Fuel pump experts help please'- V6 Hilux
- Mornes
- Town: Roodepoort
- Vehicle: Hilux 4.0 DC 4x4 AT
- Real Name: Morne
Hi guys,
If there are any fuel pump experts out there, i would appreciate your input please.
I have a 1gr fe Hilux (4.0 V6) fitted with a TRD supercharger. It is a known problem of the V6 engine to have a problematic fuel pump, causing poor starting, high fuel consumption and surging at mid range RPM. There are factors that make it worse such as long range tank shavings etc. but in general i think the pump is inadequate, especially for the supercharger that runs off higher flow injectors.
I have replaced my pump 3 times now and am convinced that the pump just is not good enough for my application, especially at lower rev range under load where the pump is still operating in it's low speed setting.
I have by-passed the fuel pump resistor circuit and this seems to resolve the issue. No surging, improved fuel economy.
My question is tow fold.
(a) can i continue to run the pump at its 2nd stage full speed permanently, i.e. full speed all the time
(b) is there a pump upgrade available
Thanks!
Morne
Thanks!
Morne
Morne' Smuts
Toyota Hilux 2007 - 4.0 DC 4x4 A/T: TRD Supercharger, OME Suspension, Outback Canopy, 29Mhz Radio, 32 BFGR Tyres, Unichip, Echo 4 Trailer, Duel Battery System, Snorkel, ARB Bumper
- Vehicle: Toyota Hilux 4x4
- Real Name: JAMES
Re: Fuel pump experts help please'- V6 Hilux
I'm not a fuel pump "expert", but Underdog Racing Development sells a line of fuel pump upgrade kits. I used their Tacoma 2.7L kit on my 2.4L '03 Hilux without any problems. Call them and talk to their tech support people. They are very helpful.
https://www.urdusa.com/fuel-pumps/
- JAMES
- JAMES
- Knuppel
- Town: Somewhere in Africa
- Real Name: Marius
best solution is to get a better pump but in the meantime you will have no issues running it on the bypass circuit at full pressure. It will just not last as long as normal
Disel electric sells Bosch pump and they have different flow rates. I suggest you call them and explain the problem and let them suggest a pump with higher flow rate.
- Mornes
- Town: Roodepoort
- Real Name: Morne
Thanks gents.
Does anybody know what the standard fuel pump gives in terms of flow rate? i know pressure is around 2.8/2.9 bar.
Some of the performance fuel pumps available are 255/265 liter per hour.
Morne' Smuts
ATS supply automotive racing components. https://www.ats-motorsport.co.za/
- JohanM
- Town: Meyerton
- Vehicle: Prado 120 4.0 V6
- Club VHF Licence: HC126
Morne,
The average fuel pump for most engines supply around 150 - 200L per hour. I have read that most TRD superchargers use the standard pump, but there is upgrades available for it should you be running the high boost pulley.
Walbro pumps should be able to advise you on what flow rate will work for your HIlux as they supply replacement pumps that replace the OE one in tank without any modifications.
- Mornes
- Town: Roodepoort
- Real Name: Morne
Thanks Johan, I have the pulley upgrade and it makes sense that the problem is now more pronounced. I will search for the Walbro pump option to see where I can source it.
Thanks again.
Thanks again.
Morne' Smuts
- Willem van Schalkwyk
- Real Name: Willem Van Schalkwyk
Hi Morne,
I have the only solution for this problem.
Take the charger off. I will organise the transport to drop the charger at my place me. I will dispose of it in a responsible manner
Put your old intake back and you fuel pump should not be an issue anymore!
Pm me your address for pickup.
Regards,
Willem
Regards,
Willem
- Mornes
- Town: Roodepoort
- Real Name: Morne
A cold beer is the best you will get out of me...Willem van Schalkwyk wrote:Hi Morne,
Regards,
Willem
Sent from my SM-G950F using Tapatalk
Morne' Smuts
- JohanM
- Town: Meyerton
Morne, I am also planning to force feed my V6 Prado at some stage, hopefully by the end of this year. That is why I knew about the pumps....
That cold beer does sound good though...
- Mornes
- Town: Roodepoort
- Real Name: Morne
Walbro will not work on the Hilux unfortunately, the pump body is different and I would prefer not to modify the canister setup if I don't have to; too much of a mission to take the pump out.JohanM wrote:Morne, I am also planning to force feed my V6 Prado at some stage, hopefully by the end of this year. That is why I knew about the pumps....
I have found a fuel pump of the right pump body shape on e-bay. Its a Denso pump and used for the TRD model specifically. Battling to get pump flow specs but I'm hoping the model description of EFP 265 refers to 265 liter....
Morne' Smuts
