Fj cruiser nitro charger to SFA
- Sven
- Town: Nelspruit
- Vehicle: '89 Hilux DC
- Real Name: Sven
Was just wondering after seeing a photo of a Toyota Tacoma with old man emus, what is the possibility of using a nitro charger style shock with coil suspension from a Tacoma/fj cruiser and one or 2 leaf springs for the axles for stability on the SFA, obviously there would need to be some shock mount modification but could this not be a suspension option on a SFA?
Re: Fj cruiser nitro charger to SFA
It's possible of course, but is it advisable?
The spring rate of a suspension system is calculated around the weight of that particular vehicle and the Tacoma as well as the FJ are considerably heavier, especially if the donor vehicle was a diesel. This of course includes the shocks, whose damping rate is similarly matched. You might well find after doing it that you have a very hard suspension with suspension travel (and thus articulation) being severely hindered because of the lighter vehicle weight not being able to deflect the springs sufficiently.
That's just my opinion.
- Town: Griffith
- Vehicle: 07 Hilux SR5
- Real Name: Luke
Dont waste your time and money! Just buy the right gear the first time!
Anything is possible - depending on you pocket depth.
