Hi guys stuck here 90ks out of Mariental in Nam, my hilux is slipping gears...
Anyone can tell me where to find the dip stick for the transmission oil? Or if can change on this auto transmissions
Urgent help v6 auto slipping gears
- mossie89
- Town: Paarl
- Vehicle: Toyota Hilux D/C 4x4 4.0 v6
- Real Name: Riaan
Re: Urgent help v6 auto slipping gears
It has no dip stick. Only has a inspetion plug and drain plug
- Giovann
- Vehicle: 2007 4l V6 Hilux Raider D/C A/T
- Real Name: Giovann
Figured as much, the auto gearboxes have a torque converter instead of clutch hey, could that be the issues?
I have considerable loss I power, it keeps slipping or trying to change gears especially when going up hill's revs up to high rpm without changing...
Managed to get onto the tar roads now where the problem is far more manageable gna try to limp accross the border maybe get a toyota service station on Monday
Sounds like the torque converter.
Time for fresh gearbox oil and a new filter.
If you make it back home with the gearbox intact, consider having the oil changed by a machine that flushes oit the whole system. The add 2 tubes of Dr Tranny.
It should solve the slipping clutches issue (IF it was not damaged completely)
