Electric Turbo designed for naturally aspirated vehicles like Toyota 4.0L and 2.7L HeeeeHaaaaaa
stumps
Town: Alberton
Vehicle: Toyota 4.0L D/C 4x4; Camil
Real Name: Marius
Club VHF Licence: X225
Post by stumps »
Hi all.
I have been looking to get a bit more bite from my 4.0l and the plans were
1. Chip. - Just not enough boost for the petrol
2. Super charger - To much of a modification and very expensive
And just as I wanted to give up
3. Turbo for my hilux.
From what my study has gathered
1. Driven by electric motor so no airflow mods needed
2. Can remove very easily when you sell your car and install on next car
3. 30% -40% increase in power and KW
4. Designed, tested and built for SA conditions
5. +- R18 000 installed and maybe cheaper with stronger rand.
6. Did test on my Lux and pushes more than enough fuel through for the extra boost
7. Patented unique design
8. Sole right to unit held by ex performance car technician. Been in business of Dino tuning for years.
I'm looking to see if the interest is there to run a test day.
ANYONE INTERESTED?
Sent from my SM-P555 using Tapatalk
2008 Hilux 4.0L 4x4 (Mufasa)
Toyota 4.0L D/C 4x4; Camil suspesion, Long Range tank, Kilber snorkel
1Co 15:10
But by the grace of God I am what I am: and his grace which was bestowed upon me was not in vain;
http://www.sandriver.co.za" onclick="window.open(this.href);return false; http://www.travelconsortium.co.za" onclick="window.open(this.href);return false;
ahmedoo
Town: pre
Vehicle: toyota fortuner
Real Name: ahmed
Re: Turbo designed for Toyota 4.0L and 2.7L HeeeeHaaaaaa
Post by ahmedoo »
I wouldn't mind that at all
Dirka
Town: Doornpoort Pretoria
Real Name: Dirk
Post by Dirka »
Any online info available for the unit?
” ― J. Kintz
stumps
Town: Alberton
Real Name: Marius
Post by stumps »
Dirka wrote:Any online info available for the unit?
We are working on a website and I'm meeting with the technician as soon as I'm back from Limpopo for test run.
The better description is that it is an Electric Turbo designed for naturally aspirated vehicles.
1Co 15:10
Lorry
Town: durban
Vehicle: D4D hilux DC $X$
Real Name: Lorenzo
Re: Electric Turbo designed for naturally aspirated vehicles like Toyota 4.0L and 2.7L HeeeeHaaaaaa
Post by Lorry »
A car without turbo has a different compression ratio than one fitted with a turbo. how are you managing this? Is this unit not just a supercharger working of an electric motor rather than a turbo charger? Is the electric motor a variable speed driving unit or fixed speed?
Town: inniedorp
Vehicle: Toy
Post by ChrisF »
Lorry wrote:A car without turbo has a different compression ratio than one fitted with a turbo. how are you managing this? Is this unit not just a supercharger working of an electric motor rather than a turbo charger? Is the electric motor a variable speed driving unit or fixed speed?
MUST be variable speed - or it will need one mother of a blow off valve ....
and the speed at which it various the supply air volume must change FAST to keep up with the rev range en responsiveness of a petrol engine .... no use in gearing down if the electric pump is going to take a few seconds to wake up ....
I do believe this have been tried a few times.
Some very good reasons why so many mechanics still install turbos or blowers - both physically connected to the engine speed, or then at least to the volume of exhaust gasses in the case of a turbo ...
stumps
Town: Alberton
Real Name: Marius
Post by stumps »
Compression ratios remain the same0.15 to 0.35
suppose you can call it an electric supercharger
1Co 15:10
stumps
Town: Alberton
Real Name: Marius
Post by stumps »
I understand its connected to the pc box to regulate all you need.
There is some mapping involved as well.
1Co 15:10
Knuppel
Town: Somewhere in Africa
Vehicle: '87 SFA HILUX D/CAB
Real Name: Marius
Post by Knuppel »
Old school engines required you to drop the compression ration, on modern engines you can get away with it up to a point but I dont think the boost will be going to that territory where you will need to drop the compression ratio.
Image Link Broken
Town: inniedorp
Vehicle: Toy
Post by ChrisF »
Which brings up the next point ... "turbo" vs "compressor" vs "Blower" vs "compensator" ...
This is starting to sound like a "compensator" ... offsetting low pressure high altitude, by providing a "bit of boost".
And the "similar compression" ratio seems to back this - though by definition compression ration is function of clearance volume to stroke volume, thus not a function of a turbo .... more correctly the increased air flow means more fuel can be burnt and more developed - thus more strain on the bearing surfaces. Again back to what older engines can tolerate vs newer engines .... Punch line - by adding "30 to 40%" to the power figures will certainly be pushing the limits of many engines ... But if this is only a low pressure compensator, then it will only be adding a small bit of power to that which the engine should have a coastal conditions ... well actually 25% increase to coastal conditions.
some of these figures dont seem to add up that nicely ... :subscribed:
would be interesting to see how this works in real life.
stumps
Town: Alberton
Real Name: Marius
Post by stumps »
I hear you. Also looking forward to a test run. Seems like installation will be Thursday..............
I'm off to the farm first for some work. Will keep taps on the tread. Going to send all the questions to the technician as well.
1Co 15:10
Post by Mars »
My thoughts exactly.
Ultred
Town: Heidelberg
Vehicle: '00 Hilux 2.7i D/Cab IFS.
Real Name: Mike
Club VHF Licence: HC108
Post by Ultred »
This is just one of those posts that i have to follow...i'm keen.
I MAY GET LOST, BUT NO WAY IN HELL WILL I GET STUCK
Ultred
Town: Heidelberg
Real Name: Mike
Post by Ultred »
Why has this been such a quiet subject?? Are those test still running?
stumps
Town: Alberton
Real Name: Marius
Post by stumps »
Sorry, i have been stuck in musina with a contract and was never able to do the installation. It's still on the cards, for sure. Contract is done in October
Sent from my SM-G930F using Tapatalk
1Co 15:10
Ultred
Town: Heidelberg
Real Name: Mike
Post by Ultred »
Are you still planning on doing the installation? keep us updated... :thumbup:
stumps
Town: Alberton
Real Name: Marius
Post by stumps »
Definitely planning on still doing it.
1Co 15:10
Ultred
Town: Heidelberg
Real Name: Mike
Post by Ultred »
Any verdict....
Sent from my SM-T815 using Tapatalk
Jurgen10
Vehicle: 2009 Hilux 4.0 V6 Raider DC 4x4
Real Name: Jurgen
Club VHF Licence: HC239
Post by Jurgen10 »
There are allot of these type of videos on YouTube.
Mighty Car Mods did some tests so you don't have to :)
Here is the link:
https://www.youtube.com/watch?v=cbGWgvJN1_8" onclick="window.open(this.href);return false;
stumps
Town: Alberton
Real Name: Marius
Post by stumps »
Its a 4year old vid. Technology has come along way since then. I still have not been able to test. Just to busy at work. Will see how this week goes
1Co 15:10
Ultred
Town: Heidelberg
Real Name: Mike
Post by Ultred »
Hi Stumps,
Have you ever had time to run those test...
