 4x4
1993 Hilux d/c sfa
2008 Fortuner 4x4
1993 Hilux d/c sfa
